#include <axlInspectorObjectManager.h>
| void | inserted (void) |
| void | stateChanged (dtkAbstractData *data, int mode) |
| void | actorVisibilityChanged (dtkAbstractData *data, bool actorVisibility) |
| void | dataChangedByGeometry (dtkAbstractData *data) |
| void | interpolationChanded (dtkAbstractData *data, int interpolation) |
| void | modifiedProperty (dtkAbstractData *, int) |
| void | dataSetRemoved (QList< dtkAbstractData * > dataSetRemoved) |
| void | update (void) |
| void | showCurrentPoint (double u, double v, dtkAbstractData *data) |
| void | moveCurrentPoint (double u, double v, dtkAbstractData *data) |
| void | hideCurrentPoint (double u, double v, dtkAbstractData *data) |
Definition at line 38 of file axlInspectorObjectManager.h.
| axlInspectorObjectManager::axlInspectorObjectManager |
QWidget * |
parent = 0 | ) |
| axlInspectorObjectManager::~axlInspectorObjectManager |
void |
| void axlInspectorObjectManager::actorVisibilityChanged |
dtkAbstractData * |
data, |
bool |
actorVisibility |
signal |
| void axlInspectorObjectManager::clearScene |
void |
| void axlInspectorObjectManager::dataChangedByGeometry |
dtkAbstractData * |
data | ) |
signal |
| QList< dtkAbstractData * > axlInspectorObjectManager::dataSet |
void |
| void axlInspectorObjectManager::dataSetRemoved |
QList< dtkAbstractData * > |
dataSetRemoved | ) |
signal |
| void axlInspectorObjectManager::hideCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectManager::inserted |
void |
signal |
| void axlInspectorObjectManager::interpolationChanded |
dtkAbstractData * |
data, |
int |
interpolation |
signal |
| void axlInspectorObjectManager::modifiedProperty |
dtkAbstractData * |
int |
signal |
| void axlInspectorObjectManager::moveCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectManager::onDataRemoved |
dataToRemoved | ) |
slot |
| void axlInspectorObjectManager::onFieldListSelectionChanged |
void |
slot |
| void axlInspectorObjectManager::onFieldOpened |
QList< axlAbstractData * > |
dataList, |
QString |
fieldName |
slot |
| void axlInspectorObjectManager::onFieldsCreatedOnData |
dataList, |
QString |
fieldName |
slot |
| void axlInspectorObjectManager::onStateChanged |
dtkAbstractData * |
data, |
int |
mode |
slot |
| axlAbstractField * axlInspectorObjectManager::onTransmitDataSelected |
QListWidgetItem * |
fromItem, |
QListWidgetItem * |
toItem |
slot |
| void axlInspectorObjectManager::removeData |
dtkAbstractData * |
data | ) |
| void axlInspectorObjectManager::resizeColumnToContents |
| void axlInspectorObjectManager::showCurrentPoint |
double |
u, |
double |
v, |
dtkAbstractData * |
data |
signal |
| void axlInspectorObjectManager::stateChanged |
dtkAbstractData * |
data, |
int |
mode |
signal |
| void axlInspectorObjectManager::update |
void |
signal |
The documentation for this class was generated from the following files:
