| addField(axlAbstractField *field) | axlAbstractData | |
| axlAbstractData(axlAbstractData *parent=NULL) | axlAbstractData | |
| axlAbstractData(const axlAbstractData &data) | axlAbstractData | |
| axlEllipsoid(QObject *parent=0) | axlEllipsoid | |
| axlEllipsoid(axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ, QObject *parent=0) | axlEllipsoid | |
| axlEllipsoid(const axlPoint ¢er, const axlPoint &semiX, const axlPoint &semiY, const axlPoint &semiZ, QObject *parent=0) | axlEllipsoid | |
| axlEllipsoid(const axlEllipsoid &other) | axlEllipsoid | |
| calculateXY(void) | axlEllipsoid | slot |
| calculateXZ(void) | axlEllipsoid | slot |
| calculateYZ(void) | axlEllipsoid | slot |
| center | axlEllipsoid | |
| center(void) const | axlEllipsoid | |
| changeFieldName(QString fieldName) | axlAbstractData | |
| color | axlAbstractData | |
| color(void) const | axlAbstractData | |
| convertDataToQVariant(void) const | axlEllipsoid | virtual |
| convertQVariantToData(const QVariantList &data) | axlEllipsoid | virtual |
| description(void) const | axlEllipsoid | virtual |
| editable(void) | axlAbstractData | |
| fields(void) | axlAbstractData | |
| identifier(void) const | axlEllipsoid | virtual |
| mesh(void) | axlAbstractData | |
| modifiedField(void) | axlAbstractData | signal |
| modifiedGeometry(void) | axlAbstractData | signal |
| modifiedProperty(void) | axlAbstractData | signal |
| modifiedStructure(void) | axlAbstractData | signal |
| modifyCenter(double *center) | axlEllipsoid | |
| modifyCenterX(double x) | axlEllipsoid | |
| modifyCenterY(double y) | axlEllipsoid | |
| modifyCenterZ(double z) | axlEllipsoid | |
| modifySemiX(double *semiX) | axlEllipsoid | |
| modifySemiXX(double x) | axlEllipsoid | |
| modifySemiXY(double y) | axlEllipsoid | |
| modifySemiXZ(double z) | axlEllipsoid | |
| modifySemiY(double *semiY) | axlEllipsoid | |
| modifySemiYX(double x) | axlEllipsoid | |
| modifySemiYY(double y) | axlEllipsoid | |
| modifySemiYZ(double z) | axlEllipsoid | |
| modifySemiZ(double *semiZ) | axlEllipsoid | |
| modifySemiZX(double x) | axlEllipsoid | |
| modifySemiZY(double y) | axlEllipsoid | |
| modifySemiZZ(double z) | axlEllipsoid | |
| onCenterChanged(axlPoint *center) | axlEllipsoid | slot |
| onSemiXChanged(axlPoint *semiX) | axlEllipsoid | slot |
| onSemiYChanged(axlPoint *semiY) | axlEllipsoid | slot |
| onSemiZChanged(axlPoint *semiZ) | axlEllipsoid | slot |
| opacity | axlAbstractData | |
| opacity(void) const | axlAbstractData | |
| operator<<(QDebug dbg, axlEllipsoid line) | axlEllipsoid | friend |
| operator<<(QDebug dbg, axlEllipsoid &line) | axlEllipsoid | friend |
| operator<<(QDebug dbg, axlEllipsoid *line) | axlEllipsoid | friend |
| operator=(const axlEllipsoid &other) | axlEllipsoid | |
| semiX | axlEllipsoid | |
| semiX(void) const | axlEllipsoid | |
| semiY | axlEllipsoid | |
| semiY(void) const | axlEllipsoid | |
| semiZ | axlEllipsoid | |
| semiZ(void) const | axlEllipsoid | |
| setCenter(axlPoint *center) | axlEllipsoid | |
| setColor(double r, double g, double b) | axlAbstractData | |
| setColor(const QColor &color) | axlAbstractData | slot |
| setEditable(bool edit) | axlAbstractData | slot |
| setMesh(axlMesh *mesh) | axlAbstractData | |
| setOpacity(const double &opacity) | axlAbstractData | slot |
| setSemiX(axlPoint *semiX) | axlEllipsoid | |
| setSemiY(axlPoint *semiY) | axlEllipsoid | |
| setSemiZ(axlPoint *semiZ) | axlEllipsoid | |
| setShader(const QString &shader) | axlAbstractData | slot |
| setSize(const double &size) | axlAbstractData | slot |
| setUpdateView(bool updateView) | axlAbstractData | |
| setValues(axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ) | axlEllipsoid | |
| shader | axlAbstractData | |
| shader(void) const | axlAbstractData | |
| size | axlAbstractData | |
| size(void) const | axlAbstractData | |
| touchCenter(axlPoint center) | axlEllipsoid | |
| touchField(void) | axlAbstractData | virtualslot |
| touchGeometry(void) | axlAbstractData | slot |
| touchProperty(void) | axlAbstractData | slot |
| touchSemiX(axlPoint semiX) | axlEllipsoid | |
| touchSemiY(axlPoint semiY) | axlEllipsoid | |
| touchSemiZ(axlPoint semiZ) | axlEllipsoid | |
| touchStructure(void) | axlAbstractData | slot |
| updateFieldList(QString nameField) | axlAbstractData | |
| updateView(void) | axlAbstractData | |
| ~axlAbstractData(void) | axlAbstractData | virtual |
| ~axlEllipsoid(void) | axlEllipsoid | |
