| addField(axlAbstractField *field) | axlAbstractData |  |
  | area(double tol) | axlAbstractSurfaceParametric | virtual |
  | axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData |  |
  | axlAbstractData(const axlAbstractData &data) | axlAbstractData |  |
  | axlAbstractSurface(void) | axlAbstractSurface |  |
  | axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric |  |
  | axlTorusParametric(axlAbstractSurfaceParametric *parent=0) | axlTorusParametric |  |
  | axlTorusParametric(axlTorus *torus, axlPoint *r) | axlTorusParametric |  |
  | axlTorusParametric(const axlTorus &torus, const axlPoint &r) | axlTorusParametric |  |
  | axlTorusParametric(const axlTorusParametric &other) | axlTorusParametric |  |
  | changeFieldName(QString fieldName) | axlAbstractData |  |
  | color | axlAbstractData |  |
  | color(void) const | axlAbstractData |  |
  | convertDataToQVariant(void) const | axlAbstractData | virtual |
  | convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
  | countCells(void) | axlAbstractSurfaceParametric | virtual |
  | description(void) const | axlTorusParametric | virtual |
  | dimension(void) const | axlAbstractSurface | virtual |
  | editable(void) | axlAbstractData |  |
  | endParam_u(void) | axlAbstractSurfaceParametric | virtual |
  | endParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
  | endParam_v(void) | axlAbstractSurfaceParametric | virtual |
  | endParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
  | eval(double u, double v) | axlTorusParametric | virtual |
  | eval(axlPoint *point, double u, double v) | axlTorusParametric | virtual |
  | eval(double &x, double &y, double &z, double u, double v) | axlTorusParametric | virtual |
  | axlAbstractSurfaceParametric::eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) | axlAbstractSurfaceParametric | virtual |
  | axlAbstractSurfaceParametric::eval(axlPoint *point, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
  | eval2(double u, double v) | axlAbstractSurfaceParametric | virtual |
  | fields(void) | axlAbstractData |  |
  | getR(void) const | axlTorusParametric |  |
  | getTorus(void) const | axlTorusParametric |  |
  | getV(void) const | axlTorusParametric |  |
  | getW(void) const | axlTorusParametric |  |
  | hasCells(void) | axlAbstractSurfaceParametric | virtual |
  | identifier(void) const | axlTorusParametric | virtual |
  | mesh(void) | axlAbstractData |  |
  | modifiedField(void) | axlAbstractData | signal |
  | modifiedGeometry(void) | axlAbstractData | signal |
  | modifiedProperty(void) | axlAbstractData | signal |
  | modifiedStructure(void) | axlAbstractData | signal |
  | modifyR(double *r) | axlTorusParametric |  |
  | normal(axlPoint *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
  | normal(double u, double v) | axlAbstractSurfaceParametric | virtual |
  | normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
  | normal(axlPoint *normal, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
  | numSamples_u(void) | axlAbstractSurfaceParametric | virtual |
  | numSamples_u(int numCell) | axlAbstractSurfaceParametric | virtual |
  | numSamples_v(void) | axlAbstractSurfaceParametric | virtual |
  | numSamples_v(int numCell) | axlAbstractSurfaceParametric | virtual |
  | onRChanged(axlPoint *r) | axlTorusParametric | slot |
  | onTorusChanged(axlTorus *torus) | axlTorusParametric | slot |
  | opacity | axlAbstractData |  |
  | opacity(void) const | axlAbstractData |  |
  | operator=(const axlTorusParametric &other) | axlTorusParametric |  |
  | parameterOf(const axlPoint &point, double &um, double &vm) | axlTorusParametric | virtual |
  | samples_u | axlAbstractSurfaceParametric |  |
  | samples_u(void) const | axlAbstractSurfaceParametric |  |
  | samples_v | axlAbstractSurfaceParametric |  |
  | samples_v(void) const | axlAbstractSurfaceParametric |  |
  | setColor(double r, double g, double b) | axlAbstractData |  |
  | setColor(const QColor &color) | axlAbstractData | slot |
  | setEditable(bool edit) | axlAbstractData | slot |
  | setMesh(axlMesh *mesh) | axlAbstractData |  |
  | setNumSamples_u(int numSamples) | axlAbstractSurfaceParametric | virtual |
  | setNumSamples_v(int numSamples) | axlAbstractSurfaceParametric | virtual |
  | setOpacity(const double &opacity) | axlAbstractData | slot |
  | setR(axlPoint *r) | axlTorusParametric |  |
  | setSamples_u(const int &color) | axlAbstractSurfaceParametric | slot |
  | setSamples_v(const int &color) | axlAbstractSurfaceParametric | slot |
  | setShader(const QString &shader) | axlAbstractData | slot |
  | setSize(const double &size) | axlAbstractData | slot |
  | setStripes(int stripes) | axlAbstractSurfaceParametric | virtual |
  | setTorus(const axlTorus &torus) | axlTorusParametric |  |
  | setUpdateView(bool updateView) | axlAbstractData |  |
  | shader | axlAbstractData |  |
  | shader(void) const | axlAbstractData |  |
  | size | axlAbstractData |  |
  | size(void) const | axlAbstractData |  |
  | startParam_u(void) | axlAbstractSurfaceParametric | virtual |
  | startParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
  | startParam_v(void) | axlAbstractSurfaceParametric | virtual |
  | startParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
  | stripes(void) | axlAbstractSurfaceParametric | virtual |
  | surface(void) | axlAbstractSurface | virtual |
  | toAxlMesh(void) | axlAbstractSurface | virtual |
  | touchField(void) | axlAbstractData | virtualslot |
  | touchGeometry(void) | axlAbstractData | slot |
  | touchProperty(void) | axlAbstractData | slot |
  | touchStructure(void) | axlAbstractData | slot |
  | updateFieldList(QString nameField) | axlAbstractData |  |
  | updateView(void) | axlAbstractData |  |
  | ~axlAbstractData(void) | axlAbstractData | virtual |
  | ~axlAbstractSurface(void) | axlAbstractSurface | virtual |
  | ~axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | virtual |
  | ~axlTorusParametric(void) | axlTorusParametric | virtual |
