Developer documentation | Axl-2.5.1
axlInspectorObjectManagerTree Class Reference
#include <axlInspectorObjectManagerTree.h>
Inheritance diagram for axlInspectorObjectManagerTree:
Public Slots
void onAllItemClickStatedChanged ()
void onDoubleClickStateChanged (QTreeWidgetItem *currentItem, int column)
void onItemClickedStateChanged (QTreeWidgetItem *currentItem, int column)
void onItemExpanded (QTreeWidgetItem *)
void onStateChanged (dtkAbstractData *data, int mode)
void setAppendMode (bool append)
void onDataRemoved (QList< dtkAbstractData * > dataToRemoved)
void remove (QObject *data)
void onVisibilityHeaderClick (int index)
Signals
void inserted (void)
void dataSetRemoved (QList< dtkAbstractData * > dataSetRemoved)
void selected (dtkAbstractData *data)
void dataSetSelected (QList< dtkAbstractData * > data)
void stateChanged (dtkAbstractData *data, int mode)
void actorVisibilityChanged (dtkAbstractData *data, bool actorVisibility)
Public Member Functions
 axlInspectorObjectManagerTree (QWidget *parent=0)
 ~axlInspectorObjectManagerTree (void)
axlInspectorObjectManagerTreeIteminsert (axlAbstractData *data)
void remove (dtkAbstractData *data)
void setController (axlInspectorObjectController *controller)
QList< dtkAbstractData * > dataSet (void)
void keyPressEvent (QKeyEvent *event)
void removeAllItems (void)
Detailed Description
Definition at line 37 of file axlInspectorObjectManagerTree.h.
Constructor & Destructor Documentation
axlInspectorObjectManagerTree::axlInspectorObjectManagerTree ( QWidget *  parent = 0)
Definition at line 44 of file axlInspectorObjectManagerTree.cpp.
axlInspectorObjectManagerTree::~axlInspectorObjectManagerTree ( void  )
Definition at line 65 of file axlInspectorObjectManagerTree.cpp.
Member Function Documentation
void axlInspectorObjectManagerTree::actorVisibilityChanged ( dtkAbstractData *  data,
signal
QList< dtkAbstractData * > axlInspectorObjectManagerTree::dataSet ( void  )
Definition at line 279 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::dataSetRemoved ( QList< dtkAbstractData * >  dataSetRemoved)
signal
void axlInspectorObjectManagerTree::dataSetSelected ( QList< dtkAbstractData * >  data)
signal
axlInspectorObjectManagerTreeItem * axlInspectorObjectManagerTree::insert ( axlAbstractData data)
Definition at line 156 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::inserted ( void  )
signal
void axlInspectorObjectManagerTree::keyPressEvent ( QKeyEvent *  event)
Definition at line 557 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onAllItemClickStatedChanged ( )
slot
Definition at line 381 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onDataRemoved ( QList< dtkAbstractData * >  dataToRemoved)
slot
Definition at line 148 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onDoubleClickStateChanged ( QTreeWidgetItem *  currentItem,
int  column
slot
Definition at line 344 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onItemClickedStateChanged ( QTreeWidgetItem *  currentItem,
int  column
slot
Definition at line 452 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onItemExpanded ( QTreeWidgetItem *  item)
slot
Definition at line 262 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onStateChanged ( dtkAbstractData *  data,
int  mode
slot
Definition at line 290 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::onVisibilityHeaderClick ( int  index)
slot
Definition at line 78 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::remove ( dtkAbstractData *  data)
Definition at line 102 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::remove ( QObject *  data)
slot
Definition at line 124 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::removeAllItems ( void  )
Definition at line 648 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::selected ( dtkAbstractData *  data)
signal
void axlInspectorObjectManagerTree::setAppendMode ( bool  append)
slot
Definition at line 508 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::setController ( axlInspectorObjectController controller)
Definition at line 72 of file axlInspectorObjectManagerTree.cpp.
void axlInspectorObjectManagerTree::stateChanged ( dtkAbstractData *  data,
int  mode
signal
The documentation for this class was generated from the following files:
