addField(axlAbstractField *field) | axlAbstractData | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlAbstractVolume(void) | axlAbstractVolume | |
axlAbstractVolumeDiscrete(void) | axlAbstractVolumeDiscrete | |
axlAbstractVolumeDiscrete(unsigned int x, unsigned int y, unsigned int z) | axlAbstractVolumeDiscrete | |
axlAbstractVolumeDiscrete(const axlAbstractVolumeDiscrete &other) | axlAbstractVolumeDiscrete | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlAbstractData | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
dimension(void) const | axlAbstractVolume | virtual |
editable(void) | axlAbstractData | |
fields(void) | axlAbstractData | |
getValue(int indiceGlobal) const | axlAbstractVolumeDiscrete | virtual |
getValue(int i, int j, int k) const | axlAbstractVolumeDiscrete | virtual |
maxValue(void) const | axlAbstractVolumeDiscrete | virtual |
mesh(void) | axlAbstractData | |
midValue(void) const | axlAbstractVolumeDiscrete | virtual |
minValue(void) const | axlAbstractVolumeDiscrete | virtual |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setDimensions(unsigned int x, unsigned int y, unsigned int z) | axlAbstractVolumeDiscrete | virtual |
setEditable(bool edit) | axlAbstractData | slot |
setMesh(axlMesh *mesh) | axlAbstractData | |
setOpacity(const double &opacity) | axlAbstractData | slot |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setUpdateView(bool updateView) | axlAbstractData | |
setValue(double value, int indiceGlobal) | axlAbstractVolumeDiscrete | virtual |
setValue(double value, int i, int j, int k) | axlAbstractVolumeDiscrete | virtual |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
toAxlMesh(void) | axlAbstractVolume | virtual |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
volume(void) | axlAbstractVolume | virtual |
xDimension(void) const | axlAbstractVolumeDiscrete | virtual |
yDimension(void) const | axlAbstractVolumeDiscrete | virtual |
zDimension(void) const | axlAbstractVolumeDiscrete | virtual |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlAbstractVolume(void) | axlAbstractVolume | virtual |
~axlAbstractVolumeDiscrete(void) | axlAbstractVolumeDiscrete | virtual |
