Developer documentation | Axl-2.5.1
axlCircleArc Member List
This is the complete list of members for axlCircleArc, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
applyMatrix(double *matrix)axlCircleArc
axlAbstractCurve(void)axlAbstractCurve
axlAbstractCurveParametric(void)axlAbstractCurveParametric
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlCircleArc(QObject *parent=0)axlCircleArc
axlCircleArc(const axlPoint &point1, const axlPoint &point2, const axlPoint &center, const axlPoint &normal, bool direct=true)axlCircleArc
axlCircleArc(const axlCircleArc &other)axlCircleArc
calculateNormal(void) const axlCircleArc
calculateRadius(void) const axlCircleArc
center(void) const axlCircleArc
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlCircleArcvirtual
convertQVariantToData(const QVariantList &data)axlCircleArcvirtual
curve(void)axlAbstractCurvevirtual
description(void) const axlCircleArcvirtual
dimension(void) const axlAbstractCurvevirtual
editable(void)axlAbstractData
endParam(void)axlAbstractCurveParametricvirtual
eval(double u)axlAbstractCurveParametricvirtual
eval(axlPoint *point, double u)axlAbstractCurveParametricvirtual
eval(double u, int derivs, bool from_right=true)axlAbstractCurveParametricvirtual
fields(void)axlAbstractData
identifier(void) const axlCircleArcvirtual
isDirect(void) const axlCircleArc
isPlanar(void) const axlAbstractCurvevirtual
length(double tolerance)axlAbstractCurveParametricvirtual
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
modifyCenter(double *center)axlCircleArc
modifyNormal(double *normal)axlCircleArc
modifyPoint1(double *point1)axlCircleArc
modifyPoint2(double *point2)axlCircleArc
normal(void) const axlCircleArc
numSamples(void)axlAbstractCurveParametricvirtual
onCenterXChanged(double x)axlCircleArcslot
onCenterYChanged(double y)axlCircleArcslot
onCenterZChanged(double z)axlCircleArcslot
onDirectChanged(bool direct)axlCircleArcvirtualslot
onNormalXChanged(double x)axlCircleArcslot
onNormalYChanged(double y)axlCircleArcslot
onNormalZChanged(double z)axlCircleArcslot
onPoint1XChanged(double x)axlCircleArcslot
onPoint1YChanged(double y)axlCircleArcslot
onPoint1ZChanged(double z)axlCircleArcslot
onPoint2XChanged(double x)axlCircleArcslot
onPoint2YChanged(double y)axlCircleArcslot
onPoint2ZChanged(double z)axlCircleArcslot
opacityaxlAbstractData
opacity(void) const axlAbstractData
operator<<(QDebug dbg, axlCircleArc arc)axlCircleArcfriend
operator<<(QDebug dbg, axlCircleArc &arc)axlCircleArcfriend
operator<<(QDebug dbg, axlCircleArc *arc)axlCircleArcfriend
operator=(const axlCircleArc &other)axlCircleArc
parameterOf(const axlPoint &p)axlAbstractCurveParametric
point1(void) const axlCircleArc
point2(void) const axlCircleArc
samplesaxlAbstractCurveParametric
samples(void) const axlAbstractCurveParametric
setCenter(const axlPoint &center)axlCircleArc
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setDirect(bool direct)axlCircleArc
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setNormal(const axlPoint &normal)axlCircleArc
setNumSamples(int numSamples)axlAbstractCurveParametricvirtual
setOpacity(const double &opacity)axlAbstractDataslot
setPoint1(const axlPoint &point1)axlCircleArc
setPoint2(const axlPoint &point2)axlCircleArc
setSamples(const int &color)axlAbstractCurveParametricslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setUpdateView(bool updateView)axlAbstractData
setValues(const axlPoint &point1, const axlPoint &point2, const axlPoint &center, const axlPoint &normal, bool direct=true)axlCircleArc
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
startParam(void)axlAbstractCurveParametricvirtual
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
~axlAbstractCurve(void)axlAbstractCurvevirtual
~axlAbstractCurveParametric(void)axlAbstractCurveParametricvirtual
~axlAbstractData(void)axlAbstractDatavirtual
~axlCircleArc(void)axlCircleArcvirtual
