Developer documentation | Axl-2.5.1
axlMesh Member List
This is the complete list of members for axlMesh, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
all_edge_count(void) const axlMesh
append(axlMesh *mesh)axlMesh
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlMesh(void)axlMesh
boundingBoxVertex(void) const axlMesh
changeFieldName(QString fieldName)axlAbstractData
clearNormals(void)axlMesh
coloraxlAbstractData
color(void) const axlAbstractData
color_count(void) const axlMesh
color_used(void) const axlMesh
color_used(void)axlMesh
colorB(const int &ind)axlMesh
colorBF(const int &ind)axlMesh
colorG(const int &ind)axlMesh
colorGF(const int &ind)axlMesh
colorR(const int &ind)axlMesh
colorRF(const int &ind)axlMesh
convertDataToQVariant(void) const axlMeshvirtual
convertQVariantToData(const QVariantList &data)axlMeshvirtual
description(void) const axlMeshvirtual
distance(int ind1, int ind2)axlMesh
Edge typedefaxlMesh
edge(int ind) const axlMesh
edge_show(void) const axlMesh
edge_show(void)axlMesh
edgePointCount(int i) const axlMesh
edgePointIndex(int i, int j) const axlMesh
edgePushBack(int, int)axlMesh
edgeSet(void) const axlMesh
editable(void)axlAbstractData
espilon(void)axlMesh
Face typedefaxlMesh
face(int ind) const axlMesh
face_count(void) const axlMesh
face_show(void) const axlMesh
face_show(void)axlMesh
facePointCount(int i) const axlMesh
facePointIndex(int i, int j) const axlMesh
faceSet(void) const axlMesh
fields(void)axlAbstractData
FLAT enum valueaxlMesh
getColor(const int &ind, int color[3])axlMesh
GOURAUD enum valueaxlMesh
identifier(void) const axlMeshvirtual
insert_face(const Face &face)axlMeshinline
Intepolation enum nameaxlMesh
interpolation(void) const axlMesh
isPlanar(void) const axlMesh
isPlanar(void)axlMesh
mesh(void)axlAbstractData
meshVertexScaleFactor() const axlMesh
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
neighborsFace(const axlMesh &mesh)axlMeshstatic
noDuplicateVertices(void)axlMesh
normal(const int &ind, double normal[3])axlMesh
normal(int ind, axlPoint &normal)axlMesh
normal(int ind, axlPoint *normal)axlMesh
normal2(int ind, axlPoint *normal)axlMesh
normal_count(void) const axlMesh
normal_used(void) const axlMesh
normal_used(void)axlMesh
normalSet(void)axlMesh
normalX(const int &ind) const axlMesh
normalY(const int &ind) const axlMesh
normalZ(const int &ind) const axlMesh
opacityaxlAbstractData
opacity(void) const axlAbstractData
operator[](int i)axlMesh
PHONG enum valueaxlMesh
Point typedefaxlMesh
push_back_color(const int &r, const int &g, const int &b)axlMesh
push_back_color(const int color[3])axlMesh
push_back_edge(int, int)axlMesh
push_back_edge(const Edge &e)axlMesh
push_back_face(const Face &face)axlMesh
push_back_face(int i1, int i2, int i3)axlMesh
push_back_new_edge(void)axlMesh
push_back_normal(axlPoint *normal)axlMesh
push_back_normal(const double &x, const double &y, const double &z)axlMesh
push_back_normal(const double normal[3])axlMesh
push_back_vertex(const double &x, const double &y, const double &z)axlMesh
push_back_vertex(const double vertex[3])axlMesh
push_back_vertex(const axlPoint &vertex)axlMesh
push_back_vertex(axlPoint *vertex)axlMesh
set_vertex(axlPoint *point, const int &ind)axlMesh
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setEpsilon(double epsilon)axlMesh
setInterpolation(int interpolation)axlMesh
setMesh(axlMesh *mesh)axlAbstractData
setNormals(const QList< axlPoint * > &pointSet)axlMesh
setOpacity(const double &opacity)axlAbstractDataslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setUpdateView(bool updateView)axlAbstractData
setVertices(const QVector< axlPoint * > &pointSet)axlMesh
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
vertex(const int &ind, double vertex[3])axlMesh
vertex(int ind, axlPoint &point) const axlMesh
vertex(int ind, axlPoint *point) const axlMesh
vertex2(int ind, axlPoint *point) const axlMesh
vertex_count(void) const axlMesh
vertex_show(void) const axlMesh
vertex_show()axlMesh
vertexSet(void) const axlMesh
VertexTofaceIndexes(const axlMesh &mesh)axlMeshstatic
vertexX(const int &ind) const axlMesh
vertexY(const int &ind) const axlMesh
vertexZ(const int &ind) const axlMesh
~axlAbstractData(void)axlAbstractDatavirtual
~axlMesh(void)axlMesh
