Developer documentation | Axl-2.5.1
axlInspectorObjectInterface Class Reference
#include <axlInspectorObjectFactory.h>
Inheritance diagram for axlInspectorObjectInterface:
axlAbstractVolumeDiscreteEditor axlInspectorObjectCircleArc axlInspectorObjectCone axlInspectorObjectCylinder axlInspectorObjectDataDynamic axlInspectorObjectEllipsoid axlInspectorObjectLine axlInspectorObjectMesh axlInspectorObjectPlane axlInspectorObjectPoint axlInspectorObjectVolumeDiscrete
Public Slots
virtual void setData (dtkAbstractData *data)
Signals
void dataChangedByGeometry (dtkAbstractData *data)
void showCurrentPoint (double u, double v, dtkAbstractData *data)
void hideCurrentPoint (double u, double v, dtkAbstractData *data)
void moveCurrentPoint (double u, double v, dtkAbstractData *data)
void tubeFilterRadiusChanged (dtkAbstractData *data, double radius)
void updateStateColor (dtkAbstractData *data, int i)
void modifiedProperty (dtkAbstractData *, int)
void update ()
Public Member Functions
 axlInspectorObjectInterface (QWidget *parent=0)
virtual ~axlInspectorObjectInterface (void)
void setObjectFactorySingleton (axlInspectorObjectFactory *objectFactorySingleton)
axlInspectorObjectFactory * objectFactorySingleton (void)
void initComboBoxShaderValue (QComboBox *comboBoxShader, QLineEdit *lineEditShader)
QString filePath (const QString &shader)
Protected Attributes
axlInspectorObjectFactory * m_objectFactorySingleton
Detailed Description
Definition at line 41 of file axlInspectorObjectFactory.h.
Constructor & Destructor Documentation
axlInspectorObjectInterface::axlInspectorObjectInterface ( QWidget *  parent = 0)
Definition at line 26 of file axlInspectorObjectFactory.cpp.
axlInspectorObjectInterface::~axlInspectorObjectInterface ( void  )
virtual
Definition at line 31 of file axlInspectorObjectFactory.cpp.
Member Function Documentation
void axlInspectorObjectInterface::dataChangedByGeometry ( dtkAbstractData *  data)
signal
QString axlInspectorObjectInterface::filePath ( const QString &  shader)
Definition at line 113 of file axlInspectorObjectFactory.cpp.
void axlInspectorObjectInterface::hideCurrentPoint ( double  u,
double  v,
signal
void axlInspectorObjectInterface::initComboBoxShaderValue ( QComboBox *  comboBoxShader,
QLineEdit *  lineEditShader
Definition at line 52 of file axlInspectorObjectFactory.cpp.
void axlInspectorObjectInterface::modifiedProperty ( dtkAbstractData *  ,
int
signal
void axlInspectorObjectInterface::moveCurrentPoint ( double  u,
double  v,
signal
axlInspectorObjectFactory * axlInspectorObjectInterface::objectFactorySingleton ( void  )
Definition at line 41 of file axlInspectorObjectFactory.cpp.
void axlInspectorObjectInterface::setData ( dtkAbstractData *  data)
virtualslot
Definition at line 46 of file axlInspectorObjectFactory.cpp.
void axlInspectorObjectInterface::setObjectFactorySingleton ( axlInspectorObjectFactory *  objectFactorySingleton)
Definition at line 36 of file axlInspectorObjectFactory.cpp.
void axlInspectorObjectInterface::showCurrentPoint ( double  u,
double  v,
signal
void axlInspectorObjectInterface::tubeFilterRadiusChanged ( dtkAbstractData *  data,
double  radius
signal
void axlInspectorObjectInterface::update ( )
signal
void axlInspectorObjectInterface::updateStateColor ( dtkAbstractData *  data,
int  i
signal
Member Data Documentation
axlInspectorObjectFactory* axlInspectorObjectInterface::m_objectFactorySingleton
protected
Definition at line 76 of file axlInspectorObjectFactory.h.
The documentation for this class was generated from the following files:
