#include <axlAbstractSurfaceBSpline.h>
Signals | |
| void | updated (void) |
| void | samplingChanged (void) |
| void | edgeSelected (int numEdge, int previous, int n) |
| void | indexSelected (int i) |
| void | modifiedControlPoints (void) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Public Member Functions | |
| axlAbstractSurfaceBSpline (void) | |
| virtual | ~axlAbstractSurfaceBSpline (void) |
| virtual axlAbstractSurfaceBSpline * | copy (void) const |
| virtual int | countControlPoints (void) const |
| virtual int | countControlPoints_u (void) const |
| virtual int | countControlPoints_v (void) const |
| virtual int | knotVectorSize_u (void) const |
| virtual int | knotVectorSize_v (void) const |
| virtual int | order_u (void) const |
| virtual int | order_v (void) const |
| virtual double | getCoord (int n, int m, int v) const |
| virtual axlPoint | getCoef (int n, int m) const |
| virtual axlPoint | getCoef (int n) const |
| virtual double | getWeight (int n, int m) const |
| virtual bool | setCoef (int n, int m, int v, double c) |
| virtual bool | setCoef (int n, int m, double *controlPoint) |
| virtual bool | setCoef (int n, double *controlPoint) |
| virtual double | getKnot_u (int n) const |
| virtual double | getKnot_v (int n) const |
| virtual void | setSurface (int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational) |
| axlAbstractSurfaceBSpline::setSurface More... | |
| virtual void | updateRcoeff () |
| virtual void | insertKnot_u (double k) |
| virtual void | removeKnot_u (double k) |
| virtual void | insertKnot_v (double k) |
| virtual void | removeKnot_v (double k) |
| virtual bool | rational (void) const |
| virtual QVector< axlPoint * > | sampling () |
| virtual void | gridEvaluator (int num_u, int num_v, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v) |
| virtual QString | printCoeffs (bool print) const |
| virtual QString | printKnotsVector (bool print) const |
| virtual QString | description (void) const |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| double | scalarValue (double u, double v) |
| void | setScalarValue (double u, double v, double value) |
| virtual bool | connectionsAreDefined (void) |
| Return true if control points connections were defined by developers. False if there are default connections visualization. More... | |
| virtual QList< int > | getControlPointConnection (int i) |
| The list returned contains all indices of coefficients that are still to be connected to the ith coefficient. More... | |
| virtual void | defineControlPointConnection (int i, int j) |
| Define connection between the ith and the jth coefficient. More... | |
| virtual void | resetControlPointConnections (void) |
| Removes all control point connections. More... | |
| virtual void | selectIndex (int i) |
Public Member Functions inherited from axlAbstractSurfaceParametric | |
| axlAbstractSurfaceParametric (void) | |
| virtual | ~axlAbstractSurfaceParametric (void) |
| virtual axlPoint | eval (double u, double v) |
| virtual void | eval (axlPoint *point, double u, double v) |
| virtual void | eval (double &, double &, double &, double u, double v) |
| virtual void | normal (axlPoint *normal, double u, double v) |
| virtual axlMesh | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v) |
| virtual void | parameterOf (const axlPoint &point, double &um, double &vm) |
| virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v) |
| virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
| virtual double | area (double tol) |
| virtual int | numSamples_u (void) |
| virtual int | numSamples_v (void) |
| virtual double | startParam_u (void) |
| virtual double | endParam_u (void) |
| virtual double | startParam_v (void) |
| virtual double | endParam_v (void) |
| virtual double | startParam_u (int numCell) |
| virtual double | endParam_u (int numCell) |
| virtual double | startParam_v (int numCell) |
| virtual double | endParam_v (int numCell) |
| virtual void | eval (axlPoint *point, double u, double v, int numCell) |
| virtual void | normal (axlPoint *normal, double u, double v, int numCell) |
| virtual bool | hasCells (void) |
| virtual int | countCells (void) |
| virtual int | numSamples_u (int numCell) |
| virtual int | numSamples_v (int numCell) |
| virtual int | stripes (void) |
| virtual void | setStripes (int stripes) |
| virtual void | setNumSamples_u (int numSamples) |
| virtual void | setNumSamples_v (int numSamples) |
| const int & | samples_u (void) const |
| const int & | samples_v (void) const |
Public Member Functions inherited from axlAbstractSurface | |
| axlAbstractSurface (void) | |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractSurfaceParametric | |
| void | setSamples_u (const int &color) |
| void | setSamples_v (const int &color) |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Properties inherited from axlAbstractSurfaceParametric | |
| int | samples_u |
| int | samples_v |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 32 of file axlAbstractSurfaceBSpline.h.
| axlAbstractSurfaceBSpline::axlAbstractSurfaceBSpline | ( | void | ) |
Definition at line 34 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 39 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 252 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 303 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 335 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 45 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 51 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 57 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 63 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 278 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Reimplemented in axlAbstractSurfaceTrimmed.
Definition at line 232 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 108 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 114 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 269 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 102 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 145 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 151 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 121 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 165 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 200 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 210 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 70 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 76 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 83 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 89 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 220 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 226 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 96 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 205 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 215 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 260 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 158 of file axlAbstractSurfaceBSpline.cpp.
signal |
| double axlAbstractSurfaceBSpline::scalarValue | ( | double | u, |
| double | v | ||
Definition at line 238 of file axlAbstractSurfaceBSpline.cpp.
inlinevirtual |
Definition at line 106 of file axlAbstractSurfaceBSpline.h.
virtual |
Definition at line 127 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 133 of file axlAbstractSurfaceBSpline.cpp.
virtual |
Definition at line 139 of file axlAbstractSurfaceBSpline.cpp.
| void axlAbstractSurfaceBSpline::setScalarValue | ( | double | u, |
| double | v, | ||
| double | value | ||
Definition at line 243 of file axlAbstractSurfaceBSpline.cpp.
virtual |
| n_u | number of control points in the u direction |
| n_v | number of control points in the v direction |
| order_u | degree+1 for the u parameter |
| order_v | degree+1 for the v parameter |
| dimension | the number of coordinates of the control points (usually 3) |
| knots_u | the sequence of knots in the u direction |
| knots_v | the sequence of knots in the v direction |
| points | the sequence of coordinates of the control points x0 y0 z0 x1 y1 z1 .... The control points are given row by row as
is represented as dimension doubles. The points of index (0..n_u,0) correspond to the isoparametric curve v=v_min, the points of index (0..n_u,n_v) correspond to the isoparametric curve v=v_max, the points of index (0, 0..n_v) correspond to the isoparametric curve u=u_min, the points of index (n_u, 0..n_v) correspond to the isoparametric curve u=u_max, where u_min,u_max, v_min, v_max are respectively the min and max values of knot_u, knot_v. |
Definition at line 188 of file axlAbstractSurfaceBSpline.cpp.
signal |
virtual |
Definition at line 194 of file axlAbstractSurfaceBSpline.cpp.
