Developer documentation | Axl-2.5.1
axlAbstractFieldParametricSurface.cpp
Go to the documentation of this file.
1 /* axlAbstractFieldParametricSurface.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include <dtkCoreSupport/dtkGlobal.h>
20
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23
24 class axlAbstractFieldParametricSurfacePrivate
25 {
26 public:
27 };
28
29 // /////////////////////////////////////////////////////////////////
30 // axlAbstractFieldParametricSurface implementation
31 // /////////////////////////////////////////////////////////////////
32
34
38 {
39 }
40
41
42
44
48 {
49  delete d;
50
51  d = NULL;
52 }
53
54
56
60
61  DTK_DEFAULT_IMPLEMENTATION;
62 }
63
65
69  DTK_DEFAULT_IMPLEMENTATION;
70  return 0;
71 }
72
74
77 double axlAbstractFieldParametricSurface::scalar(double u, double v, double w)
78 {
79  if(!(this->kind() == Scalar)) {
80  qDebug() << "Getting scalar value on non scalar field.";
81  return 0;
82  }
83  return 0;
84 }
85
87
90 double *axlAbstractFieldParametricSurface::vector(double u, double v, double w)
91 {
92  if(!(this->kind() == Vector)) {
93  qDebug() << "Getting vector value on non vector field.";
94  return NULL;
95  }
96  return NULL;
97 }
98
100
103 double *axlAbstractFieldParametricSurface::tensor(double u, double v, double w)
104 {
105  if(!(this->kind() == Tensor)) {
106  qDebug() << "Getting tensor value on non tensor field.";
107  return NULL;
108  }
109
110  return NULL;
111 }
112
113
115
119
120  DTK_DEFAULT_IMPLEMENTATION;
121  return 0;
122 }
123
124
126
130
131  DTK_DEFAULT_IMPLEMENTATION;
132  return 0;
133 }
134
135 //double axlAbstractFieldParametricSurface::start_w(void){
136
137 // DTK_DEFAULT_IMPLEMENTATION;
138 // return 0;
139 //}
140
141
143
147
148  DTK_DEFAULT_IMPLEMENTATION;
149  return 0;
150 }
151
152
154
158
159  DTK_DEFAULT_IMPLEMENTATION;
160  return 0;
161 }
162
163 //double axlAbstractFieldParametricSurface::end_w(void){
164
165 // DTK_DEFAULT_IMPLEMENTATION;
166 // return 0;
167 //}
168
169
171
175
176  DTK_DEFAULT_IMPLEMENTATION;
177  return 0;
178 }
179
180
182
186
187  DTK_DEFAULT_IMPLEMENTATION;
188  return 0;
189 }
190
191 //double axlAbstractFieldParametricSurface::numbersample_w(void){
192
193 // DTK_DEFAULT_IMPLEMENTATION;
194 // return 0;
195 //}
196
197
198
200
204
205  DTK_DEFAULT_IMPLEMENTATION;
206 }
207
208
210
214  return NULL;
215 }
216
218
223 {
224  DTK_DEFAULT_IMPLEMENTATION;
225  return QString();
226
227 }
228
229
231
236 {
237  DTK_DEFAULT_IMPLEMENTATION;
238  return QString();
239
240 }
241
242 //double axlAbstractFieldParametricSurface::evalX(double u, double v , double w ){
243 // return d->value_point->eval3(u,v,w,0);
244
245 //}
246
247 //double axlAbstractFieldParametricSurface::evalY(double u, double v , double w ){
248 // return d->value_point->eval3(u,v,w,1);
249 //}
250
251 //double axlAbstractFieldParametricSurface::evalZ(double u, double v , double w ){
252 // return d->value_point->eval3(u,v,w,2);
253 //}
254
257
261 {
262  emit updated();
263 }
264
265 // /////////////////////////////////////////////////////////////////
266 // axlField documentation
267 // /////////////////////////////////////////////////////////////////
268
275 // /////////////////////////////////////////////////////////////////
276 // Type instanciation
277 // /////////////////////////////////////////////////////////////////
278
280 {
282 }
283
Class axlAbstractFieldParametric defines an API for parametric field.
virtual axlAbstractData * getFunction(void)
Returns the description of the field.
virtual double start_u(void)
Returns the first u-value parameter.
virtual int size(void)
Returns number of parameters on which the field is evaluated.
virtual double scalar(double u, double v, double w=0)
Returns the value of the parametric field at the parameters values in input.
virtual double start_v(void)
Returns the first v-value parameter.
virtual double numbersample_v(void)
Returns the number of v-parameters.
virtual void setFunction(axlAbstractData *data)
virtual double numbersample_u(void)
Returns the number of u-parameters.
virtual double * tensor(double u, double v, double w=0)
Returns the value of the spatial field at the coordinates point entered.
virtual Kind kind(void)
virtual double end_u(void)
Returns the last v-value parameter.
virtual double * vector(double u, double v, double w=0)
Returns the value of the parametric field evaluated at the parameters in input.
dtkAbstractData * createaxlAbstractFieldParametricSurface(void)
virtual double end_v(void)
virtual QString identifier(void) const
virtual QString description(void) const
Class axlAbstractFieldParametricSurface defines an API for parametric field.
virtual void setSurface(axlAbstractData *surface)
Sets the support surface of the field.
Class axlAbstractData defines an API for all type of axel data.
virtual ~axlAbstractFieldParametricSurface(void)
Destroys a parametric field.
