Developer documentation | Axl-2.5.1
axlFieldParametricVolume.cpp
Go to the documentation of this file.
1 /* axlFieldParametricVolume.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14 #include <sstream>
15
17 #include "axlAbstractProcess.h"
18
19 #include <dtkCoreSupport/dtkGlobal.h>
20
21 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
22 #include <dtkCoreSupport/dtkAbstractProcessFactory.h>
23
26
27 class axlFieldParametricVolumePrivate
28 {
29 public:
33
36 };
37
38 // /////////////////////////////////////////////////////////////////
39 // axlFieldParametricVolume implementation
40 // /////////////////////////////////////////////////////////////////
41
43
47 {
48  d->input = NULL;
49  d->function = NULL;
50  this->setObjectName(this->identifier());
51 }
52
53
54
56
60 {
61  delete d;
62
63  d = NULL;
64 }
65
66
67
70 // *
71 // */
72 //void axlFieldParametricVolume::setType(axlFieldParametricVolume::Type type)
73 //{
74
75 // d->type = type;
76 //}
77
80 // *
81 // */
82 //void axlFieldParametricVolume::setKind(axlFieldParametricVolume::Kind kind)
83 //{
84
85 // d->kind = kind;
86 //}
87
90 // *
91 // */
92 //void axlFieldParametricVolume::setSupport(axlFieldParametricVolume::Support support)
93 //{
94 // d->support = support;
95 //}
96
97
98 //axlFieldParametricVolume::Type axlFieldParametricVolume::type(void)
99 //{
100 // return d->type;
101 //}
102
103 //axlFieldParametricVolume::Kind axlFieldParametricVolume::kind(void)
104 //{
105 // return d->kind;
106 //}
107
108 //axlFieldParametricVolume::Support axlFieldParametricVolume::support(void)
109 //{
110 // return d->support;
111 //}
112
114
117 double axlFieldParametricVolume::scalar(double u, double v , double w)
118 {
119 // if(!(this->kind() == Scalar)) {
120 // qDebug() << "Getting scalar value on non scalar field.";
121 // return 0;
122 // }
123  return d->function->eval(u,v,w).x();
124
125
126
127 }
128
130
133 double *axlFieldParametricVolume::vector(double u, double v, double w)
134 {
135 // if(!(this->kind() == Vector)) {
136 // qDebug() << "Getting vector value on non vector field.";
137 // return NULL;
138 // }
139  return d->function->eval(u,v,w).coordinates();
140
141 }
142
144
147 double *axlFieldParametricVolume::tensor(double u, double v, double w)
148 {
149 // if(!(this->kind() == Tensor)) {
150 // qDebug() << "Getting tensor value on non tensor field.";
151 // return NULL;
152 // }
153
154  //TO DO
155  return NULL;
156 }
157
160 // *
161 // */
162 //QString axlFieldParametricVolume::name(void)
163 //{
164 // return this->objectName() ;
165 //}
166
169 // *
170 // */
171 //void axlFieldParametricVolume::setName(QString name)
172 //{
173 // this->setObjectName(name);
174
175 //}
176
178
182 {
183  QString qstr;
184
185  qstr.append("axlFieldParametricVolume : \n");
186
187
188  switch(d->type){
190  qstr.append("Type : integer");
191  break;
193  qstr.append("Type : Float");
194  break;
196  qstr.append("Type : Double");
197  break;
198  default:
199  qDebug() << "Unsupported field type";
200  }
201
202
203  switch(d->kind) {
205  qstr.append(";Kind : Scalar");
206  break;
208  qstr.append(";Kind : Vector");
209  break;
211  qstr.append(";Kind : Tensor");
212  break;
213  default:
214  qDebug() << ";Unsupported field kind";
215  }
216
217  switch(d->support) {
219  qstr.append(";Support : Point");
220  break;
222  qstr.append(";Support : Cell");
223  break;
225  qstr.append(";Support : Custom");
226  break;
227  default:
228  qDebug() << ";No support";
229  }
230
231  return qstr;
232
233 }
234
235
237
241 {
242
243  return "axlFieldParametricVolume";
244 }
245
247
251  if(dynamic_cast<axlAbstractVolumeParametric*>(data))
252  d->function = dynamic_cast<axlAbstractVolumeParametric*>(data);
253 }
254
256
260  return d->function;
261 }
262
264
268  if(dynamic_cast<axlAbstractVolumeParametric *>(data))
269  d->input = dynamic_cast<axlAbstractVolumeParametric *>(data);
270 }
271
272
274
278
279  return d->input->startParam_u();
280
281 }
282
283
285
289  return d->input->startParam_v();
290 }
291
292
294
298  return d->input->startParam_w();
299 }
300
301
303
307
308  return d->input->endParam_u();
309 }
310
311
313
317
318  return d->input->endParam_v();
319 }
320
321
323
327
328  return d->input->endParam_w();
329 }
330
331
333
337
338  return d->input->numSamples_u();
339 }
340
342
346  return d->input->numSamples_v();
347 }
348
349
351
355  return d->input->numSamples_w();
356 }
357
358
360
364  return d->input->numSamples_u() *d->input->numSamples_v() *d->input->numSamples_w();
365 }
366
367
368
371
375 {
376  emit updated();
377 }
378
379 // /////////////////////////////////////////////////////////////////
380 // axlFieldBSpline documentation
381 // /////////////////////////////////////////////////////////////////
382
389 // /////////////////////////////////////////////////////////////////
390 // Type instanciation
391 // /////////////////////////////////////////////////////////////////
392
393 dtkAbstractData *createaxlFieldParametricVolume(void)
394 {
395  return new axlFieldParametricVolume();
396 }
397
398
double start_v(void)
Returns the first parameter value of the field.
virtual double * vector(double u, double v, double w)
Returns the value of the spatial field at the coordinates point entered.
void setVolume(axlAbstractData *data)
Sets the BSpline on which the BSpline field is applied.
virtual QString identifier(void) const
Returns the identifier of the field "axlFieldParametricVolume".
double start_w(void)
void setFunction(axlAbstractData *data)
Sets the Bspline function which determines the values of the parametric field.
double end_u(void)
Returns the last parameter value of the field.
double end_w(void)
dtkAbstractData * createaxlFieldParametricVolume(void)
Class axlAbstractFieldParametricVolume defines an API for parametric field.
double numbersample_w(void)
Returns the number of parameters.
virtual double * tensor(double u, double v, double w)
double start_u(void)
double end_v(void)
virtual ~axlFieldParametricVolume(void)
Destroys a Bspline field.
double numbersample_u(void)
double numbersample_v(void)
Class axlFieldParametricVolume defines an API for field which owns a BSpline Volume.
axlAbstractData * getFunction(void)
Returns the Bspline function which determines the values of the parametric field. ...
Class axlAbstractData defines an API for all type of axel data.
virtual double scalar(double u, double v, double w)
virtual QString description(void) const
Returns the description of the field.
int size(void)
Returns the number of values evaluated for this BSpline field on each samples of the input BSpline...
