| ActorState enum name | axlActor |  |
  | addToObserver(int idEvent, vtkCommand *observer) | axlActorBSpline | virtual |
  | axlAbstractActor(axlAbstractActor *parent=0) | axlAbstractActor |  |
  | axlActor(void) | axlActor |  |
  | axlActorBSpline(void) | axlActorBSpline | protected |
  | axlActorSurfaceBSpline(void) | axlActorSurfaceBSpline | protected |
  | data(void) | axlActorSurfaceBSpline | virtual |
  | deleteObserver(void) | axlActor |  |
  | drawAssymblyMatrix(void) | axlActor | protected |
  | edition enum value | axlActor |  |
  | fields(void) | axlActor |  |
  | getActor(void) | axlActor |  |
  | getCellArray(void) | axlActor |  |
  | getCellPicker() | axlActor |  |
  | getControlPoints(void) | axlActorBSpline | virtual |
  | getDataSetMapper(void) | axlActor |  |
  | getInteractor(void) | axlActor | virtual |
  | getMapper(void) | axlActor |  |
  | getNormals(void) | axlActor |  |
  | getObserver(void) | axlActor |  |
  | getObserverData(void) | axlActor |  |
  | getPoints(void) | axlActor |  |
  | getPolyData(void) | axlActor |  |
  | getState(void) | axlActor | virtual |
  | getUnstructuredGrid(void) | axlActor |  |
  | getvtkVolume(void) | axlActor |  |
  | hide(void) | axlActor | virtualslot |
  | hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
  | identifier(void) | axlAbstractActor | virtual |
  | initCurrentPoint(void) | axlActorBSpline | virtualslot |
  | isShowControlPoints(void) | axlActorBSpline | virtual |
  | isVisible(void) | axlActor | virtual |
  | meshProcess(void) | axlActorSurfaceBSpline |  |
  | moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
  | New(void) | axlActorSurfaceBSpline | static |
  | NewObserver(void) | axlActor |  |
  | normalsUpdate(void) | axlActorSurfaceBSpline |  |
  | onControlPointChanged() | axlActorBSpline | virtualslot |
  | onModeChanged(int state) | axlActorBSpline | virtualslot |
  | onRemoved(void) | axlActorBSpline | virtualslot |
  | onSamplingChanged(void) | axlActorSurfaceBSpline | virtualslot |
  | onSelectBoundaryEdge(int numEdge, int previous, int n) | axlActorSurfaceBSpline | slot |
  | onTubeFilterRadiusChanged(double radius) | axlAbstractActor | virtualslot |
  | onUpdateGeometry(void) | axlActorSurfaceBSpline | virtualslot |
  | onUpdateProperty(void) | axlAbstractActor | virtualslot |
  | onUpdateStructure(void) | axlActorBSpline | inlinevirtual |
  | parent(void) | axlAbstractActor | virtual |
  | passive enum value | axlActor |  |
  | pointsUpdate(void) | axlActorSurfaceBSpline |  |
  | polyDataUpdate(void) | axlActorSurfaceBSpline |  |
  | selection enum value | axlActor |  |
  | setActor(vtkSmartPointer< vtkActor > actor) | axlActor |  |
  | setCellArray(vtkSmartPointer< vtkCellArray > cellArray) | axlActor |  |
  | setCellPicker(vtkSmartPointer< vtkCellPicker > cellPicker) | axlActor |  |
  | setColor(double red, double green, double blue) | axlActor | virtual |
  | setControlPoints(axlControlPointsWidget *controlPoints) | axlActorBSpline | virtual |
  | setControlPolygon(bool control) | axlActorBSpline | virtual |
  | setData(dtkAbstractData *spline_Surface1) | axlActorSurfaceBSpline | virtual |
  | setDataSetMapper(vtkSmartPointer< vtkDataSetMapper > mapper) | axlActor |  |
  | setDisplay(bool display) | axlActorBSpline | virtual |
  | setInteractor(void *interactor) | axlActor | virtual |
  | setInterpolation(int interpolation) | axlActor | virtual |
  | setMapper(vtkSmartPointer< vtkPolyDataMapper > mapper) | axlActor |  |
  | setMapperCollorArray(void) | axlActorSurfaceBSpline | virtual |
  | setMode(int state) | axlActorBSpline | virtual |
  | setNormals(vtkSmartPointer< vtkDoubleArray > normals) | axlActor |  |
  | setObserver(axlActorControlPolygonObserver *observer) | axlActor |  |
  | setObserverData(dtkAbstractData *data) | axlActor |  |
  | setOpacity(double opacity) | axlActor | virtual |
  | setParent(axlAbstractActor *parent) | axlAbstractActor | virtual |
  | setPoints(vtkSmartPointer< vtkPoints > points) | axlActor |  |
  | setPolyData(vtkSmartPointer< vtkPolyData > polyData) | axlActor |  |
  | setShader(QString vsfile) | axlActor | virtual |
  | setShaderFromString(QString vertex_shader_source, QString fragment_shader_source) | axlActor | virtual |
  | axlAbstractActor::setShaderFromString(QString xmlfile) | axlAbstractActor | virtual |
  | setSize(double size) | axlActor | virtual |
  | setState(int state) | axlActor | virtual |
  | setUnstructuredGrid(vtkSmartPointer< vtkUnstructuredGrid > unstructuredGrid) | axlActor |  |
  | setvtkVolume(vtkSmartPointer< vtkVolume > actor) | axlActor |  |
  | show(void) | axlActor | virtualslot |
  | showControlPoints(bool show) | axlActorBSpline | virtual |
  | showCurrentPoint(double u, double v, dtkAbstractData *data) | axlActorBSpline | virtualslot |
  | stateChanged(dtkAbstractData *data, int mode) | axlAbstractActor | signal |
  | toMesh(void) | axlAbstractActor | virtual |
  | update(void) | axlActor | virtualslot |
  | updated(void) | axlAbstractActor | signal |
  | vtkTypeRevisionMacro(axlActorSurfaceBSpline, vtkAssembly) | axlActorSurfaceBSpline |  |
  | ~axlAbstractActor(void) | axlAbstractActor | virtual |
  | ~axlActor(void) | axlActor |  |
  | ~axlActorBSpline(void) | axlActorBSpline | protected |
  | ~axlActorSurfaceBSpline(void) | axlActorSurfaceBSpline | protected |
