Class axlEllipsoid defines 3D ellipsoids. More...
#include <axlEllipsoid.h>
Public Slots | |
| void | onCenterChanged (axlPoint *center) |
| void | onSemiXChanged (axlPoint *semiX) |
| void | onSemiYChanged (axlPoint *semiY) |
| void | onSemiZChanged (axlPoint *semiZ) |
| void | calculateYZ (void) |
| void | calculateXZ (void) |
| void | calculateXY (void) |
Public Slots inherited from axlAbstractData | |
| void | touchGeometry (void) |
| void | touchProperty (void) |
| void | touchStructure (void) |
| virtual void | touchField (void) |
| void | setColor (const QColor &color) |
| void | setOpacity (const double &opacity) |
| void | setSize (const double &size) |
| void | setShader (const QString &shader) |
| void | setEditable (bool edit) |
Public Member Functions | |
| axlEllipsoid (QObject *parent=0) | |
| Constructs a axel ellipsoid of with firstPoint and second point are NULL and 1.0 radius with parent parent of QObject type. More... | |
| axlEllipsoid (axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ, QObject *parent=0) | |
| Constructs a axel ellipsoid of two axlPoint center p2 and radius radius with parent parent of QObject type. More... | |
| axlEllipsoid (const axlPoint ¢er, const axlPoint &semiX, const axlPoint &semiY, const axlPoint &semiZ, QObject *parent=0) | |
| Constructs a axel ellipsoid from two axlPoint center p2 and radius radius with parent parent. More... | |
| axlEllipsoid (const axlEllipsoid &other) | |
| Constructs a copy of other with same axlPoints. More... | |
| ~axlEllipsoid (void) | |
| Destroys the axel ellipsoid. More... | |
| virtual QString | description (void) const |
| virtual QString | identifier (void) const |
| axlPoint * | center (void) const |
| Returns center of the ellipsoid. More... | |
| axlPoint * | semiX (void) const |
| Returns semi x axe value of the ellipsoid. More... | |
| axlPoint * | semiY (void) const |
| Returns semi y axe value of the ellipsoid. More... | |
| axlPoint * | semiZ (void) const |
| Returns semi z axe value of the ellipsoid. More... | |
| void | setValues (axlPoint *center, axlPoint *semiX, axlPoint *semiY, axlPoint *semiZ) |
| Change center, semi axes x, y, z values and quarternion of this ellipsoid. More... | |
| void | setCenter (axlPoint *center) |
| Change center of this ellipsoid. More... | |
| void | setSemiX (axlPoint *semiX) |
| Change semi axes x value of this ellipsoid. More... | |
| void | setSemiY (axlPoint *semiY) |
| Change semi axes y value of this ellipsoid. More... | |
| void | setSemiZ (axlPoint *semiZ) |
| Change semi axes z value of this ellipsoid. More... | |
| void | touchCenter (axlPoint center) |
| void | touchSemiX (axlPoint semiX) |
| void | touchSemiY (axlPoint semiY) |
| void | touchSemiZ (axlPoint semiZ) |
| void | modifyCenter (double *center) |
| modify Center of this Ellipsoid. More... | |
| void | modifyCenterX (double x) |
| modify X Center value of this Ellipsoid. More... | |
| void | modifyCenterY (double y) |
| modify Y Center value of this Ellipsoid. More... | |
| void | modifyCenterZ (double z) |
| modify Z Center value of this Ellipsoid. More... | |
| void | modifySemiX (double *semiX) |
| modify SemiX of this Ellipsoid. More... | |
| void | modifySemiXX (double x) |
| modify X SemiX value of this Ellipsoid. More... | |
| void | modifySemiXY (double y) |
| modify Y SemiX value of this Ellipsoid. More... | |
| void | modifySemiXZ (double z) |
| modify Z SemiX value of this Ellipsoid. More... | |
| void | modifySemiY (double *semiY) |
| modify SemiY of this Ellipsoid. More... | |
| void | modifySemiYX (double x) |
| modify X SemiY value of this Ellipsoid. More... | |
| void | modifySemiYY (double y) |
| modify Y SemiY value of this Ellipsoid. More... | |
| void | modifySemiYZ (double z) |
| modify Z SemiY value of this Ellipsoid. More... | |
| void | modifySemiZ (double *semiZ) |
| modify SemiZ of this Ellipsoid. More... | |
