22 #include <dtkCoreSupport/dtkGlobal.h>
   27 class axlAbstractSurfaceBSplinePrivate
   30     QMap<QPair<double, double>,
double> scalar_values;
   31     QHash<int, QList<int> > connect;
   47     DTK_DEFAULT_IMPLEMENTATION;
   53     DTK_DEFAULT_IMPLEMENTATION;
   59     DTK_DEFAULT_IMPLEMENTATION;
   65     DTK_DEFAULT_IMPLEMENTATION;
   72     DTK_DEFAULT_IMPLEMENTATION;
   78     DTK_DEFAULT_IMPLEMENTATION;
   85     DTK_DEFAULT_IMPLEMENTATION;
   91     DTK_DEFAULT_IMPLEMENTATION;
   98     DTK_DEFAULT_IMPLEMENTATION;
  104     DTK_DEFAULT_IMPLEMENTATION;
  110     DTK_DEFAULT_IMPLEMENTATION;
  116     DTK_DEFAULT_IMPLEMENTATION;
  123     DTK_DEFAULT_IMPLEMENTATION;
  129     DTK_DEFAULT_IMPLEMENTATION;
  135     DTK_DEFAULT_IMPLEMENTATION;
  141     DTK_DEFAULT_IMPLEMENTATION;
  147     DTK_DEFAULT_IMPLEMENTATION;
  153     DTK_DEFAULT_IMPLEMENTATION;
  160     DTK_DEFAULT_IMPLEMENTATION;
  161     QVector<axlPoint *> qVect;
  167     DTK_DEFAULT_IMPLEMENTATION;
  190     DTK_DEFAULT_IMPLEMENTATION;
  196     DTK_DEFAULT_IMPLEMENTATION;
  222     DTK_DEFAULT_IMPLEMENTATION;
  228     DTK_DEFAULT_IMPLEMENTATION;
  234     DTK_DEFAULT_IMPLEMENTATION;
  240     return d->scalar_values.value(qMakePair<double, double>(u, v));
  245     d->scalar_values.insert(qMakePair<double, double>(u, v), value);
  253     return !d->connect.isEmpty();
  270     return d->connect.value(i);
  280         qDebug() <<
"The two indices must be different.";
  282         int mini = std::min(i,j);
  283         int maxi = std::max(i,j);
  285         if(d->connect.keys().contains(mini)){
  286             QList<int> list = d->connect.value(mini);
  288             if(!list.contains(maxi) ){
  290                 d->connect.insert(mini, list);
  295             d->connect.insert(mini,list);
  304     dtkWarn()<<
"axlAbstractSurfaceBSpline::convertDataToQVariant not working for rational";
  306     list.append(identifier());
  311     QVariant orderu = QVariant::fromValue(
order_u());
  313     QVariant orderv = QVariant::fromValue(
order_v());
  315     QVariant
dimension = QVariant::fromValue(3);
  316     list.append(dimension);
  319     for(
int i = 0; i < nu.toInt()+
order_u();i++){
  323     for(
int i = 0; i < nv.toInt()+
order_v();i++){
  327     for(
int i = 0; i < nu.toInt()*nv.toInt();i++){
  330     QVariant name = QVariant::fromValue(objectName());
  336     dtkWarn()<<
"axlAbstractSurfaceBSpline::convertQVariantToData not working for rational";
  337     int nu = data.at(1).toInt();
  338     int nv = data.at(2).toInt();
  339     int orderu = data.at(3).toInt();
  340     int orderv = data.at(4).toInt();
  344     double *knotsU =
new double[nu+orderu];
  345     for(
int i = 0; i < nu+orderu;i++){
  346         knotsU[i] = data.at(i+6).toDouble();
  350     double *knotsV =
new double[nv+orderv];
  351     for(
int i = 0; i < nv+orderv;i++){
  352         knotsV[i] = data.at(i+6 +nu+orderu).toDouble();
  356     int indice = 6 +nu+orderu +nv+orderv;
  357     double *CP =
new double[3*nu*nv];
  358     for(
int i = 0; i < nu*nv;i++){
  360         list.append(data.at(indice));
  361         list.append(data.at(indice+1));
  362         list.append(data.at(indice+2));
  363         list.append(data.at(indice+3));
  364         list.append(data.at(indice+4));
  368         CP[3*i] = point->
x();
  369         CP[3*i+1] = point->
y();
  370         CP[3*i+2] = point->
z();
  374     setSurface(nu,nv ,orderu,orderv,dimension,knotsU, knotsV,CP,
false);
  375     QString name = data.last().toString();
virtual axlAbstractSurfaceBSpline * copy(void) const
Class axlPoint defines 3D points.
QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
virtual void resetControlPointConnections(void)
Removes all control point connections.
virtual bool connectionsAreDefined(void)
Return true if control points connections were defined by developers. False if there are default conn...
virtual double getKnot_v(int n) const
virtual QString printCoeffs(bool print) const
virtual void defineControlPointConnection(int i, int j)
Define connection between the ith and the jth coefficient.
void setScalarValue(double u, double v, double value)
axlAbstractSurfaceBSpline(void)
virtual void setSurface(int pointsCount_u, int pointsCount_v, int order_u, int order_v, int dimension, double *knots_u, double *knots_v, double *points, bool rational)
axlAbstractSurfaceBSpline::setSurface
int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual int dimension(void) const
virtual double getCoord(int n, int m, int v) const
virtual ~axlAbstractSurfaceBSpline(void)
double scalarValue(double u, double v)
virtual int countControlPoints_u(void) const
virtual int countControlPoints_v(void) const
virtual void removeKnot_v(double k)
virtual double getWeight(int n, int m) const
virtual int knotVectorSize_u(void) const
virtual QVector< axlPoint * > sampling()
virtual QString printKnotsVector(bool print) const
virtual void insertKnot_v(double k)
virtual bool rational(void) const
virtual int order_u(void) const
virtual QString description(void) const
virtual int countControlPoints(void) const
virtual bool setCoef(int n, int m, int v, double c)
virtual void insertKnot_u(double k)
virtual QList< int > getControlPointConnection(int i)
The list returned contains all indices of coefficients that are still to be connected to the ith coef...
virtual axlPoint getCoef(int n, int m) const
virtual void updateRcoeff()
virtual void gridEvaluator(int num_u, int num_v, std::vector< double > &points, std::vector< double > ¶m_u, std::vector< double > ¶m_v)
virtual int order_v(void) const
virtual int knotVectorSize_v(void) const
virtual double getKnot_u(int n) const
virtual void removeKnot_u(double k)
