#include <axlCurveOnParamSurface.h>
Public Member Functions | |
| axlCurveOnParamSurface (QObject *parent=0) | |
| ~axlCurveOnParamSurface () | |
| int | get_way_create_curve () const |
| void | set_way_create_curve (int way) |
| int | get_way_present_curve () const |
| void | set_way_present_curve (int way) |
| axlAbstractSurfaceParametric & | get_main_surface () const |
| void | set_main_surface (axlAbstractSurfaceParametric *surface) |
| axlAbstractSurfaceParametric * | get_support_surface () const |
| void | set_support_surface (axlAbstractSurfaceParametric *surface) |
| axlAbstractCurve & | get_support_curve () const |
| axlAbstractCurve * | get_support_curve () |
| void | set_support_curve (axlAbstractCurve *curve) |
| axlPoint & | get_direction () const |
| axlPoint * | get_direction () |
| void | set_direction (axlPoint *point) |
| void | set_direction (const axlPoint &point) |
| axlAbstractCurve & | get_support_curve_param_domain () const |
| axlAbstractCurve * | get_support_curve_param_domain () |
| void | set_support_curve_param_domain (axlAbstractCurve *curve) |
| void | CreateCurveObject () |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlCurveOnParamSurface & | operator= (const axlCurveOnParamSurface &other) |
Public Member Functions inherited from axlAbstractCurveParametric | |
| axlAbstractCurveParametric (void) | |
| virtual | ~axlAbstractCurveParametric (void) |
| virtual double | startParam (void) |
| virtual double | endParam (void) |
| virtual axlPoint | eval (double u) |
| virtual void | eval (axlPoint *point, double u) |
| virtual axlMesh | eval (double u, int derivs, bool from_right=true) |
| double | parameterOf (const axlPoint &p) |
| virtual double | length (double tolerance) |
| virtual int | numSamples (void) |
| virtual void | setNumSamples (int numSamples) |
| const int & | samples (void) const |
Public Member Functions inherited from axlAbstractCurve | |
| axlAbstractCurve (void) | |
| virtual | ~axlAbstractCurve (void) |
| virtual int | dimension (void) const |
| virtual bool | isPlanar (void) const |
| virtual void * | curve (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| virtual QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| virtual int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractCurveParametric | |
| virtual void | onDirectChanged (bool direct) |
| void | setSamples (const int &color) |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
Properties inherited from axlAbstractCurveParametric | |
| int | samples |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
: From IGES - page 191 (this number is in pdf file, NOT the page in book):
The Curve on a Parametric Surface Entity associates a given curve with a surface and identifies the curve as lying on the surface. If S is a regular parameterized surface whose domain is a rectangle defined by D = {( u,v )| u1 <= u <= u2 and v1 <= v <= v2 )} Let B = B(t) be a curve defined by B(t) = (u(t), v(t)) for a <= t <= b, taking its values in D. A curve Cc(t) on the surface S(u, v) is the composition of two mappings, S and B, defined as: Cc(t) = S o B(t) = (x(u(t),v(t)),y(u(t),v(t)),z(u(t),v(t))) : A curve on a surface may have been created in one of a number of various ways: " 1. as the projection on the surface of a given curve in model space in a prescribed way, for example, parallel to a given fixed vector
There are an important variable in this class, way_create_curve. So, be careful when use the methods set_way_create_curve(). Because it will decide what data will be used. See this information below:
value of way_create_curve | Methods | Variable will be used 0 | Unspecified | None of them 1 | Projection of a givencurve on the surface | sup_dir, sup_curve 2 | Intersection of two surfaces | sup_surface
Note:
Definition at line 58 of file axlCurveOnParamSurface.h.
| axlCurveOnParamSurface::axlCurveOnParamSurface | ( | QObject * | parent = 0 | ) |
Definition at line 30 of file axlCurveOnParamSurface.cpp.
| axlCurveOnParamSurface::~axlCurveOnParamSurface | ( | ) |
Definition at line 44 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::CreateCurveObject | ( | ) |
Definition at line 91 of file axlCurveOnParamSurface.cpp.
virtual |
Definition at line 162 of file axlCurveOnParamSurface.cpp.
| axlPoint & axlCurveOnParamSurface::get_direction | ( | ) | const |
Definition at line 61 of file axlCurveOnParamSurface.cpp.
| axlPoint* axlCurveOnParamSurface::get_direction | ( | ) |
| axlAbstractSurfaceParametric & axlCurveOnParamSurface::get_main_surface | ( | ) | const |
Definition at line 66 of file axlCurveOnParamSurface.cpp.
| axlAbstractCurve & axlCurveOnParamSurface::get_support_curve | ( | ) | const |
Definition at line 71 of file axlCurveOnParamSurface.cpp.
| axlAbstractCurve * axlCurveOnParamSurface::get_support_curve | ( | ) |
Definition at line 76 of file axlCurveOnParamSurface.cpp.
| axlAbstractCurve & axlCurveOnParamSurface::get_support_curve_param_domain | ( | ) | const |
Definition at line 86 of file axlCurveOnParamSurface.cpp.
| axlAbstractCurve * axlCurveOnParamSurface::get_support_curve_param_domain | ( | ) |
Definition at line 81 of file axlCurveOnParamSurface.cpp.
| axlAbstractSurfaceParametric* axlCurveOnParamSurface::get_support_surface | ( | ) | const |
| int axlCurveOnParamSurface::get_way_create_curve | ( | ) | const |
Definition at line 51 of file axlCurveOnParamSurface.cpp.
| int axlCurveOnParamSurface::get_way_present_curve | ( | ) | const |
Definition at line 56 of file axlCurveOnParamSurface.cpp.
virtual |
Definition at line 168 of file axlCurveOnParamSurface.cpp.
| axlCurveOnParamSurface & axlCurveOnParamSurface::operator= | ( | const axlCurveOnParamSurface & | other | ) |
Definition at line 146 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_direction | ( | axlPoint * | point | ) |
Definition at line 120 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_direction | ( | const axlPoint & | point | ) |
Definition at line 125 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_main_surface | ( | axlAbstractSurfaceParametric * | surface | ) |
Definition at line 115 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_support_curve | ( | axlAbstractCurve * | curve | ) |
Definition at line 130 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_support_curve_param_domain | ( | axlAbstractCurve * | curve | ) |
Definition at line 135 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_support_surface | ( | axlAbstractSurfaceParametric * | surface | ) |
Definition at line 140 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_way_create_curve | ( | int | way | ) |
Definition at line 105 of file axlCurveOnParamSurface.cpp.
| void axlCurveOnParamSurface::set_way_present_curve | ( | int | way | ) |
Definition at line 110 of file axlCurveOnParamSurface.cpp.
