Developer documentation | Axl-2.5.1
axlDataDynamic Member List
This is the complete list of members for axlDataDynamic, including all inherited members.
add(dtkAbstractData *data)axlAbstractDataComposite
addField(axlAbstractField *field)axlAbstractData
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlAbstractDataComposite(void)axlAbstractDataComposite
axlDataDynamic(void)axlDataDynamic
changeFieldName(QString fieldName)axlAbstractData
clearInputs(void)axlDataDynamic
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlDataDynamicvirtual
convertQVariantToData(const QVariantList &data)axlDataDynamicvirtual
count(void)axlAbstractDataComposite
dataInserted(axlAbstractData *data)axlDataDynamicsignal
description(void) const axlDataDynamicvirtual
Dynamic enum valueaxlDataDynamic
editable(void)axlAbstractData
fields(void)axlAbstractData
get(dtkAbstractData *data)axlAbstractDataComposite
get(int i)axlAbstractDataComposite
getType(void)axlDataDynamic
identifier(void) const axlDataDynamicvirtual
inputs(void)axlDataDynamic
isNotInputProcess(dtkAbstractData *data)axlDataDynamic
isNotOutputProcess(dtkAbstractData *data)axlDataDynamic
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
numberOfChannels(void)axlDataDynamicvirtual
numberOfUpdate(void)axlDataDynamicslot
onRemoved(void)axlDataDynamicslot
opacityaxlAbstractData
opacity(void) const axlAbstractData
outputs(void)axlDataDynamic
outputs(int channel)axlDataDynamic
parameters(void)axlDataDynamic
process(void)axlDataDynamic
remove(dtkAbstractData *data)axlAbstractDataComposite
samplingChanged()axlAbstractDataCompositesignal
set(QList< dtkAbstractData * > data)axlAbstractDataComposite
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setInput(dtkAbstractData *data, int channel=0)axlDataDynamicslot
setMesh(axlMesh *mesh)axlAbstractData
setOpacity(const double &opacity)axlAbstractDataslot
setParameter(int parameter)axlDataDynamicslot
setParameter(int parameter, int channel)axlDataDynamicslot
setParameter(double parameter)axlDataDynamicslot
setParameter(double parameter, int channel)axlDataDynamicslot
setProcess(QString processName)axlDataDynamicslot
setProcess(axlAbstractProcess *process)axlDataDynamicslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setType(axlDataDynamic::Type type)axlDataDynamic
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
Static enum valueaxlDataDynamic
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
Type enum nameaxlDataDynamic
update(void)axlDataDynamicvirtualslot
updated(void)axlAbstractDataCompositesignal
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
~axlAbstractData(void)axlAbstractDatavirtual
~axlAbstractDataComposite(void)axlAbstractDataCompositevirtual
~axlDataDynamic(void)axlDataDynamicvirtual
