addField(axlAbstractField *field) | axlAbstractData | |
area(double tol) | axlAbstractSurfaceParametric | virtual |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlAbstractSurface(void) | axlAbstractSurface | |
axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | |
axlConeParametric(axlAbstractSurfaceParametric *parent=0) | axlConeParametric | |
axlConeParametric(axlCone *cone, axlPoint *r) | axlConeParametric | |
axlConeParametric(const axlCone &cone, const axlPoint &r) | axlConeParametric | |
axlConeParametric(const axlConeParametric &other) | axlConeParametric | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlAbstractData | virtual |
convertQVariantToData(const QVariantList &data) | axlAbstractData | virtual |
countCells(void) | axlAbstractSurfaceParametric | virtual |
description(void) const | axlConeParametric | virtual |
dimension(void) const | axlAbstractSurface | virtual |
editable(void) | axlAbstractData | |
endParam_u(void) | axlAbstractSurfaceParametric | virtual |
endParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
endParam_v(void) | axlAbstractSurfaceParametric | virtual |
endParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
eval(double u, double v) | axlConeParametric | virtual |
eval(axlPoint *point, double u, double v) | axlConeParametric | virtual |
eval(double &x, double &y, double &z, double u, double v) | axlConeParametric | virtual |
axlAbstractSurfaceParametric::eval(double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) | axlAbstractSurfaceParametric | virtual |
axlAbstractSurfaceParametric::eval(axlPoint *point, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
eval2(double u, double v) | axlAbstractSurfaceParametric | virtual |
fields(void) | axlAbstractData | |
getCone(void) const | axlConeParametric | |
getR(void) const | axlConeParametric | |
hasCells(void) | axlAbstractSurfaceParametric | virtual |
identifier(void) const | axlConeParametric | virtual |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
modifyR(double *r) | axlConeParametric | |
normal(axlPoint *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
normal(double u, double v) | axlAbstractSurfaceParametric | virtual |
normal(dtkDeprecated::dtkVector3D< double > *normal, double u, double v) | axlAbstractSurfaceParametric | virtual |
normal(axlPoint *normal, double u, double v, int numCell) | axlAbstractSurfaceParametric | virtual |
numSamples_u(void) | axlAbstractSurfaceParametric | virtual |
numSamples_u(int numCell) | axlAbstractSurfaceParametric | virtual |
numSamples_v(void) | axlAbstractSurfaceParametric | virtual |
numSamples_v(int numCell) | axlAbstractSurfaceParametric | virtual |
onConeChanged(axlCone *cone) | axlConeParametric | slot |
onRChanged(axlPoint *r) | axlConeParametric | slot |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
operator=(const axlConeParametric &other) | axlConeParametric | |
parameterOf(const axlPoint &point, double &um, double &vm) | axlConeParametric | virtual |
samples_u | axlAbstractSurfaceParametric | |
samples_u(void) const | axlAbstractSurfaceParametric | |
samples_v | axlAbstractSurfaceParametric | |
samples_v(void) const | axlAbstractSurfaceParametric | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setCone(axlCone *cone) | axlConeParametric | |
setCone(const axlCone &cone) | axlConeParametric | |
setEditable(bool edit) | axlAbstractData | slot |
setMesh(axlMesh *mesh) | axlAbstractData | |
setNumSamples_u(int numSamples) | axlAbstractSurfaceParametric | virtual |
setNumSamples_v(int numSamples) | axlAbstractSurfaceParametric | virtual |
setOpacity(const double &opacity) | axlAbstractData | slot |
setR(axlPoint *r) | axlConeParametric | |
setSamples_u(const int &color) | axlAbstractSurfaceParametric | slot |
setSamples_v(const int &color) | axlAbstractSurfaceParametric | slot |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setStripes(int stripes) | axlAbstractSurfaceParametric | virtual |
setUpdateView(bool updateView) | axlAbstractData | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
startParam_u(void) | axlAbstractSurfaceParametric | virtual |
startParam_u(int numCell) | axlAbstractSurfaceParametric | virtual |
startParam_v(void) | axlAbstractSurfaceParametric | virtual |
startParam_v(int numCell) | axlAbstractSurfaceParametric | virtual |
stripes(void) | axlAbstractSurfaceParametric | virtual |
surface(void) | axlAbstractSurface | virtual |
toAxlMesh(void) | axlAbstractSurface | virtual |
touchField(void) | axlAbstractData | virtualslot |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchStructure(void) | axlAbstractData | slot |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlAbstractSurface(void) | axlAbstractSurface | virtual |
~axlAbstractSurfaceParametric(void) | axlAbstractSurfaceParametric | virtual |
~axlConeParametric(void) | axlConeParametric | virtual |
