Developer documentation | Axl-2.5.1
axlVtkView Member List
This is the complete list of members for axlVtkView, including all inherited members.
activeDefaultLigh(bool useDefaultLight)axlVtkViewvirtual
actor(dtkAbstractData *data)axlAbstractViewvirtual
add(dtkAbstractData *data)axlAbstractViewvirtual
axlAbstractView(void)axlAbstractView
axlVtkView(void)axlVtkView
bounds(float &xmin, float &xmax, float &ymin, float &ymax, float &zmin, float &zmax)axlVtkViewslot
cameraFocalPoint(double *coordinates)axlVtkViewslot
cameraPosition(double *coordinates)axlVtkViewslot
cameraUp(double *coordinates)axlVtkViewslot
controller(void)axlAbstractView
dataChangedByColor(dtkAbstractData *data, double red, double green, double blue)axlAbstractViewslot
dataChangedByGeometry(dtkAbstractData *data)axlAbstractViewslot
dataChangedByOpacity(dtkAbstractData *data, double opacity)axlAbstractViewslot
dataChangedByProperty(dtkAbstractData *data, int channel)axlAbstractViewslot
dataChangedBySize(dtkAbstractData *data, double size)axlAbstractViewslot
description(void) const axlVtkViewvirtual
getAxesVisibility(void)axlVtkViewvirtual
getBackgroundColor(void)axlVtkViewvirtual
getBackgroundGradient(void)axlVtkViewvirtual
getCameraFocalPoint(void)axlVtkViewvirtual
getCameraUp(void)axlVtkViewvirtual
getCameraViewAngle(void)axlVtkViewvirtual
getParallelProjection(void)axlVtkViewvirtual
getParallelScale(void)axlVtkViewvirtual
getSingletonFactory(void)axlAbstractView
getWorldCameraPosition(void)axlVtkViewvirtual
insert(axlAbstractData *data)axlVtkViewvirtual
axlAbstractView::insert(dtkAbstractData *data, axlAbstractActor *actor)axlAbstractViewvirtual
insertData(axlAbstractData *data)axlAbstractViewsignal
inserted(void)axlAbstractViewsignal
insertSet(QList< axlAbstractData * > dataSet)axlVtkViewvirtual
lightPositionChanged(double x, double y, double z)axlAbstractViewsignal
onActorVisibilityChanged(dtkAbstractData *data, bool actorVisibility)axlAbstractViewslot
onBackgroundGradientChange(bool gradient)axlVtkViewslot
onControlPointChanged(dtkAbstractData *data)axlAbstractViewslot
ondataSetRemoved(QList< dtkAbstractData * > dataSetToRemoved)axlAbstractViewslot
onGridResolutionChanged(int resolution)axlVtkViewslot
onInterpolationChanded(dtkAbstractData *data, int interpolation)axlAbstractViewslot
onLightPositionChanged(double x, double y, double z)axlAbstractViewslot
onShaderChanged(dtkAbstractData *data, QString isophoteShaderXml)axlAbstractViewslot
onShowAxis(bool show)axlVtkViewslot
onStateChanged(dtkAbstractData *data, int mode)axlAbstractViewslot
onTubeFilterRadiusChanged(dtkAbstractData *data, double radius)axlAbstractViewslot
onUpdateActorField(QList< axlAbstractData * > axlDataSet, QString fieldName)axlVtkViewslot
processIsophoteByShader(dtkAbstractData *data, QString isophoteShaderXml)axlAbstractViewslot
registered(void)axlVtkViewstatic
removeData(dtkAbstractData *data)axlAbstractViewvirtual
removeField(dtkAbstractData *data)axlAbstractViewvirtual
removeSet(QList< axlAbstractActor * > actorSet)axlVtkViewvirtual
removeSetFields(QList< axlAbstractActorField * > actorSet)axlVtkViewvirtual
setBackgroundColor(double red, double green, double blue)axlVtkViewslot
setCameraFocalPoint(double x, double y, double z)axlVtkViewvirtual
setCameraPosition(double x, double y, double z)axlVtkViewslot
setCameraUp(double x, double y, double z)axlVtkViewvirtual
setCameraViewAngle(double angle)axlVtkViewvirtual
setCameraViewDefaut(void)axlVtkViewvirtual
setCameraViewNegativeX(void)axlVtkViewvirtual
setCameraViewNegativeY(void)axlVtkViewvirtual
setCameraViewNegativeZ(void)axlVtkViewvirtual
setCameraViewPositiveX(void)axlVtkViewvirtual
setCameraViewPositiveY(void)axlVtkViewvirtual
setCameraViewPositiveZ(void)axlVtkViewvirtual
setGrid(bool isGridX, bool isGridY, bool isGridZ)axlVtkViewvirtual
setJoystickInteractor(void)axlVtkViewslot
setLight(int i, bool hide, double *position, double *ambiant, double *diffuse, double *specular, int exponent)axlVtkViewvirtual
setObjectCamera(void)axlVtkViewslot
setParallelCamera(bool parallel)axlVtkViewvirtual
setParallelScale(double parallelScale)axlVtkViewvirtual
setTrackballInteractor(void)axlVtkViewslot
setWorldCamera(void)axlVtkViewslot
showColorMapping(dtkAbstractData *data)axlAbstractViewslot
size(void)axlAbstractViewvirtual
stateChanged(dtkAbstractData *data, int mode)axlAbstractViewsignal
update(void)axlVtkViewvirtual
updateFieldActor(dtkAbstractData *data)axlVtkViewvirtual
widget(void)axlVtkView
~axlAbstractView(void)axlAbstractViewvirtual
~axlVtkView(void)axlVtkViewvirtual
