addField(axlAbstractField *field) | axlAbstractData | |
applyMatrix(double *matrix) | axlLine | |
axlAbstractCurve(void) | axlAbstractCurve | |
axlAbstractCurveParametric(void) | axlAbstractCurveParametric | |
axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
axlLine(QObject *parent=0) | axlLine | |
axlLine(axlPoint *p1, axlPoint *p2, QObject *parent=0) | axlLine | |
axlLine(const axlPoint &p1, const axlPoint &p2, QObject *parent=0) | axlLine | |
axlLine(const axlLine &other) | axlLine | |
changeFieldName(QString fieldName) | axlAbstractData | |
color | axlAbstractData | |
color(void) const | axlAbstractData | |
convertDataToQVariant(void) const | axlLine | virtual |
convertQVariantToData(const QVariantList &data) | axlLine | virtual |
curve(void) | axlAbstractCurve | virtual |
description(void) const | axlLine | virtual |
dimension(void) const | axlAbstractCurve | virtual |
editable(void) | axlAbstractData | |
endParam(void) | axlAbstractCurveParametric | virtual |
eval(double u) | axlAbstractCurveParametric | virtual |
eval(axlPoint *point, double u) | axlAbstractCurveParametric | virtual |
eval(double u, int derivs, bool from_right=true) | axlAbstractCurveParametric | virtual |
fields(void) | axlAbstractData | |
firstPoint(void) const | axlLine | |
getBarycenterPoint(double coeff) | axlLine | |
getMiddlePoint(void) | axlLine | |
identifier(void) const | axlLine | virtual |
isPlanar(void) const | axlAbstractCurve | virtual |
length(double tolerance) | axlAbstractCurveParametric | virtual |
mesh(void) | axlAbstractData | |
modifiedField(void) | axlAbstractData | signal |
modifiedGeometry(void) | axlAbstractData | signal |
modifiedProperty(void) | axlAbstractData | signal |
modifiedStructure(void) | axlAbstractData | signal |
numSamples(void) | axlAbstractCurveParametric | virtual |
onDirectChanged(bool direct) | axlAbstractCurveParametric | virtualslot |
onFirstPointChanged(axlPoint *p1) | axlLine | |
onSecondPointChanged(axlPoint *p2) | axlLine | |
opacity | axlAbstractData | |
opacity(void) const | axlAbstractData | |
operator<<(QDebug dbg, axlLine line) | axlLine | friend |
operator<<(QDebug dbg, axlLine &line) | axlLine | friend |
operator<<(QDebug dbg, axlLine *line) | axlLine | friend |
operator=(const axlLine &other) | axlLine | |
parameterOf(const axlPoint &p) | axlAbstractCurveParametric | |
planeDirection(void) | axlLine | |
planeOrigineOrdinate(void) | axlLine | |
point1 | axlLine | |
point2 | axlLine | |
samples | axlAbstractCurveParametric | |
samples(void) const | axlAbstractCurveParametric | |
secondPoint(void) const | axlLine | |
setColor(double r, double g, double b) | axlAbstractData | |
setColor(const QColor &color) | axlAbstractData | slot |
setEditable(bool edit) | axlAbstractData | slot |
setFirstPoint(axlPoint *p1) | axlLine | |
setFirstPoint(double *p1) | axlLine | |
setMesh(axlMesh *mesh) | axlAbstractData | |
setNumSamples(int numSamples) | axlAbstractCurveParametric | virtual |
setOpacity(const double &opacity) | axlAbstractData | slot |
setSamples(const int &color) | axlAbstractCurveParametric | slot |
setSecondPoint(axlPoint *p2) | axlLine | |
setSecondPoint(double *p2) | axlLine | |
setShader(const QString &shader) | axlAbstractData | slot |
setSize(const double &size) | axlAbstractData | slot |
setUpdateView(bool updateView) | axlAbstractData | |
setValues(axlPoint *p1, axlPoint *p2) | axlLine | |
shader | axlAbstractData | |
shader(void) const | axlAbstractData | |
size | axlAbstractData | |
size(void) const | axlAbstractData | |
startParam(void) | axlAbstractCurveParametric | virtual |
touchField(void) | axlAbstractData | virtualslot |
touchFirstPoint(const axlPoint &point) | axlLine | |
touchGeometry(void) | axlAbstractData | slot |
touchProperty(void) | axlAbstractData | slot |
touchSecondPoint(const axlPoint &point) | axlLine | |
touchStructure(void) | axlAbstractData | slot |
updateFieldList(QString nameField) | axlAbstractData | |
updateView(void) | axlAbstractData | |
~axlAbstractCurve(void) | axlAbstractCurve | virtual |
~axlAbstractCurveParametric(void) | axlAbstractCurveParametric | virtual |
~axlAbstractData(void) | axlAbstractData | virtual |
~axlLine(void) | axlLine | |