| void | modifySemiZX (double x) |
| modify X SemiZ value of this Ellipsoid. More... | |
| void | modifySemiZY (double y) |
| modify Y SemiZ value of this Ellipsoid. More... | |
| void | modifySemiZZ (double z) |
| modify Z SemiZ value of this Ellipsoid. More... | |
| axlEllipsoid & | operator= (const axlEllipsoid &other) |
| Assigns other to this ellipsoid and returns a reference to this ellipsoid. More... | |
| QVariantList | convertDataToQVariant (void) const |
| Convert an axlAbstractData into a QVariantList that specifies all properties of the axlAbstractData. More... | |
| int | convertQVariantToData (const QVariantList &data) |
| Modify properties and geometry variables of the axlAbstractData. Return 1 if the modification was sucessfully made. Otherwise return 0. More... | |
Public Member Functions inherited from axlAbstractData | |
| axlAbstractData (axlAbstractData *parent=NULL) | |
| axlAbstractData (const axlAbstractData &data) | |
| virtual | ~axlAbstractData (void) |
| const QColor & | color (void) const |
| const double & | opacity (void) const |
| const double & | size (void) const |
| const QString & | shader (void) const |
| const bool & | editable (void) |
| const bool & | updateView (void) |
| void | setColor (double r, double g, double b) |
| void | addField (axlAbstractField *field) |
| Add a field to the field list of the object. More... | |
| bool | updateFieldList (QString nameField) |
| Check if a field with the same name is already applied on the object. More... | |
| QString | changeFieldName (QString fieldName) |
| axlMesh * | mesh (void) |
| Return the mesh of that object is computed. More... | |
| void | setMesh (axlMesh *mesh) |
| Set a corresponding mesh for that object. More... | |
| void | setUpdateView (bool updateView) |
| QList< axlAbstractField * > | fields (void) |
Properties | |
| axlPoint | center |
| axlPoint | semiX |
| axlPoint | semiY |
| axlPoint | semiZ |
Properties inherited from axlAbstractData | |
| QColor | color |
| double | opacity |
| double | size |
| QString | shader |
Friends | |
| QDebug | operator<< (QDebug dbg, axlEllipsoid line) |
| QDebug | operator<< (QDebug dbg, axlEllipsoid &line) |
| QDebug | operator<< (QDebug dbg, axlEllipsoid *line) |
Additional Inherited Members | |
Signals inherited from axlAbstractData | |
| void | modifiedGeometry (void) |
| void | modifiedStructure (void) |
| void | modifiedField (void) |
| void | modifiedProperty (void) |
This class enables to represent and manipulate 3D ellipsoids.
Example:
Definition at line 35 of file axlEllipsoid.h.
| axlEllipsoid::axlEllipsoid | ( | QObject * | parent = 0 | ) |
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel ellipsoid with no parent.
Definition at line 51 of file axlEllipsoid.cpp.
| axlEllipsoid::axlEllipsoid | ( | axlPoint * | center, |
| axlPoint * | semiX, | ||
| axlPoint * | semiY, | ||
| axlPoint * | semiZ, | ||
The parent of an object may be viewed as the object's owner. The destructor of a parent object destroys all child objects. Setting parent to 0 constructs a axel point with no parent.
Definition at line 67 of file axlEllipsoid.cpp.
| axlEllipsoid::axlEllipsoid | ( | const axlPoint & | center, |
| const axlPoint & | semiX, | ||
| const axlPoint & | semiY, | ||
| const axlPoint & | semiZ, | ||
Definition at line 83 of file axlEllipsoid.cpp.
| axlEllipsoid::axlEllipsoid | ( | const axlEllipsoid & | other | ) |
Definition at line 97 of file axlEllipsoid.cpp.
| axlEllipsoid::~axlEllipsoid | ( | void | ) |
Definition at line 112 of file axlEllipsoid.cpp.
slot |
Definition at line 610 of file axlEllipsoid.cpp.
slot |
Definition at line 556 of file axlEllipsoid.cpp.
slot |
Definition at line 502 of file axlEllipsoid.cpp.
| axlPoint * axlEllipsoid::center | ( | void | ) | const |
Definition at line 157 of file axlEllipsoid.cpp.
virtual |
Reimplemented from axlAbstractData.
