Developer documentation | Axl-2.5.1
Main Page
Classes
Class List
Class Index
Class Hierarchy
Class Members
axlAbstractCurveRational Member List
This is the complete list of members for
, including all inherited members.
addField
(axlAbstractField *field)
axlAbstractData
axlAbstractCurve
(void)
axlAbstractCurve
axlAbstractCurveParametric
(void)
(void)
axlAbstractData
(axlAbstractData *parent=NULL)
axlAbstractData
axlAbstractData
(const axlAbstractData &data)
axlAbstractData
changeFieldName
(QString fieldName)
axlAbstractData
color
axlAbstractData
color
(void) const
axlAbstractData
convertDataToQVariant
(void) const
axlAbstractData
virtual
convertQVariantToData
(const QVariantList &data)
axlAbstractData
virtual
curve
(void)
axlAbstractCurve
virtual
dimension
(void) const
axlAbstractCurve
virtual
editable
(void)
axlAbstractData
endParam
(void)
virtual
eval
(double u)
virtual
eval
(axlPoint *point, double u)
virtual
eval
(double u, int derivs, bool from_right=true)
virtual
fields
(void)
axlAbstractData
isPlanar
(void) const
axlAbstractCurve
virtual
length
(double tolerance)
virtual
mesh
(void)
axlAbstractData
modifiedField
(void)
axlAbstractData
signal
modifiedGeometry
(void)
axlAbstractData
signal
modifiedProperty
(void)
axlAbstractData
signal
modifiedStructure
(void)
axlAbstractData
signal
numSamples
(void)
virtual
onDirectChanged
(bool direct)
virtual
slot
opacity
axlAbstractData
opacity
(void) const
axlAbstractData
parameterOf
(const axlPoint &p)
samples
samples
(void) const
setColor
(double r, double g, double b)
axlAbstractData
setColor
(const QColor &color)
axlAbstractData
slot
setDenominator
(const QString &denominator)
virtual
setDomain
(const QString &domain)
virtual
setDomain
(const QVector< double > domain)
virtual
setEditable
(bool edit)
axlAbstractData
slot
setMesh
(axlMesh *mesh)
axlAbstractData
setNumAndDenom
(QStringList numAndDenom)
virtual
setNumerator
(int index, const QString &numerator)
virtual
setNumSamples
(int numSamples)
virtual
setOpacity
(const double &opacity)
axlAbstractData
slot
setSamples
(const int &color)
slot
setShader
(const QString &shader)
axlAbstractData
slot
setSize
(const double &size)
axlAbstractData
slot
setSurface
(QVector< double > domain, QStringList numAndDenom)
virtual
setUpdateView
(bool updateView)
axlAbstractData
shader
axlAbstractData
shader
(void) const
axlAbstractData
size
axlAbstractData
size
(void) const
axlAbstractData
startParam
(void)
virtual
touchField
(void)
axlAbstractData
virtual
slot
touchGeometry
(void)
axlAbstractData
slot
touchProperty
(void)
axlAbstractData
slot
touchStructure
(void)
axlAbstractData
slot
updateFieldList
(QString nameField)
axlAbstractData
updateView
(void)
axlAbstractData
write_denominator
(void) const
virtual
write_domain
(void) const
virtual
write_numerator
(unsigned index) const
virtual
~axlAbstractCurve
(void)
axlAbstractCurve
virtual
~axlAbstractCurveParametric
(void)
virtual
~axlAbstractCurveRational
(void)
virtual
~axlAbstractData
(void)
axlAbstractData
virtual
Generated on Sun Dec 2 2018 20:28:12 for Axl-2.5.1 by 1.8.9.1
