20 #ifndef AXLABSTRACTSURFACEBSPLINE_H
   21 #define AXLABSTRACTSURFACEBSPLINE_H
   24 #include "axlCoreExport.h"
   26 #include <dtkMathSupport/dtkVector3D.h>
   30 class axlAbstractSurfaceBSplinePrivate;
   40     using   axlAbstractSurfaceParametric::copy;
   43     virtual int countControlPoints(
void)
const;
   44     virtual int countControlPoints_u(
void)
const;
   45     virtual int countControlPoints_v(
void)
const;
   47     virtual int knotVectorSize_u(
void)
const;
   48     virtual int knotVectorSize_v(
void)
const;
   50     virtual int order_u(
void)
const;
   51     virtual int order_v(
void)
const;
   53     virtual double   getCoord(
int n,
int m,
int v)
const;
   54     virtual axlPoint getCoef(
int n,
int m)
const;
   55     virtual axlPoint getCoef(
int n )
const;
   58     virtual double getWeight(
int n,
int m)
const;
   60     virtual bool setCoef(
int n,
int m,
int v,
double c);
   61     virtual bool setCoef(
int n,
int m,
double *controlPoint);
   62     virtual bool setCoef(
int n,
   64     virtual double getKnot_u(
int n)
const;
   65     virtual double getKnot_v(
int n)
const;
   67     virtual void setSurface(
int pointsCount_u,
int pointsCount_v,
int order_u,
int order_v,
int dimension,
double *knots_u,
double *knots_v,
double *points,
bool rational);
   70     virtual void updateRcoeff();
   72     virtual void insertKnot_u(
double k);
   73     virtual void removeKnot_u(
double k);
   75     virtual void insertKnot_v(
double k);
   76     virtual void removeKnot_v(
double k);
   78     virtual bool rational(
void)
const;
   80     virtual QVector<axlPoint *> sampling();
   82     virtual void gridEvaluator(
int num_u,
int num_v, std::vector<double>& points, std::vector<double>& param_u, std::vector<double>& param_v);
   84     virtual QString printCoeffs(
bool print)
const;
   85     virtual QString printKnotsVector(
bool print)
const;
   87     virtual QString description(
void)
const;
   95     double scalarValue(
double u,
double v);
   96     void setScalarValue(
double u,
double v,
double value);
   99     virtual bool connectionsAreDefined(
void);
  101     virtual QList<int> getControlPointConnection(
int i);
  102     virtual void defineControlPointConnection(
int i,
int j);
  104     virtual void resetControlPointConnections(
void);
  110     void samplingChanged(
void);
  111     void edgeSelected(
int numEdge,
int previous,
int n);
  112     void indexSelected(
int i);
  113     void modifiedControlPoints(
void);
  116     axlAbstractSurfaceBSplinePrivate *d;
Class axlPoint defines 3D points.
virtual void selectIndex(int i)
virtual int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
virtual QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
Class axlMesh defines a piecewise-linear 3D object.
