Class axlLine defines 3D lines. More...
#include <axlLine.h>
Public Member Functions | |
| axlLine (QObject *parent=0) | |
| Constructs a axel line of with firstPoint and second point are NULL with parent parent of QObject type. More... | |
| axlLine (axlPoint *p1, axlPoint *p2, QObject *parent=0) | |
| Constructs a axel line of two axlPoint p1 p2 with parent parent of QObject type. More... | |
| axlLine (const axlPoint &p1, const axlPoint &p2, QObject *parent=0) | |
| Constructs an axel line from two axl points p1 p2 and a parent. More... | |
| axlLine (const axlLine &other) | |
| Constructs a copy of other with same axlPoints. More... | |
| ~axlLine (void) | |
| Destroys the axel line. More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlPoint * | firstPoint (void) const |
| Returns first point of the line. More... | |
| axlPoint * | secondPoint (void) const |
| Returns second point of the line. More... | |
| axlPoint * | getBarycenterPoint (double coeff) |
| Returns a barycenter point of the line. More... | |
| axlPoint * | getMiddlePoint (void) |
| Returns the center point of the line. More... | |
| void | setFirstPoint (axlPoint *p1) |
| Change first point of this line. More... | |
| void | setFirstPoint (double *p1) |
| modify first point of this line. More... | |
| void | touchFirstPoint (const axlPoint &point) |
| Change first point of this line and emit using touchGeometry. More... | |
| void | touchSecondPoint (const axlPoint &point) |
| Change second point of this line and emit using touchGeometry. More... | |
| void | setSecondPoint (axlPoint *p2) |
| Change second point of this line. More... | |
| void | setSecondPoint (double *p2) |
| modify second point of this line. More... | |
| void | setValues (axlPoint *p1, axlPoint *p2) |
| Change first point and second point of this line. More... | |
| void | applyMatrix (double *matrix) |
| double | planeDirection (void) |
| compute the direction value of the line ie a in y = ax + b. More... | |
| double | planeOrigineOrdinate (void) |
| compute the b value of the line y = ax + b. More... | |
| axlLine & | operator= (const axlLine &other) |
| Assigns other to this line and returns a reference to this line. More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
| void | onFirstPointChanged (axlPoint *p1) |
| void | onSecondPointChanged (axlPoint *p2) |
Public Member Functions inherited from axlAbstractCurveParametric | |
| axlAbstractCurveParametric (void) | |
| virtual | ~axlAbstractCurveParametric (void) |
| virtual double | startParam (void) |
| virtual double | endParam (void) |
| virtual axlPoint | eval (double u) |
| virtual void | eval (axlPoint *point, double u) |
| virtual axlMesh | eval (double u, int derivs, bool from_right=true) |
| double | parameterOf (const axlPoint &p) |
| virtual double | length (double tolerance) |
| virtual int | numSamples (void) |
| virtual void | setNumSamples (int numSamples) |
| const int & | samples (void) const |
Public Member Functions inherited from axlAbstractCurve | |
| axlAbstractCurve (void) | |
| virtual | ~axlAbstractCurve (void) |
| virtual int | dimension (void) const |
| virtual bool | isPlanar (void) const |
| virtual void * | curve (void) |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Properties | |
| axlPoint | point1 |
| axlPoint | point2 |
Properties inherited from axlAbstractCurveParametric | |
| int | samples |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Friends | |
| QDebug | operator<< (QDebug dbg, axlLine line) |
| QDebug | operator<< (QDebug dbg, axlLine &line) |
| QDebug | operator<< (QDebug dbg, axlLine *line) |
Additional Inherited Members | |
Public Slots inherited from axlAbstractCurveParametric | |
| virtual void | onDirectChanged (bool direct) |
| void | setSamples (const int &color) |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
| axlLine::axlLine | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel line with no parent.
Definition at line 47 of file axlLine.cpp.
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 60 of file axlLine.cpp.
Definition at line 74 of file axlLine.cpp.
| axlLine::axlLine | ( | const axlLine & | other | ) |
Definition at line 86 of file axlLine.cpp.
| axlLine::~axlLine | ( | void | ) |
Definition at line 98 of file axlLine.cpp.
| void axlLine::applyMatrix | ( | double * | matrix | ) |
Definition at line 242 of file axlLine.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 319 of file axlLine.cpp.
virtual |
Definition at line 333 of file axlLine.cpp.
virtual |
Definition at line 293 of file axlLine.cpp.
| axlPoint * axlLine::firstPoint | ( | void | ) | const |
Definition at line 128 of file axlLine.cpp.
| axlPoint * axlLine::getBarycenterPoint | ( | double | coeff | ) |
Definition at line 146 of file axlLine.cpp.
| axlPoint * axlLine::getMiddlePoint | ( | void | ) |
Definition at line 158 of file axlLine.cpp.
virtual |
Definition at line 300 of file axlLine.cpp.
| void axlLine::onFirstPointChanged | ( | axlPoint * | p1 | ) |
Definition at line 306 of file axlLine.cpp.
| void axlLine::onSecondPointChanged | ( | axlPoint * | p2 | ) |
Definition at line 312 of file axlLine.cpp.
Definition at line 116 of file axlLine.cpp.
| double axlLine::planeDirection | ( | void | ) |
Definition at line 252 of file axlLine.cpp.
| double axlLine::planeOrigineOrdinate | ( | void | ) |
Definition at line 262 of file axlLine.cpp.
| axlPoint * axlLine::secondPoint | ( | void | ) | const |
Definition at line 137 of file axlLine.cpp.
| void axlLine::setFirstPoint | ( | axlPoint * | p1 | ) |
Definition at line 182 of file axlLine.cpp.
| void axlLine::setFirstPoint | ( | double * | p1 | ) |
Definition at line 202 of file axlLine.cpp.
| void axlLine::setSecondPoint | ( | axlPoint * | p2 | ) |
Definition at line 192 of file axlLine.cpp.
| void axlLine::setSecondPoint | ( | double * | p2 | ) |
Definition at line 214 of file axlLine.cpp.
Definition at line 170 of file axlLine.cpp.
| void axlLine::touchFirstPoint | ( | const axlPoint & | point | ) |
Definition at line 226 of file axlLine.cpp.
| void axlLine::touchSecondPoint | ( | const axlPoint & | point | ) |
Definition at line 236 of file axlLine.cpp.
friend |
Definition at line 272 of file axlLine.cpp.
friend |
Definition at line 279 of file axlLine.cpp.
friend |
Definition at line 286 of file axlLine.cpp.
