Developer documentation | Axl-2.5.1
axlFieldSpatialCoordinatesWriter.cpp
Go to the documentation of this file.
1 /* axlFieldSpatialCoordinatesWriter.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
16
18
19 #include <dtkCoreSupport/dtkAbstractData.h>
20 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
21
22 // /////////////////////////////////////////////////////////////////
23 // axlFieldSpatialCoordinatesWriter
24 // /////////////////////////////////////////////////////////////////
25
27 {
28  this->setObjectName(this->description());
29 }
30
32 {
33
34 }
35
37 {
38  return "axlFieldSpatialCoordinatesWriter";
39 }
40
42 {
43  return "axlFieldSpatialCoordinatesWriter";
44 }
45
47 {
48  return QStringList() << "axlAbstractField" << "axlAbstractFieldSpatial" << "axlFieldSpatialCoordinates";
49 }
50
52 {
53  return dtkAbstractDataFactory::instance()->registerDataWriterType("axlFieldSpatialCoordinatesWriter", QStringList(), createaxlFieldSpatialCoordinatesWriter);
54 }
55
56 bool axlFieldSpatialCoordinatesWriter::accept(dtkAbstractData *data)
57 {
58  axlFieldSpatialCoordinates *spatialField = dynamic_cast<axlFieldSpatialCoordinates *>(data);
59  if(spatialField)
60  return true;
61
62  return false;
63 }
64
65 bool axlFieldSpatialCoordinatesWriter::reject(dtkAbstractData *data)
66 {
67  return !this->accept(data);
68 }
69
70 QDomElement axlFieldSpatialCoordinatesWriter::write(QDomDocument *doc, dtkAbstractData *data)
71 {
72  axlFieldSpatialCoordinates *field = dynamic_cast<axlFieldSpatialCoordinates *>(data);
73
74  QDomElement fieldElement = doc->createElement("field");
75
77  fieldElement.setAttribute("type", field->identifier());
78
80  for(int i = 0; i < 3;i++){
81
82  QDomElement parameter = doc->createElement("parameter");
83  parameter.setAttribute("value", QString::number(field->parameter(i)));
84  parameter.setAttribute("channel", QString::number(i));
85  parameter.setAttribute("type", "double");
86  fieldElement.appendChild(parameter);
87
88  }
89
90  return fieldElement;
91 }
92
93
94
95 QDomElement axlFieldSpatialCoordinatesWriter::elementByWriter(axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data)
96 {
97  QDomElement element;
98
99  if(!axl_writer)
100  return element;
101
102  if(!axl_writer->accept(data))
103  return element;
104
105  element = axl_writer->write(doc, data);
106
107  return element;
108 }
109
110 dtkAbstractDataWriter *createaxlFieldSpatialCoordinatesWriter(void)
111 {
113 }
114
115
virtual bool accept(dtkAbstractData *data)=0
Class axlFieldSpatialCoordinates defines an API for spatial field. The value are computed as follow :...
QString identifier(void) const
Returns the identifier of the field which is "axlFieldSpatialCoordinates".
double parameter(int channel)
Returns the channel-th parameter value.
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
dtkAbstractDataWriter * createaxlFieldSpatialCoordinatesWriter(void)
