Developer documentation | Axl-2.5.1
axlAbstractFieldDiscrete.cpp
Go to the documentation of this file.
1 /* axlAbstractFieldDiscrete.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
16
17 #include <dtkCoreSupport/dtkGlobal.h>
18
19
20 // /////////////////////////////////////////////////////////////////
21 // axlAbstractFieldDiscrete implementation
22 // /////////////////////////////////////////////////////////////////
23
25
30 {
31
32 }
33
37 axlAbstractFieldDiscrete::axlAbstractFieldDiscrete(QString name, Type type, Kind kind, Support support, int size)
38 {
39
40 }
41
43
49 {
50
51 }
52
54
58 {
59 }
60
63 // *
64 // */
65 //void axlAbstractFieldDiscrete::setType(axlAbstractFieldDiscrete::Type type)
66 //{
67 // Q_UNUSED(type);
68 //}
69
72 // *
73 // */
74 //void axlAbstractFieldDiscrete::setKind(axlAbstractFieldDiscrete::Kind kind)
75 //{
76 // Q_UNUSED(kind);
77 //}
78
81 // *
82 // */
83 //void axlAbstractFieldDiscrete::setSupport(axlAbstractFieldDiscrete::Support support)
84 //{
85 // Q_UNUSED(support);
86 //}
87
89
92 void axlAbstractFieldDiscrete::setScalar(int index, double v1)
93 {
94  Q_UNUSED(index);
95  Q_UNUSED(v1);
96 }
97
99
102 void axlAbstractFieldDiscrete::setVector(int index, double v1, double v2, double v3)
103 {
104  Q_UNUSED(index);
105  Q_UNUSED(v1);
106  Q_UNUSED(v2);
107  Q_UNUSED(v3);
108 }
109
111
115 void axlAbstractFieldDiscrete::setTensor(int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9)
116 {
117  Q_UNUSED(index);
118  Q_UNUSED(v1);
119  Q_UNUSED(v2);
120  Q_UNUSED(v3);
121  Q_UNUSED(v4);
122  Q_UNUSED(v5);
123  Q_UNUSED(v6);
124  Q_UNUSED(v7);
125  Q_UNUSED(v8);
126  Q_UNUSED(v9);
127 }
128
129 //axlAbstractFieldDiscrete::Type axlAbstractFieldDiscrete::type(void)
130 //{
131 // DTK_DEFAULT_IMPLEMENTATION;
132
133 // return axlAbstractFieldDiscrete::Double;
134 //}
135
136 //axlAbstractFieldDiscrete::Kind axlAbstractFieldDiscrete::kind(void)
137 //{
138 // DTK_DEFAULT_IMPLEMENTATION;
139
140 // return axlAbstractFieldDiscrete::Scalar;
141 //}
142
143 //axlAbstractFieldDiscrete::Support axlAbstractFieldDiscrete::support(void)
144 //{
145 // DTK_DEFAULT_IMPLEMENTATION;
146
147 // return axlAbstractFieldDiscrete::Point;
148 //}
149
151 {
152  DTK_DEFAULT_IMPLEMENTATION;
153
154  return -1;
155 }
156
158 {
159  Q_UNUSED(size);
160
161 }
162
164
168 {
169  DTK_DEFAULT_IMPLEMENTATION;
170
171  return 0;
172 }
173
175
179 {
180  DTK_DEFAULT_IMPLEMENTATION;
181
182  return NULL;
183 }
184
186
190 {
191  DTK_DEFAULT_IMPLEMENTATION;
192
193  return NULL;
194 }
195
198 // *
199 // */
200 //QString axlAbstractFieldDiscrete::name(void)
201 //{
202 // DTK_DEFAULT_IMPLEMENTATION;
203
204 // return "";
205 //}
206
207 //void axlAbstractFieldDiscrete::setName(QString name)
208 //{
209 // Q_UNUSED(name);
210 //}
211
212
215
219 {
220  DTK_DEFAULT_IMPLEMENTATION;
221 }
222
223
226 // *
227 // */
228 //void *axlAbstractFieldDiscrete::array(void)
229 //{
230 // DTK_DEFAULT_IMPLEMENTATION;
231
232 // return NULL;
233 //}
234
235
236 //QString axlAbstractFieldDiscrete::objectType(void)
237 //{
238 // return "Field";
239 //}
240
241 // /////////////////////////////////////////////////////////////////
242 // axlAbstractFieldDiscrete documentation
243 // /////////////////////////////////////////////////////////////////
244
virtual ~axlAbstractFieldDiscrete(void)
Destroys the discrete field.
virtual double scalar(int index)
Returns the value at index location of the scalar array.
virtual void setTensor(int index, double v1, double v2, double v3, double v4, double v5, double v6, double v7, double v8, double v9)
virtual void setVector(int index, double v1, double v2, double v3)
virtual double * tensor(int index)
Returns the value at index location of the tensor array.
virtual void setScalar(int index, double v1)
virtual double * vector(int index)
Returns the value at index location of the vector array.
