|  | axlConeParametric (axlAbstractSurfaceParametric *parent=0) |
|  | axlConeParametric (axlCone *cone, axlPoint *r) |
|  | axlConeParametric (const axlCone &cone, const axlPoint &r) |
|  | axlConeParametric (const axlConeParametric &other) |
| virtual | ~axlConeParametric (void) |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| void | setCone (axlCone *cone) |
| axlPoint * | getR (void) const |
| void | setR (axlPoint *r) |
| axlConeParametric & | operator= (const axlConeParametric &other) |
| void | modifyR (double *r) |
| axlCone * | getCone (void) const |
| void | setCone (const axlCone &cone) |
| virtual axlPoint | eval (double u, double v) |
| virtual void | eval (axlPoint *point, double u, double v) |
| virtual void | eval (double &x, double &y, double &z, double u, double v) |
| virtual void | parameterOf (const axlPoint &point, double &um, double &vm) |
|  | axlAbstractSurfaceParametric (void) |
| virtual | ~axlAbstractSurfaceParametric (void) |
| virtual void | normal (axlPoint *normal, double u, double v) |
| virtual axlMesh | eval (double u, double v, int derivs, bool u_from_right=true, bool v_from_right=true, double resolution=1.0e-12) |
| virtual dtkDeprecated::dtkVector3D< double > | eval2 (double u, double v) |
| virtual dtkDeprecated::dtkVector3D< double > | normal (double u, double v) |
| virtual void | normal (dtkDeprecated::dtkVector3D< double > *normal, double u, double v) |
| virtual double | area (double tol) |
| virtual int | numSamples_u (void) |
| virtual int | numSamples_v (void) |
| virtual double | startParam_u (void) |
| virtual double | endParam_u (void) |
| virtual double | startParam_v (void) |
| virtual double | endParam_v (void) |
| virtual double | startParam_u (int numCell) |
| virtual double | endParam_u (int numCell) |
| virtual double | startParam_v (int numCell) |
| virtual double | endParam_v (int numCell) |
| virtual void | eval (axlPoint *point, double u, double v, int numCell) |
| virtual void | normal (axlPoint *normal, double u, double v, int numCell) |
| virtual bool | hasCells (void) |
| virtual int | countCells (void) |
| virtual int | numSamples_u (int numCell) |
| virtual int | numSamples_v (int numCell) |
| virtual int | stripes (void) |
| virtual void | setStripes (int stripes) |
| virtual void | setNumSamples_u (int numSamples) |
| virtual void | setNumSamples_v (int numSamples) |
| const int & | samples_u (void) const |
| const int & | samples_v (void) const |
|  | axlAbstractSurface (void) |
| virtual | ~axlAbstractSurface (void) |
| virtual int | dimension (void) const |
| virtual axlMesh * | toAxlMesh (void) |
| virtual void * | surface (void) |
|  | axlAbstractData (axlAbstractData *parent=NULL) |
|  | axlAbstractData (const axlAbstractData &data) |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
|  | Add a field to the field list of the object.  More...
| bool | updateFieldList (QString nameField) |
|  | Check if a field with the same name is already applied on the object.  More...
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
|  | Return the mesh of that object is computed.  More...
| void | setMesh (axlMesh *mesh) |
|  | Set a corresponding mesh for that object.  More...
| virtual QVariantList | convertDataToQVariant (void) const |
|  | Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData.  More...
| virtual int | convertQVariantToData (const QVariantList &data) |
|  | Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0.  More...
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Definition at line 26 of file axlConeParametric.h.
