Class axlPoint defines 3D points. More...
#include <axlPoint.h>
Public Member Functions | |
| axlPoint (QObject *parent=0) | |
| Constructs an axel point of zero coordinates with parent parent of QObject type. More... | |
| axlPoint (double x, double y, double z=0, QObject *parent=0) | |
| Constructs a axel point of coordinates (x, y, z) with parent parent of QObject type. More... | |
| axlPoint (const axlPoint &other) | |
| Constructs a copy of other. More... | |
| axlPoint (const axlPoint *other) | |
| axlPoint (double *p, QObject *parent=0) | |
| ~axlPoint (void) | |
| Destroys the axel point. More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| double | x (void) const |
| Returns x-coordinate of this point. More... | |
| double | y (void) const |
| Returns y-coordinate of this point. More... | |
| double | z (void) const |
| Returns z-coordinate of this point. More... | |
| double | operator[] (int i) const |
| Returns i-th coordinate of this point. More... | |
| double & | x (void) |
| double & | y (void) |
| double & | z (void) |
| double & | operator[] (int i) |
| double * | coordinates (void) const |
| Returns coordinates of this point. More... | |
| double | norm (void) const |
| void | setCoordinates (double x, double y, double z) |
| Change coordinates of this point. More... | |
| void | touchX (double x) |
| void | touchY (double y) |
| void | touchZ (double z) |
| void | normalize (void) |
| axlPoint & | normalized (void) |
| bool | isEqualTo (axlPoint *point) |
| Check if the point we apply the method on is equal to point. More... | |
| axlPoint & | operator= (const axlPoint &other) |
| Assigns other to this point and returns a reference to this point. More... | |
| axlPoint & | operator+= (const axlPoint &other) |
| Adds the coordinates of the other point to this point and returns a reference to this point. More... | |
| axlPoint & | operator-= (const axlPoint &other) |
| Substracts the coordinates of the other point to this point and returns a reference to this point. More... | |
| double | operator* (const axlPoint &other) const |
| Compute the inner product of the two vectors. More... | |
| axlPoint & | operator*= (double scalar) |
| Multiplies the coordinates of this point by a scalar value and returns a reference to this point. More... | |
| axlPoint & | operator/= (double scalar) |
| Divides the coordinates of this point by a scalar value and returns a reference to this point. More... | |
| axlPoint | operator+ (const axlPoint &other) const |
| Returns a point that results from the addition of this point and the other point. More... | |
| axlPoint | operator- (const axlPoint &other) const |
| Returns a point that results from the substraction of this point and the other point. More... | |
| axlPoint | operator* (double scalar) const |
| Returns a point that results from the multiplication of the scalar with this point. More... | |
| axlPoint | operator/ (double scalar) const |
| Returns a point that results from the division of the scalar with this point. More... | |
| void | transformAsPoint (double matrix[12]) |
| Multiplication by 3x3 left block (rotation part) and addition with 3x1 right block (translation part) More... | |
| void | transformAsVector (double matrix[12]) |
| bool | operator< (const axlPoint &other) const |
| order on axlPoints. Compare the coordinates (x,y,z) by lexicographic order. More... | |
| bool | operator== (const axlPoint &point2) const |
| bool | operator!= (const axlPoint &point2) const |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Static Public Member Functions | |
| static double | distance (const axlPoint &lhs, const axlPoint &rhs) |
| Returns the distance between lhs point and rhs point. More... | |
| static double | distance (axlPoint *lhs, axlPoint *rhs) |
| static axlPoint | crossProduct (const axlPoint &lhs, const axlPoint &rhs) |
| Returns the cross product between lhs (coords) and rhs (coords). More... | |
| static axlPoint * | crossProduct (axlPoint *lhs, axlPoint *rhs) |
| static double | dotProduct (const axlPoint &lhs, const axlPoint &rhs) |
| static double | dotProduct (axlPoint *lhs, axlPoint *rhs) |
Properties | |
| double | x |
| double | y |
| double | z |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Friends | |
| QDebug | operator<< (QDebug dbg, axlPoint point) |
| QDebug | operator<< (QDebug dbg, axlPoint &point) |
| QDebug | operator<< (QDebug dbg, axlPoint *point) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
This class enables to represent and manipulate 3D points.
Example:
Definition at line 34 of file axlPoint.h.
| axlPoint::axlPoint | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 45 of file axlPoint.cpp.
| axlPoint::axlPoint | ( | double | x, |
| double | y, | ||
| double | z = 0, |
Definition at line 59 of file axlPoint.cpp.
| axlPoint::axlPoint | ( | const axlPoint & | other | ) |
Definition at line 71 of file axlPoint.cpp.
| axlPoint::axlPoint | ( | const axlPoint * | other | ) |
Definition at line 84 of file axlPoint.cpp.
| axlPoint::axlPoint | ( | double * | p, |
Definition at line 94 of file axlPoint.cpp.
| axlPoint::~axlPoint | ( | void | ) |
Definition at line 107 of file axlPoint.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 571 of file axlPoint.cpp.
virtual |
Definition at line 588 of file axlPoint.cpp.
| double * axlPoint::coordinates | ( | void | ) | const |
Definition at line 445 of file axlPoint.cpp.
