Developer documentation | Axl-2.5.1
axlFieldDiscreteWriter.cpp
Go to the documentation of this file.
1 /* axlFieldDiscreteWriter.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
15 #include "axlFieldDiscreteWriter.h"
16
17 #include "axlFieldDiscrete.h"
18
19 #include <dtkCoreSupport/dtkAbstractData.h>
20 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
21
22 // /////////////////////////////////////////////////////////////////
23 // axlFieldDiscreteWriter
24 // /////////////////////////////////////////////////////////////////
25
27 {
28  this->setObjectName(this->description());
29 }
30
32 {
33
34 }
35
37 {
38  return "axlFieldDiscreteWriter";
39 }
40
42 {
43  return "axlFieldDiscreteWriter";
44 }
45
46 QStringList axlFieldDiscreteWriter::handled(void) const
47 {
48  return QStringList() << "axlAbstractField" << "axlAbstractFieldDiscrete" << "axlFieldDiscrete";
49 }
50
52 {
53  return dtkAbstractDataFactory::instance()->registerDataWriterType("axlFieldDiscreteWriter", QStringList(), createaxlFieldDiscreteWriter);
54 }
55
56 bool axlFieldDiscreteWriter::accept(dtkAbstractData *data)
57 {
58  axlFieldDiscrete *spatialField = dynamic_cast<axlFieldDiscrete *>(data);
59  if(spatialField)
60  return true;
61
62  return false;
63 }
64
65 bool axlFieldDiscreteWriter::reject(dtkAbstractData *data)
66 {
67  return !this->accept(data);
68 }
69
70 QDomElement axlFieldDiscreteWriter::write(QDomDocument *doc, dtkAbstractData *data)
71 {
72  axlFieldDiscrete *field = dynamic_cast<axlFieldDiscrete *>(data);
73
74  QDomElement fieldElement = doc->createElement("field");
75
77  fieldElement.setAttribute("type", field->identifier());
78
80  fieldElement.setAttribute("count", QString::number(field->size()));
81
83  if(field->kind() == axlFieldDiscrete::Scalar){
84  fieldElement.setAttribute("dimension", QString::number(1));
85  }else if(field->kind() == axlFieldDiscrete::Vector){
86  fieldElement.setAttribute("dimension", QString::number(3));
87  }else{
88  fieldElement.setAttribute("dimension", QString::number(9));
89  }
90
92  if(field->support() == axlFieldDiscrete::Point){
93  fieldElement.setAttribute("support", "point");
94  }else if(field->support() == axlFieldDiscrete::Cell){
95  fieldElement.setAttribute("support", "cell");
96  }else{
97  fieldElement.setAttribute("support", "custom");
98  }
99
101  QString fieldsText;
102  if(field->kind() == axlFieldDiscrete::Scalar)
103  for(int i = 0 ; i < field->size(); i++)
104  QTextStream(&fieldsText) << "\n " << QString::number(field->scalar(i));
105  else if(field->kind() == axlFieldDiscrete::Vector)
106  for(int i = 0 ; i < field->size(); i++)
107  QTextStream(&fieldsText) << "\n " << QString::number((field->vector(i))[0]) << " "<< QString::number((field->vector(i))[1]) << " "<< QString::number((field->vector(i))[2]);
108  else if(field->kind() == axlFieldDiscrete::Tensor)
109  for(int i = 0 ; i < field->size(); i++)
110  QTextStream(&fieldsText) << "\n " << QString::number((field->tensor(i))[0]) << " "<< QString::number((field->tensor(i))[1]) << " "<< QString::number((field->tensor(i))[2])<< " "<< QString::number((field->tensor(i))[3])<< " "<< QString::number((field->tensor(i))[4])<< " "<< QString::number((field->tensor(i))[5])<< " "<< QString::number((field->tensor(i))[6])<< " "<< QString::number((field->tensor(i))[7])<< " "<< QString::number((field->tensor(i))[8]);
111
112
113
114  QTextStream(&fieldsText)<< "\n"; // for easy read of the file
115  QDomText fieldsDomText = doc->createTextNode(fieldsText);
116  fieldElement.appendChild(fieldsDomText);
117
118  return fieldElement;
119 }
120
121
122
123 QDomElement axlFieldDiscreteWriter::elementByWriter(axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data)
124 {
125  QDomElement element;
126
127  if(!axl_writer)
128  return element;
129
130  if(!axl_writer->accept(data))
131  return element;
132
133  element = axl_writer->write(doc, data);
134
135  return element;
136 }
137
138 dtkAbstractDataWriter *createaxlFieldDiscreteWriter(void)
139 {
140  return new axlFieldDiscreteWriter;
141 }
142
dtkAbstractDataWriter * createaxlFieldDiscreteWriter(void)
virtual bool accept(dtkAbstractData *data)=0
QString identifier(void) const
virtual int size(void)
bool reject(dtkAbstractData *data)
Returns the identifier "axlFieldDiscrete".
virtual Kind kind(void)
virtual Support support(void)
Class axlFieldDiscrete defines an API for arrays of numeric data.
virtual double scalar(int index)
Returns the value at index location of the scalar array.
QStringList handled(void) const
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
QString description(void) const
virtual double * vector(int index)
Returns the value at index location of the vector array.
virtual double * tensor(int index)
Returns the value at index location of the tensor array.
