Class axlDataDynamic defines a dynamic object. More...
#include <axlDataDynamic.h>
 | Public Types | |
| enum | Type { Dynamic = 0x001, Static = 0x002 } |
| Public Slots | |
| void | setInput (dtkAbstractData *data, int channel=0) |
| Add input;.  More... | |
| void | setParameter (int parameter) |
| Set parameter.  More... | |
| void | setParameter (int parameter, int channel) |
| void | setParameter (double parameter) |
| void | setParameter (double parameter, int channel) |
| int | setProcess (QString processName) |
| Create the dynamic object process only with the name of its latter.  More... | |
| void | setProcess (axlAbstractProcess *process) |
| Create the dynamic object process by copying the current state of a process.  More... | |
| int | numberOfUpdate (void) |
| Return how many times the geometry of the dynamic object has been updated.  More... | |
| virtual void | update (void) |
| Update the dynamic object.  More... | |
| void | onRemoved (void) |
| This slot is called whenever one of the dynamic object input is deleted.  More... | |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Signals | |
| void | dataInserted (axlAbstractData *data) |
|  Signals inherited from axlAbstractDataComposite | |
| void | updated (void) |
| void | samplingChanged () |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| Public Member Functions | |
| axlDataDynamic (void) | |
| virtual | ~axlDataDynamic (void) |
| axlDataDynamic::Type | getType (void) |
| Return the type : dynamic if it is a dynamic object or static if it is just a computation node.  More... | |
| void | setType (axlDataDynamic::Type type) |
| Sets the type of the object. Type could be dynamic or static.  More... | |
| QList< axlAbstractData * > | inputs (void) |
| Return input list;.  More... | |
| QList< axlAbstractData * > | parameters (void) |
| axlAbstractProcess * | process (void) |
| Return the process.  More... | |
| axlAbstractData * | outputs (void) |
| Return the first output of the list.  More... | |
| axlAbstractData * | outputs (int channel) |
| Return the channel-th output of the list.  More... | |
| void | clearInputs (void) |
| Clear input list.  More... | |
| bool | isNotInputProcess (dtkAbstractData *data) |
| Check whether the output of the process is a different object that one of its inputs.  More... | |
| bool | isNotOutputProcess (dtkAbstractData *data) |
| Check whether the data is an output of the process.  More... | |
| QVariantList | convertDataToQVariant (void) const |
| int | convertQVariantToData (const QVariantList &data) |
| virtual QString | description (void) const |
| Return a description of the dynamic object.  More... | |
| virtual QString | identifier (void) const |
| Return the identifier "axlDataDynamic".  More... | |
| virtual int | numberOfChannels (void) |
| Return the number of output(s);.  More... | |
|  Public Member Functions inherited from axlAbstractDataComposite | |
| axlAbstractDataComposite (void) | |
| virtual | ~axlAbstractDataComposite (void) |
| void | add (dtkAbstractData *data) |
| bool | get (dtkAbstractData *data) |
| void | set (QList< dtkAbstractData * > data) |
| void | remove (dtkAbstractData *data) |
| int | count (void) |
| dtkAbstractData * | get (int i) |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Additional Inherited Members | |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
This class enables to represent and manipulate dynamic object.
Example:
Definition at line 33 of file axlDataDynamic.h.
| enum axlDataDynamic::Type |
| Enumerator | |
| Dynamic | |
| Static | |
Definition at line 38 of file axlDataDynamic.h.
| axlDataDynamic::axlDataDynamic | ( | void | ) |
Definition at line 57 of file axlDataDynamic.cpp.
 | virtual |
Definition at line 66 of file axlDataDynamic.cpp.
| void axlDataDynamic::clearInputs | ( | void | ) |
Clear input list.
Definition at line 169 of file axlDataDynamic.cpp.
 | virtual |
Convert an axlShape into a QVariantList. Useful for RPC protocol.
Reimplemented from axlAbstractData.
Definition at line 469 of file axlDataDynamic.cpp.
 | virtual |
Convert a QVariantList into an axlShape. Useful for RPC protocol.
Definition at line 522 of file axlDataDynamic.cpp.
 | signal |
 | virtual |
Reimplemented from axlAbstractDataComposite.
Definition at line 311 of file axlDataDynamic.cpp.
| axlDataDynamic::Type axlDataDynamic::getType | ( | void | ) |
By default type is dynamic.
Definition at line 114 of file axlDataDynamic.cpp.
 | virtual |
Definition at line 331 of file axlDataDynamic.cpp.
| QList< axlAbstractData * > axlDataDynamic::inputs | ( | void | ) |
Return input list;.
Definition at line 202 of file axlDataDynamic.cpp.
| bool axlDataDynamic::isNotInputProcess | ( | dtkAbstractData * | data | ) |
Definition at line 177 of file axlDataDynamic.cpp.
| bool axlDataDynamic::isNotOutputProcess | ( | dtkAbstractData * | data | ) |
Definition at line 189 of file axlDataDynamic.cpp.
 | virtual |
Definition at line 341 of file axlDataDynamic.cpp.
 | slot |
Definition at line 132 of file axlDataDynamic.cpp.
 | slot |
Definition at line 104 of file axlDataDynamic.cpp.
| axlAbstractData * axlDataDynamic::outputs | ( | void | ) |
Definition at line 154 of file axlDataDynamic.cpp.
| axlAbstractData * axlDataDynamic::outputs | ( | int | channel | ) |
Definition at line 141 of file axlDataDynamic.cpp.
| QList<axlAbstractData *> axlDataDynamic::parameters | ( | void | ) |
| axlAbstractProcess * axlDataDynamic::process | ( | void | ) |
Return the process.
Definition at line 210 of file axlDataDynamic.cpp.
 | slot |
Add input;.
Definition at line 218 of file axlDataDynamic.cpp.
 | slot |
Set parameter.
Definition at line 241 of file axlDataDynamic.cpp.
 | slot |
Set parameter.
Definition at line 252 of file axlDataDynamic.cpp.
 | slot |
Set parameter.
Definition at line 263 of file axlDataDynamic.cpp.
 | slot |
Set parameter.
Definition at line 274 of file axlDataDynamic.cpp.
 | slot |
Definition at line 285 of file axlDataDynamic.cpp.
 | slot |
Definition at line 300 of file axlDataDynamic.cpp.
| void axlDataDynamic::setType | ( | axlDataDynamic::Type | type | ) |
Definition at line 123 of file axlDataDynamic.cpp.
 | virtualslot |
Definition at line 350 of file axlDataDynamic.cpp.
