| axlInspectorObjectComposite(QWidget *parent=0) | axlInspectorObjectComposite | |
| hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectComposite | signal |
| modifiedProperty(dtkAbstractData *, int) | axlInspectorObjectComposite | signal |
| moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectComposite | signal |
| onColorChanged(QColor color) | axlInspectorObjectComposite | slot |
| onHideCurrentPoint(double u, double v) | axlInspectorObjectComposite | slot |
| onLineEditShaderChanged(QString) | axlInspectorObjectComposite | slot |
| onMoveCurrentPoint(double u, double v) | axlInspectorObjectComposite | slot |
| onOpacityChanged(int opacity) | axlInspectorObjectComposite | slot |
| onShaderChanged(QString) | axlInspectorObjectComposite | slot |
| onShaderStateChanged(bool isShader) | axlInspectorObjectComposite | slot |
| onShowCurrentPoint(double u, double v) | axlInspectorObjectComposite | slot |
| openShader(void) | axlInspectorObjectComposite | slot |
| setData(axlAbstractDataComposite *data) | axlInspectorObjectComposite | slot |
| showCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectComposite | signal |
| sizeHint(void) const | axlInspectorObjectComposite | |
| update(void) | axlInspectorObjectComposite | signal |
| ~axlInspectorObjectComposite(void) | axlInspectorObjectComposite | |
