| addField(axlAbstractField *field) | axlAbstractData | |
| append_curve(const axlAbstractCurve &curve) | axlCompositeCurve | |
| append_curve(axlAbstractCurve *curve) | axlCompositeCurve | |
| append_point(const axlPoint &startPoint, const axlPoint &endPoint) | axlCompositeCurve | |
| append_point(axlPoint *startPoint, axlPoint *endPoint) | axlCompositeCurve | |
| axlAbstractCurve(void) | axlAbstractCurve | |
| axlAbstractCurveParametric(void) | axlAbstractCurveParametric | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlCompositeCurve(QObject *parent=0) | axlCompositeCurve | |
| axlCompositeCurve(bool Case, QObject *parent=0) | axlCompositeCurve | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlAbstractData | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
| count_curve(void) const | axlCompositeCurve | |
| curve(void) | axlAbstractCurve | virtual |
| description(void) const | axlCompositeCurve | virtual |
| dimension(void) const | axlAbstractCurve | virtual |
| editable(void) | axlAbstractData | |
| endParam(void) | axlAbstractCurveParametric | virtual |
| eval(double u) | axlAbstractCurveParametric | virtual |
| eval(axlPoint *point, double u) | axlAbstractCurveParametric | virtual |
| eval(double u, int derivs, bool from_right=true) | axlAbstractCurveParametric | virtual |
| fields(void) | axlAbstractData | |
| get_curve_at_id(int id) const | axlCompositeCurve | |
| get_end_point() | axlCompositeCurve | |
| get_pt_curve_at_id(int id) const | axlCompositeCurve | |
| get_ref_curve_at_id(int id) const | axlCompositeCurve | |
| get_start_point() | axlCompositeCurve | |
| getCase() | axlCompositeCurve | |
| identifier(void) const | axlCompositeCurve | virtual |
| insert_curve(axlAbstractCurve *curve, int id_want_inserted) | axlCompositeCurve | |
| insert_curve(axlAbstractCurve curve, int id_want_inserted) | axlCompositeCurve | |
| insert_list_curves(const QList< axlAbstractCurve > &data_curves) | axlCompositeCurve | |
| insert_list_curves(const QList< axlAbstractCurve * > &data_curve) | axlCompositeCurve | |
| isPlanar(void) const | axlAbstractCurve | virtual |
| length(double tolerance) | axlAbstractCurveParametric | virtual |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| numSamples(void) | axlAbstractCurveParametric | virtual |
| onDirectChanged(bool direct) | axlAbstractCurveParametric | virtualslot |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator=(const axlCompositeCurve &other) | axlCompositeCurve | |
| parameterOf(const axlPoint &p) | axlAbstractCurveParametric | |
| remove_curve_at_id(int id_want_remove) | axlCompositeCurve | |
| remove_last_curve() | axlCompositeCurve | |
| samples | axlAbstractCurveParametric | |
| samples(void) const | axlAbstractCurveParametric | |
| setCase(bool Case) | axlCompositeCurve | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNumSamples(int numSamples) | axlAbstractCurveParametric | virtual |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setSamples(const int &color) | axlAbstractCurveParametric | slot |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| startParam(void) | axlAbstractCurveParametric | virtual |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractCurve(void) | axlAbstractCurve | virtual |
| ~axlAbstractCurveParametric(void) | axlAbstractCurveParametric | virtual |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlCompositeCurve() | axlCompositeCurve | |
