Developer documentation | Axl-2.5.1
axlSurfaceParametricOffset Member List
This is the complete list of members for axlSurfaceParametricOffset, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
area(double tol)axlAbstractSurfaceParametricvirtual
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlAbstractSurface(void)axlAbstractSurface
axlAbstractSurfaceParametric(void)axlAbstractSurfaceParametric
axlSurfaceParametricOffset(axlAbstractSurfaceParametric *surfaceParam, double offset=0.0)axlSurfaceParametricOffset
axlSurfaceParametricOffset(const axlSurfaceParametricOffset &other)axlSurfaceParametricOffset
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlAbstractDatavirtual
convertQVariantToData(const QVariantList &data)axlAbstractDatavirtual
countCells(void)axlAbstractSurfaceParametricvirtual
description(void) const axlSurfaceParametricOffsetvirtual
dimension(void) const axlAbstractSurfacevirtual
editable(void)axlAbstractData
endParam_u(void)axlAbstractSurfaceParametricvirtual
endParam_u(int numCell)axlAbstractSurfaceParametricvirtual
endParam_v(void)axlAbstractSurfaceParametricvirtual
endParam_v(int numCell)axlAbstractSurfaceParametricvirtual
eval(double u, double v)axlAbstractSurfaceParametricvirtual
eval(axlPoint *point, double u, double v)axlAbstractSurfaceParametricvirtual
eval(double &, double &, double &, double u, double v)axlAbstractSurfaceParametricvirtual
eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12)axlAbstractSurfaceParametricvirtual
eval(axlPoint *point, double u, double v, int numCell)axlAbstractSurfaceParametricvirtual
eval2(double u, double v)axlAbstractSurfaceParametricvirtual
fields(void)axlAbstractData
hasCells(void)axlAbstractSurfaceParametricvirtual
identifier(void) const axlSurfaceParametricOffsetvirtual
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
normal(axlPoint *normal, double u, double v)axlAbstractSurfaceParametricvirtual
normal(double u, double v)axlAbstractSurfaceParametricvirtual
normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v)axlAbstractSurfaceParametricvirtual
normal(axlPoint *normal, double u, double v, int numCell)axlAbstractSurfaceParametricvirtual
numSamples_u(void)axlAbstractSurfaceParametricvirtual
numSamples_u(int numCell)axlAbstractSurfaceParametricvirtual
numSamples_v(void)axlAbstractSurfaceParametricvirtual
numSamples_v(int numCell)axlAbstractSurfaceParametricvirtual
offset(void)axlSurfaceParametricOffset
opacityaxlAbstractData
opacity(void) const axlAbstractData
operator<<(QDebug dbg, axlSurfaceParametricOffset sphere)axlSurfaceParametricOffsetfriend
operator<<(QDebug dbg, axlSurfaceParametricOffset &sphere)axlSurfaceParametricOffsetfriend
operator<<(QDebug dbg, axlSurfaceParametricOffset *sphere)axlSurfaceParametricOffsetfriend
operator=(const axlSurfaceParametricOffset &other)axlSurfaceParametricOffset
parameterOf(const axlPoint &point, double &um, double &vm)axlAbstractSurfaceParametricvirtual
samples_uaxlAbstractSurfaceParametric
samples_u(void) const axlAbstractSurfaceParametric
samples_vaxlAbstractSurfaceParametric
samples_v(void) const axlAbstractSurfaceParametric
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setNumSamples_u(int numSamples)axlAbstractSurfaceParametricvirtual
setNumSamples_v(int numSamples)axlAbstractSurfaceParametricvirtual
setOffset(double offset)axlSurfaceParametricOffset
setOpacity(const double &opacity)axlAbstractDataslot
setSamples_u(const int &color)axlAbstractSurfaceParametricslot
setSamples_v(const int &color)axlAbstractSurfaceParametricslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setStripes(int stripes)axlAbstractSurfaceParametricvirtual
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
startParam_u(void)axlAbstractSurfaceParametricvirtual
startParam_u(int numCell)axlAbstractSurfaceParametricvirtual
startParam_v(void)axlAbstractSurfaceParametricvirtual
startParam_v(int numCell)axlAbstractSurfaceParametricvirtual
stripes(void)axlAbstractSurfaceParametricvirtual
surface(void)axlAbstractSurfacevirtual
surfaceParam(void)axlSurfaceParametricOffset
toAxlMesh(void)axlAbstractSurfacevirtual
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
~axlAbstractData(void)axlAbstractDatavirtual
~axlAbstractSurface(void)axlAbstractSurfacevirtual
~axlAbstractSurfaceParametric(void)axlAbstractSurfaceParametricvirtual
~axlSurfaceParametricOffset(void)axlSurfaceParametricOffsetvirtual
