Developer documentation | Axl-2.5.1
axlFieldSpatialWriter.cpp
Go to the documentation of this file.
1 /* axlFieldSpatialWriter.cpp ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C) 2013 - Anais Ducoffe, Inria.
5  */
6
7 /* Commentary:
8  *
9  */
10
11 /* Change log:
12  *
13  */
14
15 #include "axlFieldSpatialWriter.h"
16
17 #include <axlCore/axlDouble.h>
22
23 #include <dtkCoreSupport/dtkAbstractData.h>
24
26 #include <dtkCoreSupport/dtkAbstractDataFactory.h>
27
28 // /////////////////////////////////////////////////////////////////
29 // axlFieldSpatialWriter
30 // /////////////////////////////////////////////////////////////////
31
33 {
34  this->setObjectName(this->description());
35 }
36
38 {
39
40 }
41
43 {
44  return "axlFieldSpatialWriter";
45 }
46
48 {
49  return "axlFieldSpatialWriter";
50 }
51
52 QStringList axlFieldSpatialWriter::handled(void) const
53 {
54  return QStringList() << "axlAbstractField";
55 }
56
58 {
59  return dtkAbstractDataFactory::instance()->registerDataWriterType("axlFieldSpatialWriter", QStringList(), createaxlFieldSpatialWriter);
60 }
61
62 bool axlFieldSpatialWriter::accept(dtkAbstractData *data)
63 {
64  axlAbstractField *spatialField = dynamic_cast<axlAbstractField *>(data);
65  if(spatialField)
66  return true;
67
68  return false;
69 }
70
71 bool axlFieldSpatialWriter::reject(dtkAbstractData *data)
72 {
73  return !this->accept(data);
74 }
75
76 QDomElement axlFieldSpatialWriter::write(QDomDocument *doc, dtkAbstractData *data)
77 {
78  axlAbstractField *field = dynamic_cast<axlAbstractField *>(data);
79
80  QDomElement fieldElement = doc->createElement("field");
81  //Three kind of field : discrete, spatial and parametric.
82  if(dynamic_cast<axlAbstractFieldSpatial *>(field))
83  fieldElement.setAttribute("type", "spatial");
84  else if(dynamic_cast<axlAbstractFieldParametric *>(field))
85  fieldElement.setAttribute("type", "parametric");
86  else
87  fieldElement.setAttribute("type", "discrete");
88
90  fieldElement.setAttribute("name", field->name());
91
92
93
94  //Support
95  int fieldSupport= field->support();
96  if(fieldSupport == 1)
97  fieldElement.setAttribute("support", "point");
98  else if (fieldSupport == 2)
99  fieldElement.setAttribute("support", "cell");
100  else
101  fieldElement.setAttribute("support", "custom");
102
103  //Kind
104  int fieldKind= field->kind();
105  if(fieldKind == 1)
106  fieldElement.setAttribute("kind", "scalar");
107  else if (fieldKind == 2)
108  fieldElement.setAttribute("kind", "vector");
109  else
110  fieldElement.setAttribute("kind", "tensor");
111
112  //Type
113  int fieldType= field->type();
114  if(fieldType == 1)
115  fieldElement.setAttribute("type", "int");
116  else if (fieldType == 2)
117  fieldElement.setAttribute("type", "float");
118  else
119  fieldElement.setAttribute("type", "double");
120
121
122  //not necessary to write field value except if it is of type field discrete
123  int size = field->size();
124  QString fieldsText;
125  if(axlAbstractFieldDiscrete *fieldD = dynamic_cast<axlAbstractFieldDiscrete *>(field) ){
126
127  if(fieldKind == 1)
128  for(int i = 0 ; i < size; i++)
129  QTextStream(&fieldsText) << "\n" << QString::number(fieldD->scalar(i));
130  else if(fieldKind == 2)
131  for(int i = 0 ; i < size; i++)
132  QTextStream(&fieldsText) << "\n" << QString::number((fieldD->vector(i))[0]) << " "<< QString::number((fieldD->vector(i))[1]) << " "<< QString::number((fieldD->vector(i))[2]);
133
134  }
135  QDomText fieldsDomText = doc->createTextNode(fieldsText);
136  fieldElement.appendChild(fieldsDomText);
137
138  //precise the object name on which the field is applied. (its parent )
139  fieldElement.setAttribute("parent", dynamic_cast<axlAbstractData *>(field->parent())->name());
140
141  //if parametric field , we need to know the fonction
142  //problem : the BSpline function is not inserted in the object manager.
143  if(axlAbstractFieldParametric *paramField = dynamic_cast<axlAbstractFieldParametric *>(field)){
144  //fieldElement.setAttribute("fonctionBSpline", paramField->getFunctionBSpline()->objectName());
145
146  //TO DO
147  }
148
149  //if the field has some parameters.
150  // TO DO
151  int res = dynamic_cast<QMetaObject *>(field)->indexOfMethod("setParameter");
152  fieldElement.setAttribute("res",QString::number(res));
153  if(res == -1)
154  qDebug()<< "no parameter values to write";
155  else{
156  //we must know the number of parameters.
157  int arg_count = 0;
158  }
159
160  return fieldElement;
161 }
162
163
164
165 QDomElement axlFieldSpatialWriter::elementByWriter(axlAbstractDataWriter *axl_writer, QDomDocument *doc, dtkAbstractData *data)
166 {
167  QDomElement element;
168
169  if(!axl_writer)
170  return element;
171
172  if(!axl_writer->accept(data))
173  return element;
174
175  element = axl_writer->write(doc, data);
176
177  return element;
178 }
179
180 dtkAbstractDataWriter *createaxlFieldSpatialWriter(void)
181 {
182  return new axlFieldSpatialWriter;
183 }
184
185
QStringList handled(void) const
Class axlAbstractFieldParametric defines an API for parametric field.
virtual bool accept(dtkAbstractData *data)=0
QDomElement write(QDomDocument *doc, dtkAbstractData *data)
QString identifier(void) const
Class axlAbstractFieldDiscrete defines an API for arrays of numeric data.
virtual Kind kind(void)
QString description(void) const
virtual Support support(void)
Class axlAbstractField defines an API for arrays of numeric data.
dtkAbstractDataWriter * createaxlFieldSpatialWriter(void)
virtual Type type(void)
virtual QDomElement write(QDomDocument *doc, dtkAbstractData *data)=0
bool reject(dtkAbstractData *data)
