Developer documentation | Axl-2.5.1
axlShape Member List
This is the complete list of members for axlShape, including all inherited members.
addField(axlAbstractField *field)axlAbstractData
axlAbstractData(axlAbstractData *parent=NULL)axlAbstractData
axlAbstractData(const axlAbstractData &data)axlAbstractData
axlShape(int vertexCount, int edgeCount, int faceCount, axlShape *parent=0)axlShape
changeFieldName(QString fieldName)axlAbstractData
coloraxlAbstractData
color(void) const axlAbstractData
convertDataToQVariant(void) const axlShapevirtual
convertQVariantToData(const QVariantList &data)axlShapevirtual
description(void) const axlShapevirtual
editable(void)axlAbstractData
fields(void)axlAbstractData
getEdgeCount(void) const axlShape
getEdges(void) const axlShape
getFaceCount(void) const axlShape
getFaces(void) const axlShape
getVertexCount(void) const axlShape
getVertices(void) const axlShape
identifier(void) const axlShapevirtual
insert_edge(Edge *edge, int index)axlShape
insert_edge(axlAbstractCurveParametric *crv, int si, int ei, int index)axlShape
insert_face(Face *face, int index)axlShape
insert_face(axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index)axlShape
insert_face(axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index)axlShape
insert_face_with_no_sort(axlAbstractSurfaceParametric *surf, int *l, int *orient, int sizel, int sizeOrient, int index)axlShape
insert_face_with_no_sort(axlAbstractSurfaceParametric *surf, int *l, int *orient, int *loopsSize, int sizel, int nbLoops, int index)axlShape
insert_vertex(axlPoint *vertex, int index)axlShape
mesh(void)axlAbstractData
modifiedField(void)axlAbstractDatasignal
modifiedGeometry(void)axlAbstractDatasignal
modifiedProperty(void)axlAbstractDatasignal
modifiedStructure(void)axlAbstractDatasignal
opacityaxlAbstractData
opacity(void) const axlAbstractData
setColor(double r, double g, double b)axlAbstractData
setColor(const QColor &color)axlAbstractDataslot
setEditable(bool edit)axlAbstractDataslot
setMesh(axlMesh *mesh)axlAbstractData
setOpacity(const double &opacity)axlAbstractDataslot
setShader(const QString &shader)axlAbstractDataslot
setSize(const double &size)axlAbstractDataslot
setUpdateView(bool updateView)axlAbstractData
shaderaxlAbstractData
shader(void) const axlAbstractData
sizeaxlAbstractData
size(void) const axlAbstractData
sortEdges(Loop *loop)axlShape
sortLoops(Face *face)axlShape
touchField(void)axlAbstractDatavirtualslot
touchGeometry(void)axlAbstractDataslot
touchProperty(void)axlAbstractDataslot
touchStructure(void)axlAbstractDataslot
updateFieldList(QString nameField)axlAbstractData
updateView(void)axlAbstractData
~axlAbstractData(void)axlAbstractDatavirtual
~axlShape(void)axlShapevirtual
