#include <axlShape.h>
 | Classes | |
| struct | Edge |
| The edge structure.  More... | |
| struct | Face |
| The Face structure.  More... | |
| struct | Loop |
| The Loop structure.  More... | |
| Public Member Functions | |
| axlShape (int vertexCount, int edgeCount, int faceCount, axlShape *parent=0) | |
| virtual | ~axlShape (void) |
| QVector< axlPoint * > | getVertices (void) const |
| QVector< Edge * > | getEdges (void) const |
| QVector< Face * > | getFaces (void) const |
| int | getVertexCount (void) const |
| int | getEdgeCount (void) const |
| int | getFaceCount (void) const |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| void | insert_vertex (axlPoint *vertex, int index) |
| void | insert_edge (Edge *edge, int index) |
| void | insert_edge (axlAbstractCurveParametric *crv, int si, int ei, int index) |
| void | sortEdges (Loop *loop) |
| Sort edges.  More... | |
| void | sortLoops (Face *face) |
| Sort loops.  More... | |
| void | insert_face (Face *face, int index) |
| void | insert_face (axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index) |
| void | insert_face (axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index) |
| void | insert_face_with_no_sort (axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index) |
| void | insert_face_with_no_sort (axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index) |
| QVariantList | convertDataToQVariant (void) const |
| int | convertQVariantToData (const QVariantList &data) |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Additional Inherited Members | |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Definition at line 31 of file axlShape.h.
| axlShape::axlShape | ( | int | vertexCount, |
| int | edgeCount, | ||
| int | faceCount, | ||
| axlShape * | parent = 0 | ||
Construct an axlShape with the corresponding number of vertices, edges and faces.
The default values for the pointers is NULL.
Definition at line 45 of file axlShape.cpp.
 | virtual |
Destructor
Definition at line 60 of file axlShape.cpp.
 | virtual |
Convert an axlShape into a QVariantList. Useful for RPC protocol.
Reimplemented from axlAbstractData.
Definition at line 314 of file axlShape.cpp.
 | virtual |
Convert a QVariantList into an axlShape. Useful for RPC protocol.
Definition at line 349 of file axlShape.cpp.
 | virtual |
Describe the object.
Definition at line 89 of file axlShape.cpp.
| int axlShape::getEdgeCount | ( | void | ) | const |
Get the number of edges.
Definition at line 81 of file axlShape.cpp.
| QVector< axlShape::Edge * > axlShape::getEdges | ( | void | ) | const |
Get the vector of edges.
Definition at line 69 of file axlShape.cpp.
| int axlShape::getFaceCount | ( | void | ) | const |
Get the number of faces.
Definition at line 85 of file axlShape.cpp.
| QVector< axlShape::Face * > axlShape::getFaces | ( | void | ) | const |
Get the vector of faces.
Definition at line 73 of file axlShape.cpp.
| int axlShape::getVertexCount | ( | void | ) | const |
Get the number of vertices.
Definition at line 77 of file axlShape.cpp.
| QVector< axlPoint * > axlShape::getVertices | ( | void | ) | const |
Get the vector of vertices.
Definition at line 65 of file axlShape.cpp.
 | virtual |
Identify the object
Definition at line 130 of file axlShape.cpp.
| void axlShape::insert_edge | ( | Edge * | edge, |
| int | index | ||
Insert edge at the index position. The number of allocated edges should be stricktly bigger than the index.
Definition at line 138 of file axlShape.cpp.
| void axlShape::insert_edge | ( | axlAbstractCurveParametric * | crv, |
| int | si, | ||
| int | ei, | ||
| int | index | ||
Definition at line 142 of file axlShape.cpp.
| void axlShape::insert_face | ( | Face * | face, |
| int | index | ||
Insert face at the index position. The number of allocated faces should be stricktly bigger than the index.
Definition at line 308 of file axlShape.cpp.
| void axlShape::insert_face | ( | axlAbstractSurfaceParametric * | surf, |
| int * | l, | ||
| int * | orient, | ||
| int * | loopsSize, | ||
| int | sizel, | ||
| int | nbLoops, | ||
| int | index | ||
Definition at line 238 of file axlShape.cpp.
| int * | l, | ||
| int | sizel, | ||
| int | sizeOrient, | ||
| int | index | ||
Definition at line 279 of file axlShape.cpp.
| void axlShape::insert_face_with_no_sort | ( | axlAbstractSurfaceParametric * | surf, |
| int * | l, | ||
| int | sizel, | ||
| int | index | ||
Definition at line 294 of file axlShape.cpp.
| int * | l, | ||
| int | sizel, | ||
| int | nbLoops, | ||
| int | index | ||
Definition at line 259 of file axlShape.cpp.
| void axlShape::insert_vertex | ( | axlPoint * | vertex, |
| int | index | ||
Insert vertex at index position. The number of allocated vertices should be stricktly bigger than the index.
Definition at line 134 of file axlShape.cpp.
| void axlShape::sortEdges | ( | Loop * | loop | ) |
Sort edges.
Edges among a loop are not ordered. This function sort them to be adjacent.
| loop | the loop to sort |
Definition at line 147 of file axlShape.cpp.
| void axlShape::sortLoops | ( | Face * | face | ) |
Sort loops.
Edges among a loop are not ordered. This function sort every loop the face contains.
| face | the face that contains loops to sort |
Definition at line 232 of file axlShape.cpp.
