#include <axlAbstractVolumeDiscrete.h>
 | Public Member Functions | |
| axlAbstractVolumeDiscrete (void) | |
| axlAbstractVolumeDiscrete (unsigned int x, unsigned int y, unsigned int z) | |
| axlAbstractVolumeDiscrete (const axlAbstractVolumeDiscrete &other) | |
| virtual | ~axlAbstractVolumeDiscrete (void) |
| virtual int | xDimension (void) const |
| virtual int | yDimension (void) const |
| virtual int | zDimension (void) const |
| virtual void | setDimensions (unsigned int x, unsigned int y, unsigned int z) |
| virtual double | getValue (int indiceGlobal) const |
| virtual double | getValue (int i, int j, int k) const |
| virtual void | setValue (double value, int indiceGlobal) |
| virtual void | setValue (double value, int i, int j, int k) |
| virtual double | minValue (void) const |
| virtual double | midValue (void) const |
| virtual double | maxValue (void) const |
|  Public Member Functions inherited from axlAbstractVolume | |
| axlAbstractVolume (void) | |
| virtual | ~axlAbstractVolume (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | volume (void) |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Additional Inherited Members | |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 33 of file axlAbstractVolumeDiscrete.h.
| axlAbstractVolumeDiscrete::axlAbstractVolumeDiscrete | ( | void | ) |
Definition at line 39 of file axlAbstractVolumeDiscrete.cpp.
| axlAbstractVolumeDiscrete::axlAbstractVolumeDiscrete | ( | unsigned int | x, |
| unsigned int | y, | ||
| unsigned int | z | ||
Definition at line 49 of file axlAbstractVolumeDiscrete.cpp.
| axlAbstractVolumeDiscrete::axlAbstractVolumeDiscrete | ( | const axlAbstractVolumeDiscrete & | other | ) |
Definition at line 59 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 69 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 122 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Reimplemented in axlVolumeDiscrete.
Definition at line 133 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 217 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 205 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 194 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 113 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 155 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 169 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 81 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 92 of file axlAbstractVolumeDiscrete.cpp.
 | virtual |
Definition at line 103 of file axlAbstractVolumeDiscrete.cpp.
