Class axlDouble defines a double. More...
#include <axlDouble.h>
 | Public Slots | |
| void | setValue (double newValue) |
|  Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
| Public Member Functions | |
| axlDouble (QObject *parent=0) | |
| axlDouble (double value, QObject *parent=0) | |
| axlDouble (const axlDouble &other) | |
| Constructs a copy of other with same value.  More... | |
| ~axlDouble (void) | |
| Destroys the axel double.  More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| double | value (void) const |
| QVariantList | convertDataToQVariant (void) const |
| int | convertQVariantToData (const QVariantList &data) |
| axlDouble & | operator= (const axlDouble &other) |
| Assigns other to this double and returns a reference to this double.  More... | |
|  Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object.  More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object.  More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed.  More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object.  More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
| Friends | |
| QDebug | operator<< (QDebug dbg, axlDouble line) |
| QDebug | operator<< (QDebug dbg, axlDouble &line) |
| QDebug | operator<< (QDebug dbg, axlDouble *line) |
| Additional Inherited Members | |
|  Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
|  Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
This class enables to represent and manipulate double number.
Example:
Definition at line 29 of file axlDouble.h.
| axlDouble::axlDouble | ( | QObject * | parent = 0 | ) |
Definition at line 35 of file axlDouble.cpp.
| axlDouble::axlDouble | ( | double | value, |
| QObject * | parent = 0 | ||
Definition at line 41 of file axlDouble.cpp.
| axlDouble::axlDouble | ( | const axlDouble & | other | ) |
Definition at line 52 of file axlDouble.cpp.
| axlDouble::~axlDouble | ( | void | ) |
Definition at line 62 of file axlDouble.cpp.
 | virtual |
Convert an axlDouble into a QVariantList. Useful for RPC protocol.
Reimplemented from axlAbstractData.
Definition at line 128 of file axlDouble.cpp.
 | virtual |
Convert a QVariantList into an axlDouble. Useful for RPC protocol.
Definition at line 138 of file axlDouble.cpp.
 | virtual |
Definition at line 115 of file axlDouble.cpp.
 | virtual |
Definition at line 122 of file axlDouble.cpp.
Definition at line 72 of file axlDouble.cpp.
 | slot |
Definition at line 83 of file axlDouble.cpp.
| double axlDouble::value | ( | void | ) | const |
Definition at line 79 of file axlDouble.cpp.
 | friend |
Definition at line 94 of file axlDouble.cpp.
 | friend |
Definition at line 101 of file axlDouble.cpp.
 | friend |
Definition at line 108 of file axlDouble.cpp.
