Developer documentation | Axl-2.5.1
axlInspectorObjectSceneWidgetFieldScalar Class Reference
#include <axlInspectorObjectSceneWidgetFieldScalar.h>
Inheritance diagram for axlInspectorObjectSceneWidgetFieldScalar:
Public Slots
void setIsoCount (int count)
void setIsoRangeMin (double min)
void setIsoRangeMax (double max)
void setField (axlAbstractField *field)
void setView (axlAbstractView *view)
void setDefaultDisplay (void)
Signals
void displayAsColor (void)
void displayAsIso (void)
void displayAsNone (void)
void colRangeMinChanged (double)
void colRangeMaxChanged (double)
void isoCountChanged (int)
void isoRadiusChanged (double)
void isoRangeMinChanged (double)
void isoRangeMaxChanged (double)
Public Member Functions
 axlInspectorObjectSceneWidgetFieldScalar (QWidget *parent=0)
 ~axlInspectorObjectSceneWidgetFieldScalar (void)
Protected Slots
void onDisplayAsColorClicked (void)
void onDisplayAsIsoClicked (void)
void onDisplayAsNothingClicked (void)
Detailed Description
Definition at line 31 of file axlInspectorObjectSceneWidgetFieldScalar.h.
Constructor & Destructor Documentation
axlInspectorObjectSceneWidgetFieldScalar::axlInspectorObjectSceneWidgetFieldScalar ( QWidget *  parent = 0)
Definition at line 47 of file axlInspectorObjectSceneWidgetFieldScalar.cpp.
axlInspectorObjectSceneWidgetFieldScalar::~axlInspectorObjectSceneWidgetFieldScalar ( void  )
Definition at line 91 of file axlInspectorObjectSceneWidgetFieldScalar.cpp.
Member Function Documentation
void axlInspectorObjectSceneWidgetFieldScalar::colRangeMaxChanged ( double  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::colRangeMinChanged ( double  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::displayAsColor ( void  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::displayAsIso ( void  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::displayAsNone ( void  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::isoCountChanged ( int  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::isoRadiusChanged ( double  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::isoRangeMaxChanged ( double  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::isoRangeMinChanged ( double  )
signal
void axlInspectorObjectSceneWidgetFieldScalar::onDisplayAsColorClicked ( void  )
protectedslot
void axlInspectorObjectSceneWidgetFieldScalar::onDisplayAsIsoClicked ( void  )
protectedslot
void axlInspectorObjectSceneWidgetFieldScalar::onDisplayAsNothingClicked ( void  )
protectedslot
void axlInspectorObjectSceneWidgetFieldScalar::setDefaultDisplay ( void  )
slot
void axlInspectorObjectSceneWidgetFieldScalar::setField ( axlAbstractField field)
slot
void axlInspectorObjectSceneWidgetFieldScalar::setIsoCount ( int  count)
slot
Definition at line 98 of file axlInspectorObjectSceneWidgetFieldScalar.cpp.
void axlInspectorObjectSceneWidgetFieldScalar::setIsoRangeMax ( double  max)
slot
void axlInspectorObjectSceneWidgetFieldScalar::setIsoRangeMin ( double  min)
slot
void axlInspectorObjectSceneWidgetFieldScalar::setView ( axlAbstractView view)
slot
The documentation for this class was generated from the following files:
