| axlInspectorObjectInterface(QWidget *parent=0) | axlInspectorObjectInterface | |
| axlInspectorObjectPlane(QWidget *parent=0) | axlInspectorObjectPlane | |
| dataChangedByGeometry(dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| filePath(const QString &shader) | axlInspectorObjectInterface | |
| hideCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| initComboBoxShaderValue(QComboBox *comboBoxShader, QLineEdit *lineEditShader) | axlInspectorObjectInterface | |
| m_objectFactorySingleton | axlInspectorObjectInterface | protected |
| modifiedProperty(dtkAbstractData *, int) | axlInspectorObjectInterface | signal |
| moveCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| objectFactorySingleton(void) | axlInspectorObjectInterface | |
| onColorChanged(QColor color) | axlInspectorObjectPlane | slot |
| onCoordDataChangedNormal_x(double x) | axlInspectorObjectPlane | slot |
| onCoordDataChangedNormal_y(double y) | axlInspectorObjectPlane | slot |
| onCoordDataChangedNormal_z(double z) | axlInspectorObjectPlane | slot |
| onCoordDataChangedPoint_x(double x) | axlInspectorObjectPlane | slot |
| onCoordDataChangedPoint_y(double y) | axlInspectorObjectPlane | slot |
| onCoordDataChangedPoint_z(double z) | axlInspectorObjectPlane | slot |
| onLineEditShaderChanged(QString) | axlInspectorObjectPlane | slot |
| onOpacityChanged(int opacity) | axlInspectorObjectPlane | slot |
| onShaderChanged(QString) | axlInspectorObjectPlane | slot |
| onShaderStateChanged(bool isShader) | axlInspectorObjectPlane | slot |
| onSizeChanged(double size) | axlInspectorObjectPlane | slot |
| openShader(void) | axlInspectorObjectPlane | slot |
| setData(axlPlane *pointt) | axlInspectorObjectPlane | slot |
| axlInspectorObjectInterface::setData(dtkAbstractData *data) | axlInspectorObjectInterface | virtualslot |
| setObjectFactorySingleton(axlInspectorObjectFactory *objectFactorySingleton) | axlInspectorObjectInterface | |
| showCurrentPoint(double u, double v, dtkAbstractData *data) | axlInspectorObjectInterface | signal |
| sizeHint(void) const | axlInspectorObjectPlane | |
| tubeFilterRadiusChanged(dtkAbstractData *data, double radius) | axlInspectorObjectInterface | signal |
| update() | axlInspectorObjectInterface | signal |
| updateStateColor(dtkAbstractData *data, int i) | axlInspectorObjectInterface | signal |
| updateValues(void) | axlInspectorObjectPlane | slot |
| ~axlInspectorObjectInterface(void) | axlInspectorObjectInterface | virtual |
| ~axlInspectorObjectPlane(void) | axlInspectorObjectPlane | |