Definition at line 664 of file axlEllipsoid.cpp.
virtual |
Definition at line 682 of file axlEllipsoid.cpp.
virtual |
Definition at line 296 of file axlEllipsoid.cpp.
virtual |
Definition at line 308 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifyCenter | ( | double * | center | ) |
Definition at line 342 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifyCenterX | ( | double | x | ) |
Definition at line 352 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifyCenterY | ( | double | y | ) |
Definition at line 362 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifyCenterZ | ( | double | z | ) |
Definition at line 372 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiX | ( | double * | semiX | ) |
Definition at line 382 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiXX | ( | double | x | ) |
Definition at line 392 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiXY | ( | double | y | ) |
Definition at line 402 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiXZ | ( | double | z | ) |
Definition at line 412 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiY | ( | double * | semiY | ) |
Definition at line 422 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiYX | ( | double | x | ) |
Definition at line 432 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiYY | ( | double | y | ) |
Definition at line 443 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiYZ | ( | double | z | ) |
Definition at line 453 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiZ | ( | double * | semiZ | ) |
Definition at line 463 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiZX | ( | double | x | ) |
Definition at line 473 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiZY | ( | double | y | ) |
Definition at line 484 of file axlEllipsoid.cpp.
| void axlEllipsoid::modifySemiZZ | ( | double | z | ) |
Definition at line 495 of file axlEllipsoid.cpp.
slot |
Definition at line 314 of file axlEllipsoid.cpp.
slot |
Definition at line 320 of file axlEllipsoid.cpp.
slot |
Definition at line 326 of file axlEllipsoid.cpp.
slot |
Definition at line 332 of file axlEllipsoid.cpp.
| axlEllipsoid & axlEllipsoid::operator= | ( | const axlEllipsoid & | other | ) |
Definition at line 143 of file axlEllipsoid.cpp.
| axlPoint * axlEllipsoid::semiX | ( | void | ) | const |
Definition at line 166 of file axlEllipsoid.cpp.
| axlPoint * axlEllipsoid::semiY | ( | void | ) | const |
Definition at line 175 of file axlEllipsoid.cpp.
| axlPoint * axlEllipsoid::semiZ | ( | void | ) | const |
Definition at line 184 of file axlEllipsoid.cpp.
| void axlEllipsoid::setCenter | ( | axlPoint * | center | ) |
Definition at line 207 of file axlEllipsoid.cpp.
| void axlEllipsoid::setSemiX | ( | axlPoint * | semiX | ) |
Definition at line 218 of file axlEllipsoid.cpp.
| void axlEllipsoid::setSemiY | ( | axlPoint * | semiY | ) |
Definition at line 229 of file axlEllipsoid.cpp.
| void axlEllipsoid::setSemiZ | ( | axlPoint * | semiZ | ) |
Definition at line 240 of file axlEllipsoid.cpp.
| void axlEllipsoid::setValues | ( | axlPoint * | center, |
| axlPoint * | semiZ | ||
Definition at line 193 of file axlEllipsoid.cpp.
| void axlEllipsoid::touchCenter | ( | axlPoint | center | ) |
Definition at line 247 of file axlEllipsoid.cpp.
| void axlEllipsoid::touchSemiX | ( | axlPoint | semiX | ) |
Definition at line 253 of file axlEllipsoid.cpp.
| void axlEllipsoid::touchSemiY | ( | axlPoint | semiY | ) |
Definition at line 259 of file axlEllipsoid.cpp.
| void axlEllipsoid::touchSemiZ | ( | axlPoint | semiZ | ) |
Definition at line 265 of file axlEllipsoid.cpp.
friend |
Definition at line 275 of file axlEllipsoid.cpp.
friend |
Definition at line 282 of file axlEllipsoid.cpp.
friend |
Definition at line 289 of file axlEllipsoid.cpp.
readwrite |
Definition at line 38 of file axlEllipsoid.h.
readwrite |
readwrite |
Definition at line 39 of file axlEllipsoid.h.
readwrite |
Definition at line 40 of file axlEllipsoid.h.