Definition at line 485 of file axlPoint.cpp.
Definition at line 498 of file axlPoint.cpp.
virtual |
Definition at line 542 of file axlPoint.cpp.
The distance is always positive.
Definition at line 459 of file axlPoint.cpp.
Definition at line 472 of file axlPoint.cpp.
Definition at line 508 of file axlPoint.cpp.
Definition at line 512 of file axlPoint.cpp.
virtual |
Definition at line 549 of file axlPoint.cpp.
| bool axlPoint::isEqualTo | ( | axlPoint * | point | ) |
Definition at line 437 of file axlPoint.cpp.
| double axlPoint::norm | ( | void | ) | const |
Definition at line 450 of file axlPoint.cpp.
| void axlPoint::normalize | ( | void | ) |
Definition at line 410 of file axlPoint.cpp.
| axlPoint & axlPoint::normalized | ( | void | ) |
Definition at line 421 of file axlPoint.cpp.
| bool axlPoint::operator!= | ( | const axlPoint & | point2 | ) | const |
Definition at line 287 of file axlPoint.cpp.
| double axlPoint::operator* | ( | const axlPoint & | other | ) | const |
Definition at line 226 of file axlPoint.cpp.
| axlPoint axlPoint::operator* | ( | double | scalar | ) | const |
Definition at line 214 of file axlPoint.cpp.
| axlPoint & axlPoint::operator*= | ( | double | scalar | ) |
Definition at line 157 of file axlPoint.cpp.
Definition at line 190 of file axlPoint.cpp.
Definition at line 131 of file axlPoint.cpp.
Definition at line 202 of file axlPoint.cpp.
Definition at line 144 of file axlPoint.cpp.
| axlPoint axlPoint::operator/ | ( | double | scalar | ) | const |
If the scalar value is zero, it returns a default point.
Definition at line 248 of file axlPoint.cpp.
| axlPoint & axlPoint::operator/= | ( | double | scalar | ) |
If the scalar value is zero, the point remains unchanged.
Definition at line 170 of file axlPoint.cpp.
| bool axlPoint::operator< | ( | const axlPoint & | other | ) | const |
Definition at line 236 of file axlPoint.cpp.
Definition at line 118 of file axlPoint.cpp.
| bool axlPoint::operator== | ( | const axlPoint & | point2 | ) | const |
Definition at line 281 of file axlPoint.cpp.
| double axlPoint::operator[] | ( | int | i | ) | const |
Definition at line 323 of file axlPoint.cpp.
| double & axlPoint::operator[] | ( | int | i | ) |
Definition at line 360 of file axlPoint.cpp.
| void axlPoint::setCoordinates | ( | double | x, |
| double | y, | ||
| double | z | ||
Definition at line 370 of file axlPoint.cpp.
| void axlPoint::touchX | ( | double | x | ) |
Definition at line 389 of file axlPoint.cpp.
| void axlPoint::touchY | ( | double | y | ) |
Definition at line 396 of file axlPoint.cpp.
| void axlPoint::touchZ | ( | double | z | ) |
Definition at line 403 of file axlPoint.cpp.
| void axlPoint::transformAsPoint | ( | double | matrix[12] | ) |
Definition at line 263 of file axlPoint.cpp.
| void axlPoint::transformAsVector | ( | double | matrix[12] | ) |
Definition at line 272 of file axlPoint.cpp.
| double axlPoint::x | ( | void | ) | const |
Definition at line 296 of file axlPoint.cpp.
| double & axlPoint::x | ( | void | ) |
Definition at line 333 of file axlPoint.cpp.
| double axlPoint::y | ( | void | ) | const |
Definition at line 305 of file axlPoint.cpp.
| double & axlPoint::y | ( | void | ) |
Definition at line 342 of file axlPoint.cpp.
| double axlPoint::z | ( | void | ) | const |
Definition at line 314 of file axlPoint.cpp.
| double & axlPoint::z | ( | void | ) |
Definition at line 351 of file axlPoint.cpp.
friend |
Definition at line 521 of file axlPoint.cpp.
friend |
Definition at line 528 of file axlPoint.cpp.
friend |
Definition at line 535 of file axlPoint.cpp.
readwrite |
Definition at line 37 of file axlPoint.h.
readwrite |
readwrite |
Definition at line 38 of file axlPoint.h.
