Developer documentation | Axl-2.5.1
axlDataDynamic.h
Go to the documentation of this file.
1 /* axlDataDynamic.h ---
2  *
3  * Author: Anais Ducoffe
4  * Copyright (C)
5  * Created:
6  * Version: $Id$
7  * Last-Updated:
8  * By:
9  * Update #:
10  */
11
12 /* Commentary:
13  *
14  */
15
16 /* Change log:
17  *
18  */
19
20 #ifndef AXLDATADYNAMIC_H
21 #define AXLDATADYNAMIC_H
22
23 #include "axlCoreExport.h"
25
26 #include <dtkCoreSupport/dtkAbstractProcess.h>
27
28 #include <QtCore>
29
30 class axlDataDynamicPrivate;
31 class axlAbstractProcess;
32
34 {
35  Q_OBJECT
36
37 public:
38  enum Type {
39  Dynamic = 0x001,
40  Static = 0x002
41  };
42
43 public:
44  axlDataDynamic(void);
45  virtual ~axlDataDynamic(void);
46
47
48 public :
49  axlDataDynamic::Type getType(void);
50  void setType(axlDataDynamic::Type type);
51
52
53 public slots:
54  void setInput(dtkAbstractData *data, int channel=0);
55
56  void setParameter(int parameter);
57  void setParameter(int parameter, int channel);
58  void setParameter(double parameter);
59  void setParameter(double parameter, int channel);
60
61  int setProcess(QString processName);
62  void setProcess(axlAbstractProcess *process);
63  int numberOfUpdate(void);
64
65 public :
66  QList<axlAbstractData *> inputs(void);
67  QList<axlAbstractData *> parameters(void);
68  axlAbstractProcess *process(void);
69  axlAbstractData *outputs(void);
70  axlAbstractData *outputs(int channel);
71  void clearInputs(void);
72  bool isNotInputProcess(dtkAbstractData *data);
73  bool isNotOutputProcess(dtkAbstractData *data);
74
78  QVariantList convertDataToQVariant(void) const;
82  int convertQVariantToData(const QVariantList &data);
83
84
85  /* dtk overload */
86
87 public:
88
89  virtual QString description(void) const;
90  virtual QString identifier(void) const;
91
92 public:
93  virtual int numberOfChannels(void);
94
95 signals :
96  void dataInserted(axlAbstractData *data);
97
98 public slots:
99  virtual void update(void);
100  void onRemoved(void);
101
102 private:
103  axlDataDynamicPrivate *d;
104 };
105
106 dtkAbstractData *createAxlDataDynamic(void);
107
108 #endif// AXLDATADYNAMIC_H
virtual int convertQVariantToData(const QVariantList &data)
Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was suc...
Class axlDataDynamic defines a dynamic object.
dtkAbstractData * createAxlDataDynamic(void)
virtual QVariantList convertDataToQVariant(void) const
Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData...
#define AXLCORE_EXPORT
Class axlAbstractData defines an API for all type of axel data.
