| axlInspectorObjectInterface(QWidget *parent=0) | axlInspectorObjectInterface | |
| dataChangedByGeometry(dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| filePath(const QString &shader) | axlInspectorObjectInterface | |
| hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| initComboBoxShaderValue(QComboBox *comboBoxShader, QLineEdit *lineEditShader) | axlInspectorObjectInterface | |
| m_objectFactorySingleton | axlInspectorObjectInterface | protected |
| modifiedProperty(dtkAbstractData *, int) | axlInspectorObjectInterface | signal |
| moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| objectFactorySingleton(void) | axlInspectorObjectInterface | |
| setData(dtkAbstractData *data) | axlInspectorObjectInterface | virtualslot |
| setObjectFactorySingleton(axlInspectorObjectFactory *objectFactorySingleton) | axlInspectorObjectInterface | |
| showCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| tubeFilterRadiusChanged(dtkAbstractData *data, double radius) | axlInspectorObjectInterface | signal |
| update() | axlInspectorObjectInterface | signal |
| updateStateColor(dtkAbstractData *data, int i) | axlInspectorObjectInterface | signal |
| ~axlInspectorObjectInterface(void) | axlInspectorObjectInterface | virtual |
