| ActorState enum name | axlActor |  |
  | axlAbstractActor(axlAbstractActor *parent=0) | axlAbstractActor |  |
  | axlActor(void) | axlActor |  |
  | axlActorEllipsoid(void) | axlActorEllipsoid | protected |
  | data(void) | axlActorEllipsoid | virtual |
  | deleteObserver(void) | axlActor |  |
  | drawAssymblyMatrix(void) | axlActor | protected |
  | edition enum value | axlActor |  |
  | ellipsoid(void) | axlActorEllipsoid |  |
  | fields(void) | axlActor |  |
  | getActor(void) | axlActor |  |
  | getCellArray(void) | axlActor |  |
  | getCellPicker() | axlActor |  |
  | getDataSetMapper(void) | axlActor |  |
  | getInteractor(void) | axlActor | virtual |
  | getMapper(void) | axlActor |  |
  | getNormals(void) | axlActor |  |
  | getObserver(void) | axlActor |  |
  | getObserverData(void) | axlActor |  |
  | getPoints(void) | axlActor |  |
  | getPolyData(void) | axlActor |  |
  | getState(void) | axlActor | virtual |
  | getUnstructuredGrid(void) | axlActor |  |
  | getvtkVolume(void) | axlActor |  |
  | hide(void) | axlActor | virtualslot |
  | hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
  | identifier(void) | axlAbstractActor | virtual |
  | isShowControlPoints(void) | axlAbstractActor | virtual |
  | isShowEllipsoidWidget(void) | axlActorEllipsoid |  |
  | isVisible(void) | axlActor | virtual |
  | moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
  | NewObserver(void) | axlActor |  |
  | onControlPointChanged(void) | axlAbstractActor | virtualslot |
  | onModeChanged(int state) | axlActorEllipsoid | slot |
  | onRemoved(void) | axlActorEllipsoid | slot |
  | onSamplingChanged(void) | axlAbstractActor | virtualslot |
  | onSelectBoundaryEdge(int numEdge, int previous, int n) | axlAbstractActor | virtualslot |
  | onTubeFilterRadiusChanged(double radius) | axlAbstractActor | virtualslot |
  | onUpdateGeometry(void) | axlActorEllipsoid | slot |
  | onUpdateProperty(void) | axlAbstractActor | virtualslot |
  | onUpdateStructure(void) | axlAbstractActor | inlinevirtualslot |
  | parent(void) | axlAbstractActor | virtual |
  | passive enum value | axlActor |  |
  | selection enum value | axlActor |  |
  | setActor(vtkSmartPointer< vtkActor > actor) | axlActor |  |
  | setCellArray(vtkSmartPointer< vtkCellArray > cellArray) | axlActor |  |
  | setCellPicker(vtkSmartPointer< vtkCellPicker > cellPicker) | axlActor |  |
  | setColor(double red, double green, double blue) | axlActor | virtual |
  | setData(dtkAbstractData *ellipsoid1) | axlActorEllipsoid | virtual |
  | setDataSetMapper(vtkSmartPointer< vtkDataSetMapper > mapper) | axlActor |  |
  | setDisplay(bool display) | axlActorEllipsoid | virtual |
  | setEllipsoidWidget(bool ellipsoidWidget) | axlActorEllipsoid |  |
  | setInteractor(void *interactor) | axlActor | virtual |
  | setInterpolation(int interpolation) | axlActor | virtual |
  | setMapper(vtkSmartPointer< vtkPolyDataMapper > mapper) | axlActor |  |
  | setMapperCollorArray(void) | axlAbstractActor | virtual |
  | setMode(int state) | axlActorEllipsoid | virtual |
  | setNormals(vtkSmartPointer< vtkDoubleArray > normals) | axlActor |  |
  | setObserver(axlActorControlPolygonObserver *observer) | axlActor |  |
  | setObserverData(dtkAbstractData *data) | axlActor |  |
  | setOpacity(double opacity) | axlActor | virtual |
  | setParent(axlAbstractActor *parent) | axlAbstractActor | virtual |
  | setPoints(vtkSmartPointer< vtkPoints > points) | axlActor |  |
  | setPolyData(vtkSmartPointer< vtkPolyData > polyData) | axlActor |  |
  | setQVTKWidget(QVTKOpenGLWidget *widget) | axlActorEllipsoid |  |
  | setShader(QString vsfile) | axlActor | virtual |
  | setShaderFromString(QString vertex_shader_source, QString fragment_shader_source) | axlActor | virtual |
  | axlAbstractActor::setShaderFromString(QString xmlfile) | axlAbstractActor | virtual |
  | setSize(double size) | axlActor | virtual |
  | setState(int state) | axlActor | virtual |
  | setUnstructuredGrid(vtkSmartPointer< vtkUnstructuredGrid > unstructuredGrid) | axlActor |  |
  | setvtkVolume(vtkSmartPointer< vtkVolume > actor) | axlActor |  |
  | show(void) | axlActor | virtualslot |
  | showControlPoints(bool show) | axlAbstractActor | virtual |
  | showCurrentPoint(double u, double v, dtkAbstractData *data) | axlAbstractActor | virtualslot |
  | showEllipsoidWidget(bool ellipsoidWidget) | axlActorEllipsoid |  |
  | stateChanged(dtkAbstractData *data, int mode) | axlAbstractActor | signal |
  | toMesh(void) | axlAbstractActor | virtual |
  | update(void) | axlActor | virtualslot |
  | updated(void) | axlAbstractActor | signal |
  | vtkTypeRevisionMacro(axlActorEllipsoid, vtkAssembly) static axlActorEllipsoid *New(void) | axlActorEllipsoid |  |
  | ~axlAbstractActor(void) | axlAbstractActor | virtual |
  | ~axlActor(void) | axlActor |  |
  | ~axlActorEllipsoid(void) | axlActorEllipsoid | protected |
