25 #include <dtkGuiSupport/dtkColorButton.h>
   26 #include <dtkGuiSupport/dtkSplitter.h>
   30 class axlInspectorObjectSurfaceParametricOffsetPrivate
   35     QDoubleSpinBox *offset;
   40     dtkColorButton *colorButton;
   41     QComboBox *comboBoxShader;
   43     QCheckBox *checkBoxShader;
   44     QLineEdit *lineEditShader;
   45     QPushButton *buttonShader;
   47     QSlider *sliderOpacity;
   56     d->colorButton = NULL;
   57     d->comboBoxShader = NULL;
   59     d->checkBoxShader = NULL;
   60     d->lineEditShader = NULL;
   61     d->buttonShader = NULL;
   63     d->sliderOpacity = NULL;
   75     return QSize(300, 300);
   84 void axlInspectorObjectSurfaceParametricOffset::initWidget()
   86     QVBoxLayout *layoutTop =
new QVBoxLayout(
this);
   87     layoutTop->addWidget(
new QLabel(
"axlInspectorObjectSurfaceParametricOffset",
this));
   91     d->offset =
new QDoubleSpinBox(
this);
   92     d->offset->setRange(-1000, 1000);
   93     d->offset->setValue(d->surface->offset());
   94     d->offset->setSingleStep(0.1);
   96     QHBoxLayout *layoutoffset =
new QHBoxLayout;
   97     layoutoffset->addWidget(
new QLabel(
"offset",
this));
   98     layoutoffset->addWidget(d->offset);
  103     d->sliderSize =
new QSlider(Qt::Horizontal,
this);
  105     QHBoxLayout *layoutSize =
new QHBoxLayout;
  106     layoutSize->addWidget(
new QLabel(
"Size",
this));
  107     layoutSize->addWidget(d->sliderSize);
  108     d->sliderSize->setMinimum(-800);
  109     d->sliderSize->setMaximum(500);
  110     d->sliderSize->setValue(initSizeValue());
  114     d->colorButton =
new dtkColorButton(
this);
  116     QHBoxLayout *layoutColorButton =
new QHBoxLayout;
  117     layoutColorButton->addWidget(
new QLabel(
"Color",
this));
  118     layoutColorButton->addWidget(d->colorButton);
  119     d->colorButton->setColor(this->initColorValue());
  123     d->sliderOpacity =
this);
  125     QHBoxLayout *layoutOpacity =
new QHBoxLayout;
  126     layoutOpacity->addWidget(
new QLabel(
"Opacity",
this));
  127     layoutOpacity->addWidget(d->sliderOpacity);
  128     d->sliderOpacity->setMaximum(100);
  129     d->sliderOpacity->setValue(initOpacityValue());
  132     d->comboBoxShader =
new QComboBox(
this);
  133     d->comboBoxShader->setInsertPolicy(QComboBox::InsertAlphabetically);
  135     d->checkBoxShader =
new QCheckBox(
this);
  136     d->lineEditShader =
new QLineEdit(
this);
  137     d->buttonShader =
new QPushButton(
this);
  138     d->buttonShader->setText(
"open");
  140     d->lineEditShader->setText(this->initShaderValue());
  141     this->initComboBoxShaderValue();
  143     if(d->lineEditShader->text().isEmpty())
  145         d->lineEditShader->setEnabled(
false);
  146         d->buttonShader->setEnabled(
false);
  147         d->comboBoxShader->setEnabled(
false);
  150         d->checkBoxShader->setChecked(
true);
  155     QVBoxLayout *layoutShader =
new QVBoxLayout;
  156     QHBoxLayout *layoutShader1 =
new QHBoxLayout;
  158     QLabel *labelShader  =
new QLabel(
"Shader",
this);
  159     layoutShader1->addWidget(labelShader);
  160     layoutShader1->addWidget(d->checkBoxShader);
  161     layoutShader1->addWidget(d->comboBoxShader);
  162     layoutShader1->addWidget(d->buttonShader);
  164     layoutShader1->setStretchFactor(labelShader, 2);
  165     layoutShader1->setStretchFactor(d->checkBoxShader, 1);
  166     layoutShader1->setStretchFactor(d->comboBoxShader, 4);
  167     layoutShader1->setStretchFactor(d->buttonShader, 3);
  169     layoutShader->addLayout(layoutShader1);
  170     layoutShader->addWidget(d->lineEditShader);
  172     layoutTop->addLayout(layoutoffset);
  173     layoutTop->addWidget(
new QLabel(d->surface->surfaceParam()->description(),
this));
  176     layoutTop->addLayout(layoutSize);
  178     layoutTop->addLayout(layoutColorButton);
  179     layoutTop->addLayout(layoutOpacity);
  180     layoutTop->addLayout(layoutShader);
  182     QWidget *top =
new QWidget(
this);
  183     top->setMaximumWidth(295);
  185     top->setLayout(layoutTop);
  197     connect(d->offset, SIGNAL(valueChanged(
double)),
this, SLOT(
onOffsetChanged(
double)));
  199     connect(d->sliderSize, SIGNAL(valueChanged(
int)),
this, SLOT(
onSizeChanged(
int)));
  204     connect(d->sliderOpacity, SIGNAL(valueChanged(
int)),
this, SLOT(
onOpacityChanged(
int)));
  205     connect(d->comboBoxShader, SIGNAL(currentIndexChanged(QString)),
this, SLOT(
onLineEditShaderChanged(QString)));
  207     connect(d->buttonShader, SIGNAL(clicked()),
this, SLOT(
openShader()));
  208     connect(d->lineEditShader, SIGNAL(textChanged(QString)),
this, SLOT(
onShaderChanged(QString)));
  213 int axlInspectorObjectSurfaceParametricOffset::initSizeValue(
void)
  215     double initSize =  100.0*(log(d->surface->size()/0.125))/log(2.0);
  224 void axlInspectorObjectSurfaceParametricOffset::initComboBoxShaderValue(
void)
  226     if(d->comboBoxShader)
  229         QDir dirShader(
":axlShader/shader/");
  230         dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
  232         QFileInfoList list = dirShader.entryInfoList();
  237         QSettings settings(
"inria",
"dtk");
  239         settings.beginGroup(
"shader");
  240         QString defaultPathShader = settings.value(
"path", defaultPath).toString();
  241         defaultPathShader.append(
  243         QDir defaultDirShader(defaultPathShader);
  246         defaultDirShader.setNameFilters(filters);
  247         QFileInfoList list2 = defaultDirShader.entryInfoList();
  253         for (
int i = 0; i < list.size(); ++i) {
  254             if(!items.contains(list.at(i).fileName()))
  255                 items << list.at(i).fileName();
  259         int indInitShader = -1;
  260         int indCurrentShader = -1;
  263         foreach(QString item, items)
  266             d->comboBoxShader->addItem(item);
  268             QFileInfo currentFileInfo(d->lineEditShader->text());
  270             if(currentFileInfo.exists())
  272                 if(item == currentFileInfo.fileName())
  273                     indInitShader =indCurrentShader;
  278         if(indInitShader != -1)
  279             d->comboBoxShader->setCurrentIndex(indInitShader);
  287     QDir dirShader(
  288     dirShader.setFilter(QDir::Files | QDir::Hidden | QDir::NoSymLinks);
  290     QFileInfo currentFile(dirShader, shader);
  291     if(!currentFile.exists())
  293         QSettings settings(
"inria",
"dtk");
  295         settings.beginGroup(
"shader");
  296         QString defaultPathShader = settings.value(
  297         defaultPathShader.append(
  299         QDir defaultDirShader(defaultPathShader);
  300         currentFile = QFileInfo(defaultDirShader, shader);
  304     d->lineEditShader->setText(currentFile.absoluteFilePath());
  307 QString axlInspectorObjectSurfaceParametricOffset::initShaderValue(
void)
  309     return  d->surface->shader();
  313 QColor axlInspectorObjectSurfaceParametricOffset::initColorValue(
void)
  315     return d->surface->color();
  319 int axlInspectorObjectSurfaceParametricOffset::initOpacityValue(
void)
  321     double initOpacity = 0.0;
  322     double opacity = d->surface->opacity();
  323     if(opacity > initOpacity)
  324         initOpacity = opacity;
  326     return 100 * (1.0 - initOpacity);
  331     if(d->lineEditShader->isEnabled())
  334         fileToOpen = QFileDialog::getOpenFileName(
this, tr(
"Open shader"),
"", tr(
"xml document (*.xml)"));
  335         d->lineEditShader->setText(fileToOpen);
  341     d->surface->setShader(shader);
  352         d->comboBoxShader->setEnabled(
true);
  353         d->lineEditShader->setEnabled(
true);
  354         d->buttonShader->setEnabled(
true);
  361         d->comboBoxShader->setEnabled(
false);
  362         d->lineEditShader->setEnabled(
false);
  363         d->buttonShader->setEnabled(
false);
  373     d->surface->setOffset(offset);
  382     QVariant variant = d->surface->QObject::property(
"color");
  383     if(variant.isValid())
  385         d->surface->setColor(color);
  396     double size_d = pow(2.0, size/100.0 - 3.0);
  398     QVariant variant = d->surface->QObject::property(
"size");
  399     if(variant.isValid())
  401         d->surface->setSize(size_d);
  411     double opacity_d = 1.0 - 0.01 * opacity;
  413     QVariant variant = d->surface->QObject::property(
"opacity");
  414     if(variant.isValid())
  416         d->surface->setOpacity(opacity_d);
void onShaderStateChanged(bool isShader)
bool caseInsensitiveLessThan(const QString &s1, const QString &s2)
void onSizeChanged(int size)
void onLineEditShaderChanged(QString)
void dataChangedByGeometry(dtkAbstractData *data)
axlInspectorObjectSurfaceParametricOffset(QWidget *parent=0)
void dataChangedByOpacity(dtkAbstractData *data, double opacity)
~axlInspectorObjectSurfaceParametricOffset(void)
QSize sizeHint(void) const
Class axlSurfaceParametricOffset defines offset of axlAbstractSurfaceParametric.
void colorChanged(QColor color, dtkAbstractData *data)
void setData(axlSurfaceParametricOffset *surface)
void dataChangedByShader(dtkAbstractData *data, QString isophoteShaderXml)
void onOpacityChanged(int opacity)
void onShaderChanged(QString)
void onColorChanged(QColor color)
void onOffsetChanged(double offset)
void dataChangedByColor(dtkAbstractData *data, double red, double green, double blue)
