| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlAbstractField() | axlAbstractField | |
| axlAbstractField(QString name, Type type, Kind kind, Support support) | axlAbstractField | |
| axlAbstractFieldDiscrete() | axlAbstractFieldDiscrete | |
| axlAbstractFieldDiscrete(QString name, Type type, Kind kind, Support support, int size) | axlAbstractFieldDiscrete | |
| axlAbstractFieldDiscrete(void *array) | axlAbstractFieldDiscrete | |
| Cell enum value | axlAbstractField | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlAbstractData | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
| Custom enum value | axlAbstractField | |
| Double enum value | axlAbstractField | |
| editable(void) | axlAbstractData | |
| fields(void) | axlAbstractData | |
| Float enum value | axlAbstractField | |
| identifier(void) const | axlAbstractField | virtual |
| Int enum value | axlAbstractField | |
| kind(void) | axlAbstractField | virtual |
| Kind enum name | axlAbstractField | |
| maxValue(void) | axlAbstractField | virtual |
| mesh(void) | axlAbstractData | |
| minValue(void) | axlAbstractField | virtual |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| Point enum value | axlAbstractField | |
| scalar(int index) | axlAbstractFieldDiscrete | virtual |
| Scalar enum value | axlAbstractField | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setKind(Kind kind) | axlAbstractField | virtual |
| setMax(double maxi) | axlAbstractField | virtual |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setMin(double mini) | axlAbstractField | virtual |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setScalar(int index, double v1) | axlAbstractFieldDiscrete | virtual |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(int size) | axlAbstractFieldDiscrete | virtual |
| axlAbstractField::setSize(const double &size) | axlAbstractData | slot |
| setSupport(Support support) | axlAbstractField | virtual |
| setTensor(int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9) | axlAbstractFieldDiscrete | virtual |
| setType(Type type) | axlAbstractField | virtual |
| setUpdateView(bool updateView) | axlAbstractData | |
| setVector(int index, double v1, double v2, double v3) | axlAbstractFieldDiscrete | virtual |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size(void) | axlAbstractFieldDiscrete | virtual |
| axlAbstractField::size | axlAbstractData | |
| axlAbstractField::size(void) const | axlAbstractData | |
| Support enum name | axlAbstractField | |
| support(void) | axlAbstractField | virtual |
| tensor(int index) | axlAbstractFieldDiscrete | virtual |
| Tensor enum value | axlAbstractField | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| Type enum name | axlAbstractField | |
| type(void) | axlAbstractField | virtual |
| update(void) | axlAbstractFieldDiscrete | virtualslot |
| updated(void) | axlAbstractFieldDiscrete | signal |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| Vector enum value | axlAbstractField | |
| vector(int index) | axlAbstractFieldDiscrete | virtual |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlAbstractField(void) | axlAbstractField | virtual |
| ~axlAbstractFieldDiscrete(void) | axlAbstractFieldDiscrete | virtual |
