Developer documentation | Axl-2.5.1
axlCurveOnParamSurface Member List
This is the complete list of members for axlCurveOnParamSurface, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
axlAbstractCurve(void)axlAbstractCurve
axlAbstractCurveParametric(void)axlAbstractCurveParametric
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlCurveOnParamSurface(QObject *parent=0)axlCurveOnParamSurface
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlAbstractDatavirtual
convertQVariantToData(const QVariantList &data)axlAbstractDatavirtual
CreateCurveObject()axlCurveOnParamSurface
curve(void)axlAbstractCurvevirtual
description(void) const axlCurveOnParamSurfacevirtual
dimension(void) const axlAbstractCurvevirtual
editable(void)axlAbstractData
endParam(void)axlAbstractCurveParametricvirtual
eval(double u)axlAbstractCurveParametricvirtual
eval(axlPoint *point, double u)axlAbstractCurveParametricvirtual
eval(double u, int derivs, bool from_right=true)axlAbstractCurveParametricvirtual
fields(void)axlAbstractData
get_direction() const axlCurveOnParamSurface
get_direction()axlCurveOnParamSurface
get_main_surface() const axlCurveOnParamSurface
get_support_curve() const axlCurveOnParamSurface
get_support_curve()axlCurveOnParamSurface
get_support_curve_param_domain() const axlCurveOnParamSurface
get_support_curve_param_domain()axlCurveOnParamSurface
get_support_surface() const axlCurveOnParamSurface
get_way_create_curve() const axlCurveOnParamSurface
get_way_present_curve() const axlCurveOnParamSurface
identifier(void) const axlCurveOnParamSurfacevirtual
isPlanar(void) const axlAbstractCurvevirtual
length(double tolerance)axlAbstractCurveParametricvirtual
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
numSamples(void)axlAbstractCurveParametricvirtual
onDirectChanged(bool direct)axlAbstractCurveParametricvirtualslot
opacityaxlAbstractData
opacity(void) const axlAbstractData
operator=(const axlCurveOnParamSurface &other)axlCurveOnParamSurface
parameterOf(const axlPoint &p)axlAbstractCurveParametric
samplesaxlAbstractCurveParametric
samples(void) const axlAbstractCurveParametric
set_direction(axlPoint *point)axlCurveOnParamSurface
set_direction(const axlPoint &point)axlCurveOnParamSurface
set_main_surface(axlAbstractSurfaceParametric *surface)axlCurveOnParamSurface
set_support_curve(axlAbstractCurve *curve)axlCurveOnParamSurface
set_support_curve_param_domain(axlAbstractCurve *curve)axlCurveOnParamSurface
set_support_surface(axlAbstractSurfaceParametric *surface)axlCurveOnParamSurface
set_way_create_curve(int way)axlCurveOnParamSurface
set_way_present_curve(int way)axlCurveOnParamSurface
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setNumSamples(int numSamples)axlAbstractCurveParametricvirtual
setOpacity(const double &opacity)axlAbstractDataslot
setSamples(const int &color)axlAbstractCurveParametricslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
startParam(void)axlAbstractCurveParametricvirtual
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
~axlAbstractCurve(void)axlAbstractCurvevirtual
~axlAbstractCurveParametric(void)axlAbstractCurveParametricvirtual
~axlAbstractData(void)axlAbstractDatavirtual
~axlCurveOnParamSurface()axlCurveOnParamSurface
