addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlCylinder(QObject *parent=0) | axlCylinder | |
axlCylinder(axlPoint *p1, axlPoint *p2, double radius, QObject *parent=0) | axlCylinder | |
axlCylinder(const axlPoint &p1, const axlPoint &p2, double radius, QObject *parent=0) | axlCylinder | |
axlCylinder(const axlCylinder &other) | axlCylinder | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlCylinder | virtual |
convertQVariantToData(const QVariantList &data) | axlCylinder | virtual |
description(void) const | axlCylinder | virtual |
editable(void) | axlAbstractData | |
fields(void) | axlAbstractData | |
firstPoint(void) const | axlCylinder | |
identifier(void) const | axlCylinder | virtual |
length(void) const | axlCylinder | |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
onFirstPointChanged(axlPoint *p1) | axlCylinder | slot |
onRadiusChanged(double radius) | axlCylinder | slot |
onSecondPointChanged(axlPoint *p2) | axlCylinder | slot |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
operator<<(QDebug dbg, axlCylinder line) | axlCylinder | friend |
operator<<(QDebug dbg, axlCylinder &line) | axlCylinder | friend |
operator<<(QDebug dbg, axlCylinder *line) | axlCylinder | friend |
operator=(const axlCylinder &other) | axlCylinder | |
point1 | axlCylinder | |
point2 | axlCylinder | |
radius | axlCylinder | |
radius(void) const | axlCylinder | |
secondPoint(void) const | axlCylinder | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setEditable(bool edit) | axlAbstractData | slot |
setFirstPoint(axlPoint *p1) | axlCylinder | |
setFirstPoint(double *p1) | axlCylinder | |
setLength(double length) | axlCylinder | |
setMesh(axlMesh *mesh) | axlAbstractData | |
setOpacity(const double &opacity) | axlAbstractData | slot |
setRadius(double radius) | axlCylinder | |
setSecondPoint(axlPoint *p2) | axlCylinder | |
setSecondPoint(double *p2) | axlCylinder | |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setUpdateView(bool updateView) | axlAbstractData | |
setValues(axlPoint *p1, axlPoint *p2, double radius) | axlCylinder | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
touchField(void) | axlAbstractData | virtualslot |
touchFirstPoint(axlPoint p1) | axlCylinder | |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchRadius(double radius) | axlCylinder | |
touchSecondPoint(axlPoint p2) | axlCylinder | |
touchStructure(void) | axlAbstractData | slot |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlCylinder(void) | axlCylinder | |
