Class axlCone defines 3D cones. More...
#include <axlCone.h>
Public Slots | |
void | onApexChanged (axlPoint *apex) |
void | onBasePointChanged (axlPoint *basePoint) |
void | onRadiusChanged (double radius) |
void | touchGeometry (void) |
void | touchProperty (void) |
void | touchStructure (void) |
virtual void | touchField (void) |
void | setColor (const QColor &color) |
void | setOpacity (const double &opacity) |
void | setSize (const double &size) |
void | setShader (const QString &shader) |
void | setEditable (bool edit) |
Signals | |
void | dataChanged (void) |
void | modifiedGeometry (void) |
void | modifiedStructure (void) |
void | modifiedField (void) |
void | modifiedProperty (void) |
Public Member Functions | |
axlCone (QObject *parent=0) | |
Constructs a axel cone of with apex and basePoint point are NULL and 1.0 radius with parent parent of QObject type. More... | |
axlCone (axlPoint *apex, axlPoint *basePoint, double radius, QObject *parent=0) | |
Constructs a axel cone of two axlPoint apex basePoint and radius radius with parent parent of QObject type. More... | |
axlCone (const axlPoint &apex, const axlPoint &basePoint, double radius, QObject *parent=0) | |
Constructs an axel cone from two axlPoint apex basePoint and its radius radius with parent parent. More... | |
axlCone (const axlCone &other) | |
Constructs a copy of other with same axlPoints. More... | |
~axlCone (void) | |
Destroys the axel cone. More... | |
virtual QString | description (void) const |
virtual QString | identifier (void) const |
axlPoint * | apex (void) const |
Returns apex of the cone. More... | |
axlPoint * | basePoint (void) const |
Returns basePoint point of the cone. More... | |
double | radius (void) const |
Returns radius of the cone. More... | |
double | length (void) const |
Returns length of the cone. More... | |
void | setValues (axlPoint *apex, axlPoint *basePoint, double radius) |
Change apex and basePoint of this cone. More... | |
void | setApex (axlPoint *apex) |
Change apex of this cone. More... | |
void | setApex (double *apex) |
void | setBasePoint (axlPoint *basePoint) |
Change base point of this cone. More... | |
void | setBasePoint (double *basePoint) |
void | setRadius (double radius) |
Change radius of this cone. More... | |
void | setLength (double length) |
Change length of this cone we considered then apex is the origin of the cone and we change base point in consequence. More... | |
void | touchApex (axlPoint apex) |
void | touchBasePoint (axlPoint basePoint) |
void | touchRadius (double radius) |
axlCone & | operator= (const axlCone &other) |
Assigns other to this cone and returns a reference to this cone. More... | |
QVariantList | convertDataToQVariant (void) const |
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
int | convertQVariantToData (const QVariantList &data) |
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
axlAbstractData (axlAbstractData *parent=NULL) | |
axlAbstractData (const axlAbstractData &data) | |
virtual | ~axlAbstractData (void) |
const QColor & | color (void) const |
const double & | opacity (void) const |
const double & | size (void) const |
const QString & | shader (void) const |
const bool & | editable (void) |
const bool & | updateView (void) |
void | setColor (double r, double g, double b) |
void | addField (axlAbstractField *field) |
Add a field to the field list of the object. More... | |
bool | updateFieldList (QString nameField) |
Check if a field with the same name is already applied on the object. More... | |
QString | changeFieldName (QString fieldName) |
axlMesh * | mesh (void) |
Return the mesh of that object is computed. More... | |
void | setMesh (axlMesh *mesh) |
Set a corresponding mesh for that object. More... | |
void | setUpdateView (bool updateView) |
QList< axlAbstractField * > | fields (void) |
Properties | |
axlPoint | apex |
axlPoint | basePoint |
double | radius |
QColor | color |
double | opacity |
double | size |
QString | shader |
Friends | |
QDebug | operator<< (QDebug dbg, axlCone line) |
QDebug | operator<< (QDebug dbg, axlCone &line) |
QDebug | operator<< (QDebug dbg, axlCone *line) |
This class enables to represent and manipulate 3D cones.
Example:
axlCone::axlCone | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel cone with no parent.
Definition at line 48 of file axlCone.cpp.
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 63 of file axlCone.cpp.
axlCone::axlCone | ( | const axlPoint & | apex, |
const axlPoint & | basePoint, | ||
double | radius, | ||
Definition at line 78 of file axlCone.cpp.
axlCone::axlCone | ( | const axlCone & | other | ) |
Definition at line 90 of file axlCone.cpp.
axlCone::~axlCone | ( | void | ) |
Definition at line 103 of file axlCone.cpp.
axlPoint * axlCone::apex | ( | void | ) | const |
Definition at line 136 of file axlCone.cpp.
axlPoint * axlCone::basePoint | ( | void | ) | const |
Definition at line 145 of file axlCone.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 326 of file axlCone.cpp.
virtual |
Definition at line 342 of file axlCone.cpp.
signal |
virtual |
Definition at line 288 of file axlCone.cpp.
virtual |
Definition at line 301 of file axlCone.cpp.
double axlCone::length | ( | void | ) | const |
Definition at line 163 of file axlCone.cpp.
slot |
Definition at line 307 of file axlCone.cpp.
slot |
Definition at line 313 of file axlCone.cpp.
slot |
Definition at line 319 of file axlCone.cpp.
Definition at line 123 of file axlCone.cpp.
double axlCone::radius | ( | void | ) | const |
Definition at line 154 of file axlCone.cpp.
void axlCone::setApex | ( | axlPoint * | apex | ) |
Definition at line 185 of file axlCone.cpp.
void axlCone::setApex | ( | double * | apex | ) |
Definition at line 192 of file axlCone.cpp.
void axlCone::setBasePoint | ( | axlPoint * | basePoint | ) |
Definition at line 203 of file axlCone.cpp.
void axlCone::setBasePoint | ( | double * | basePoint | ) |
Definition at line 210 of file axlCone.cpp.
void axlCone::setLength | ( | double | length | ) |
Definition at line 232 of file axlCone.cpp.
void axlCone::setRadius | ( | double | radius | ) |
Definition at line 221 of file axlCone.cpp.
Definition at line 172 of file axlCone.cpp.
void axlCone::touchApex | ( | axlPoint | apex | ) |
Definition at line 257 of file axlCone.cpp.
void axlCone::touchBasePoint | ( | axlPoint | basePoint | ) |
Definition at line 251 of file axlCone.cpp.
void axlCone::touchRadius | ( | double | radius | ) |
Definition at line 245 of file axlCone.cpp.
friend |
Definition at line 267 of file axlCone.cpp.
friend |
Definition at line 274 of file axlCone.cpp.
friend |
Definition at line 281 of file axlCone.cpp.
