| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlPlane(QObject *parent=0) | axlPlane | |
| axlPlane(axlPoint *point, axlPoint *normal, QObject *parent=0) | axlPlane | |
| axlPlane(const axlPoint &point, const axlPoint &normal, QObject *parent=0) | axlPlane | |
| axlPlane(const axlPlane &other) | axlPlane | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlPlane | virtual |
| convertQVariantToData(const QVariantList &data) | axlPlane | virtual |
| description(void) const | axlPlane | virtual |
| editable(void) | axlAbstractData | |
| fields(void) | axlAbstractData | |
| identifier(void) const | axlPlane | virtual |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| normal | axlPlane | |
| normal(void) const | axlPlane | |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator<<(QDebug dbg, axlPlane plane) | axlPlane | friend |
| operator<<(QDebug dbg, axlPlane &plane) | axlPlane | friend |
| operator<<(QDebug dbg, axlPlane *plane) | axlPlane | friend |
| operator=(const axlPlane &other) | axlPlane | |
| point | axlPlane | |
| point(void) const | axlPlane | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNormal(axlPoint *normal) | axlPlane | |
| setNormal(double *normal) | axlPlane | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setPoint(axlPoint *point) | axlPlane | |
| setPoint(double *p) | axlPlane | |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| setValues(axlPoint *point, axlPoint *normal) | axlPlane | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchNormal(axlPoint normal) | axlPlane | |
| touchPoint(axlPoint point) | axlPlane | |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlPlane(void) | axlPlane | |
