#include <axlInspectorObjectPointSet.h>
          | axlInspectorObjectPointSet::axlInspectorObjectPointSet | ( | QWidget * | parent = 0 | ) |  |
          | axlInspectorObjectPointSet::~axlInspectorObjectPointSet | ( | void |  | ) |  |
          | void axlInspectorObjectPointSet::colorChanged | ( | QColor | color, |
          |  |  | dtkAbstractData * | data |
          |  | ) |  |  |  | signal |
          | void axlInspectorObjectPointSet::dataChangedByColor | ( | dtkAbstractData * | data, |
          |  |  | double | red, |
          |  |  | double | green, |
          |  |  | double | blue |
          |  | ) |  |  |  | signal |
          | void axlInspectorObjectPointSet::dataChangedByGeometry | ( | dtkAbstractData * | data | ) |  |  | signal |
          | void axlInspectorObjectPointSet::dataChangedByOpacity | ( | dtkAbstractData * | data, |
          |  |  | double | opacity |
          |  | ) |  |  |  | signal |
          | void axlInspectorObjectPointSet::dataChangedByShader | ( | dtkAbstractData * | data, |
          |  |  | QString | isophoteShaderXml |
          |  | ) |  |  |  | signal |
          | void axlInspectorObjectPointSet::dataChangedBySize | ( | dtkAbstractData * | data, |
          |  |  | double | size |
          |  | ) |  |  |  | signal |
          | void axlInspectorObjectPointSet::onColorChanged | ( | QColor | color | ) |  |  | slot |
          | void axlInspectorObjectPointSet::onLineEditShaderChanged | ( | QString | shader | ) |  |  | slot |
          | void axlInspectorObjectPointSet::onOpacityChanged | ( | int | opacity | ) |  |  | slot |
          | void axlInspectorObjectPointSet::onShaderChanged | ( | QString | shader | ) |  |  | slot |
          | void axlInspectorObjectPointSet::onShaderStateChanged | ( | bool | isShader | ) |  |  | slot |
          | void axlInspectorObjectPointSet::onSizeChanged | ( | int | size | ) |  |  | slot |
          | void axlInspectorObjectPointSet::openShader | ( | void |  | ) |  |  | slot |
          | void axlInspectorObjectPointSet::setData | ( | axlPointSet * | pointt | ) |  |  | slot |
          | QSize axlInspectorObjectPointSet::sizeHint | ( | void |  | ) | const |
          | void axlInspectorObjectPointSet::update | ( | void |  | ) |  |  | signal |
The documentation for this class was generated from the following files:
