| addField(axlAbstractField *field) | axlAbstractData | |
| area(double tol) | axlAbstractSurfaceParametric | virtual |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlAbstractSurface(void) | axlAbstractSurface | |
| axlAbstractSurfaceBSpline(void) | axlAbstractSurfaceBSpline | |
| axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| connectionsAreDefined(void) | axlAbstractSurfaceBSpline | virtual |
| convertDataToQVariant(void) const | axlAbstractSurfaceBSpline | virtual |
| convertQVariantToData(const QVariantList &data) | axlAbstractSurfaceBSpline | virtual |
| copy(void) const | axlAbstractSurfaceBSpline | virtual |
| countCells(void) | axlAbstractSurfaceParametric | virtual |
| countControlPoints(void) const | axlAbstractSurfaceBSpline | virtual |
| countControlPoints_u(void) const | axlAbstractSurfaceBSpline | virtual |
| countControlPoints_v(void) const | axlAbstractSurfaceBSpline | virtual |
| defineControlPointConnection(int i, int j) | axlAbstractSurfaceBSpline | virtual |
| description(void) const | axlAbstractSurfaceBSpline | virtual |
| dimension(void) const | axlAbstractSurface | virtual |
| edgeSelected(int numEdge, int previous, int n) | axlAbstractSurfaceBSpline | signal |
| editable(void) | axlAbstractData | |
| endParam_u(void) | axlAbstractSurfaceParametric | virtual |
| endParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| endParam_v(void) | axlAbstractSurfaceParametric | virtual |
| endParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| eval(double u, double v) | axlAbstractSurfaceParametric | virtual |
| eval(axlPoint *point, double u, double v) | axlAbstractSurfaceParametric | virtual |
| eval(double &, double &, double &, double u, double v) | axlAbstractSurfaceParametric | virtual |
| eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) | axlAbstractSurfaceParametric | virtual |
| eval(axlPoint *point, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
| eval2(double u, double v) | axlAbstractSurfaceParametric | virtual |
| fields(void) | axlAbstractData | |
| getCoef(int n, int m) const | axlAbstractSurfaceBSpline | virtual |
| getCoef(int n) const | axlAbstractSurfaceBSpline | virtual |
| getControlPointConnection(int i) | axlAbstractSurfaceBSpline | virtual |
| getCoord(int n, int m, int v) const | axlAbstractSurfaceBSpline | virtual |
| getKnot_u(int n) const | axlAbstractSurfaceBSpline | virtual |
| getKnot_v(int n) const | axlAbstractSurfaceBSpline | virtual |
| getWeight(int n, int m) const | axlAbstractSurfaceBSpline | virtual |
| gridEvaluator(int num_u, int num_v, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v) | axlAbstractSurfaceBSpline | virtual |
| hasCells(void) | axlAbstractSurfaceParametric | virtual |
| indexSelected(int i) | axlAbstractSurfaceBSpline | signal |
| insertKnot_u(double k) | axlAbstractSurfaceBSpline | virtual |
| insertKnot_v(double k) | axlAbstractSurfaceBSpline | virtual |
| knotVectorSize_u(void) const | axlAbstractSurfaceBSpline | virtual |
| knotVectorSize_v(void) const | axlAbstractSurfaceBSpline | virtual |
| mesh(void) | axlAbstractData | |
| modifiedControlPoints(void) | axlAbstractSurfaceBSpline | signal |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| normal(axlPoint *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
| normal(axlPoint *normal, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
| numSamples_u(void) | axlAbstractSurfaceParametric | virtual |
| numSamples_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| numSamples_v(void) | axlAbstractSurfaceParametric | virtual |
| numSamples_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| order_u(void) const | axlAbstractSurfaceBSpline | virtual |
| order_v(void) const | axlAbstractSurfaceBSpline | virtual |
| parameterOf(const axlPoint &point, double &um, double &vm) | axlAbstractSurfaceParametric | virtual |
| printCoeffs(bool print) const | axlAbstractSurfaceBSpline | virtual |
| printKnotsVector(bool print) const | axlAbstractSurfaceBSpline | virtual |
| rational(void) const | axlAbstractSurfaceBSpline | virtual |
| removeKnot_u(double k) | axlAbstractSurfaceBSpline | virtual |
| removeKnot_v(double k) | axlAbstractSurfaceBSpline | virtual |
| resetControlPointConnections(void) | axlAbstractSurfaceBSpline | virtual |
| samples_u | axlAbstractSurfaceParametric | |
| samples_u(void) const | axlAbstractSurfaceParametric | |
| samples_v | axlAbstractSurfaceParametric | |
| samples_v(void) const | axlAbstractSurfaceParametric | |
| sampling() | axlAbstractSurfaceBSpline | virtual |
| samplingChanged(void) | axlAbstractSurfaceBSpline | signal |
| scalarValue(double u, double v) | axlAbstractSurfaceBSpline | |
| selectIndex(int i) | axlAbstractSurfaceBSpline | inlinevirtual |
| setCoef(int n, int m, int v, double c) | axlAbstractSurfaceBSpline | virtual |
| setCoef(int n, int m, double *controlPoint) | axlAbstractSurfaceBSpline | virtual |
| setCoef(int n, double *controlPoint) | axlAbstractSurfaceBSpline | virtual |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setNumSamples_u(int numSamples) | axlAbstractSurfaceParametric | virtual |
| setNumSamples_v(int numSamples) | axlAbstractSurfaceParametric | virtual |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setSamples_u(const int &color) | axlAbstractSurfaceParametric | slot |
| setSamples_v(const int &color) | axlAbstractSurfaceParametric | slot |
| setScalarValue(double u, double v, double value) | axlAbstractSurfaceBSpline | |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setStripes(int stripes) | axlAbstractSurfaceParametric | virtual |
| setSurface(int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational) | axlAbstractSurfaceBSpline | virtual |
| setUpdateView(bool updateView) | axlAbstractData | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| startParam_u(void) | axlAbstractSurfaceParametric | virtual |
| startParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
| startParam_v(void) | axlAbstractSurfaceParametric | virtual |
| startParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
| stripes(void) | axlAbstractSurfaceParametric | virtual |
| surface(void) | axlAbstractSurface | virtual |
| toAxlMesh(void) | axlAbstractSurface | virtual |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchStructure(void) | axlAbstractData | slot |
| updated(void) | axlAbstractSurfaceBSpline | signal |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateRcoeff() | axlAbstractSurfaceBSpline | virtual |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlAbstractSurface(void) | axlAbstractSurface | virtual |
| ~axlAbstractSurfaceBSpline(void) | axlAbstractSurfaceBSpline | virtual |
| ~axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | virtual |
