Developer documentation | Axl-2.5.1
axlFieldParametricCurveTangentVectorCreator.cpp
Go to the documentation of this file.
1 /* axlFieldParametricCurveTangentVectorCreator.cpp---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
16
21
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
24 #include <dtkCoreSupport/dtkGlobal.h>
25 #include <QtGui>
26
27 class axlFieldParametricCurveTangentVectorCreatorPrivate
28 {
29 public:
31 };
32
34 {
35  d->input = NULL;
36
37 }
38
40 {
41  delete d;
42
43  d = NULL;
44 }
45
46
47 void axlFieldParametricCurveTangentVectorCreator::setInput(dtkAbstractData *data, int channel)
48 {
49  if(axlAbstractCurveParametric *surface = dynamic_cast<axlAbstractCurveParametric *>(data))
50  d->input = surface;
51
52 }
53
54
56 {
57
58  if(!d->input)
59  return 0;
60
62
63  QString newName = d->input->changeFieldName(field->objectName());
64  field->setObjectName(newName);
65  d->input->addField(field);
66  field->setCurve(d->input);
67
68
69  QList<axlAbstractData *>list;
70  list << d->input;
71  emit dataSetFieldsChanged(list, field->objectName());
72
73  return 1;
74
75 }
76
77
79 {
80  return 0;
81 }
82
83
85 {
86  return "axlFieldParametricCurveTangentVectorCreator created fields for input tha compute the normal vector in each parameter coordinates of the input support.";
87 }
88
90 {
91  return "axlFieldParametricCurveTangentVectorCreator";
92 }
93
94 // /////////////////////////////////////////////////////////////////
95 // Type instanciation
96 // /////////////////////////////////////////////////////////////////
97
99 {
101 }
102
103
void setCurve(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
Generic interface for parametric curve.
dtkAbstractProcess * createaxlFieldParametricCurveTangentVectorCreator(void)
void dataSetFieldsChanged(QList< axlAbstractData * > dataSet, QString fieldName)
Class axlFieldParametricCurveTangentVector defines an API for field which owns a BSpline Surface as a...
